  • 2714阅读
  • 1回复
新机欣赏:FTM-3200DE / FTM-3200DR (Europe / USA) [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2016-04-17
GENERAL
Type:Amateur VHF transceiver
Frequency range:TX: 144-146 MHz (Europe)
RX: 136-174 MHz
Tuning steps:5 / 6.25 / 10 / 12.5 / 15 / 20 / 25 / 50 / 100 KHz
Mode:TX: FM/NFM/DV (C4FM FDMA, 9.6 Kbps)
RX: AM/FM/NFM/DV (C4FM FDMA, 9.6 Kbps)
Channels/memory management:220 regular with alpha tags
Repeater shift/offset:±? KHz
Power supply:11.7-15.8 VDC
Current drain/power consumption:RX: ? mA
TX: Max ? A
Antenna impedance/connector:50 ohms / SO-239
Dimensions (W*H*D):154*43*155 mm (6.06*1.69*6.1")
Weight:Total: 1.3 Kg (2.86 lbs)
Other features:CTCSS/PL, DCS
RECEIVER SECTION
Receiver system:Double conversion superheterodyne
1st IF: ? MHz
2nd IF: ? KHz
Sensitivity:
Selectivity:
Image rejection:
AF output power/speaker:3 W at ?% distortion / ? ohms
External speaker connector:
TRANSMITTER SECTION
RF output power:Hi: 65 W
Mid: 30 W
Lo: 5 W
Modulation system:FM: Variable reactance
DV: 4FSK/C4FM
Max FM deviation:FM: ±5 KHz
NFM: ±2.5 KHz
Spurious emissions:Less than -? dB
Microphone impedance/connector:? Kohm / 8-pin (modular)
MISCELLANEOUS
Manufactured:2016-201x
Additional info:Not compatible with HRI-200 (Wires-X)
Related documents:
1222
88
[ 此帖被BD3RJ在2016-04-17 10:25重新编辑 ]
Stay Here Forever!
只看该作者 1楼 发表于: 2016-04-17
长宽高6*1.7*6.1
