  • 4431阅读
  • 15回复
2015 CQWW CW Logchecking Report [复制链接]
离线BA7NQ
只看楼主 倒序阅读 0楼 发表于: 2016-04-09
在这个无聊的周末,收到了2015 CQWW CW的Logcheck报告...
Contest: 2015 CQ WW DX CONTEST CWCall: B7P
Category: Single Op All Band High Power AssistedOperator(s):BA7NQ
************************** Summary ***************************
1802 Claimed QSO before checking (does not include duplicates)
1766 Final QSO after checking reductions
3392 Claimed QSO points3176 Final QSO points
232 Claimed countries231 Final countries
110 Claimed zones110 Final zones
342 Claimed mults341 Final mults
1160064 Claimed score1083016 Final score
6.6% Score reduction
2.0% Error Rate based on claimed and final qso counts
22 (1.2%) calls copied incorrectly
5 (0.3%) exchanges copied incorrectly
9 (0.5%) not in log
15 (0.8%) duplicates (Removed without penalty)
5 (0.3%) calls unique to this log only (not removed)
离线bg8srq
只看该作者 1楼 发表于: 2016-04-10
我也收到了,4.0%的出错率,超过平均值2.55%
离线bd7ob
只看该作者 2楼 发表于: 2016-04-10
我也收到了,扣分比较多,有8个系数损失。
1228 Claimed QSO before checking (does not include duplicates)
1201 Final   QSO after  checking reductions
2560 Claimed QSO points
2350 Final   QSO points
171 Claimed countries
165 Final   countries
81 Claimed zones
79 Final   zones
252 Claimed mults
244 Final   mults
645120 Claimed score
573400 Final   score
11.1% Score reduction
2.2% Error Rate based on claimed and final qso counts
15 (1.2%) calls copied incorrectly
1 (0.1%) exchanges copied incorrectly
11 (0.9%) not in log
13 (1.0%) duplicates (Removed without penalty)
6 (0.5%) calls unique to this log only (not removed)
[ 此帖被bd7ob在2016-04-10 10:25重新编辑 ]
不使用自己呼号远程操作其它电台;
不使用QSO机器人;
不使用CW解调软件做CW QSO;
离线bg3upa
只看该作者 3楼 发表于: 2016-04-10
9.9% Score reduction
    2.9% Error Rate based on claimed and final qso counts
      37 (1.7%) calls copied incorrectly
       4 (0.2%) exchanges copied incorrectly
       1 (0.0%) band change violations
      22 (1.0%) not in log
      35 (1.6%) duplicates (Removed without penalty)
       8 (0.4%) calls unique to this log only (not removed)
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
离线bg3upa
只看该作者 4楼 发表于: 2016-04-10
************************* Not In Log *************************
14015 CW 2015-11-28 0136 BG3UPA          24 W0DLE            4
14041 CW 2015-11-28 0235 BG3UPA          24 IR4M            15
21020 CW 2015-11-28 0512 BG3UPA          24 ZW5B            11
21018 CW 2015-11-28 0543 BG3UPA          24 JA1BNW          25
21048 CW 2015-11-28 0650 BG3UPA          24 AH0K            27
14045 CW 2015-11-28 0852 BG3UPA          24 JA4XHF/3        25
14045 CW 2015-11-28 0918 BG3UPA          24 DL1NKS          14
7037 CW 2015-11-28 1156 BG3UPA          24 JA2NDQ          25
7037 CW 2015-11-28 1254 BG3UPA          24 BH7PFH          24
7037 CW 2015-11-28 1408 BG3UPA          24 BD5FFK          24
请大家评评理,找上门来做了QSO,结果删了
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
离线bg2aue
只看该作者 5楼 发表于: 2016-04-10
两个B电台主动向四爷请安吧
离线BD5FFK
只看该作者 6楼 发表于: 2016-04-10
回 bg3upa 的帖子
bg3upa:************************* Not In Log *************************
14041 CW 2015-11-28 0 .. (2016-04-10 11:01)
经过认真核查和校对LOG,发现其他波段记录都有,就缺40米波段。尤其是两位情况都惊人一致。由此可以推断当事人在该事发过程中不是错乱就是幻听,对此次错误事件应付全部责任。判决赔偿上述被冤枉的两位精神损失费******.**元,即日红包付清!
退堂!!!
离线bg3upa
只看该作者 7楼 发表于: 2016-04-10
回 BD5FFK 的帖子
BD5FFK:经过认真核查和校对LOG,发现其他波段记录都有,就缺40米波段。尤其是两位情况都惊人一致。由此可以推断当事人在该事发过程中不是错乱就是幻听,对此次错误事件应付全部责任。判决赔偿上 .. (2016-04-10 11:14)
气死我了
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
离线BA5CW
只看该作者 8楼 发表于: 2016-04-10
楼上的请看
28034 CW 2015-11-28 0034 BY5CD           24 K9JF             3
14024 CW 2015-11-28 0220 BY5CD           24 LT7H            13
21013 CW 2015-11-28 0343 BY5CD           24 BG2AUE          24
14020 CW 2015-11-28 0654 BY5CD           24 OK2PCL          15
14035 CW 2015-11-28 0738 BY5CD           24 UN7LZ           17
21005 CW 2015-11-28 0741 BY5CD           24 OK4DZ           15
21037 CW 2015-11-28 0829 BY5CD           24 SN8B            15
21037 CW 2015-11-28 0830 BY5CD           24 SN8B            15
21016 CW 2015-11-28 0915 BY5CD           24 F6BVY           14
21034 CW 2015-11-28 1016 BY5CD           24 PY2NY           11
21039 CW 2015-11-28 1018 BY5CD           24 YO4DW           20
21037 CW 2015-11-28 1030 BY5CD           24 PZ5W             9
21019 CW 2015-11-28 1033 BY5CD           24 R3QX            16
21019 CW 2015-11-28 1034 BY5CD           24 R3QX            16
14000 CW 2015-11-28 1057 BY5CD           24 UA6ARR          16
7012 CW 2015-11-28 1127 BY5CD           24 JA1HNW          25
14023 CW 2015-11-28 1230 BY5CD           24 RA4AAT          16
1818 CW 2015-11-28 1426 BY5CD           24 B4T             24
3507 CW 2015-11-28 1432 BY5CD           24 RW4HD           16
14008 CW 2015-11-28 1436 BY5CD           24 K2LE             5
7012 CW 2015-11-28 1519 BY5CD           24 BH1BMG          24
3507 CW 2015-11-28 1605 BY5CD           24 BV1EL           24
我们错得多了,100个抄错呼号,76个not in log
离线bg3upa
只看该作者 9楼 发表于: 2016-04-10
回 BA5CW 的帖子
BA5CW:楼上的请看
14024  .. (2016-04-10 11:20)
有些错误是不应该发生的
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
离线BD5FFK
只看该作者 10楼 发表于: 2016-04-10
    1314 Claimed QSO before checking (does not include duplicates)
    1290 Final   QSO after  checking reductions
    2770 Claimed QSO points
    2611 Final   QSO points
     177 Claimed countries
     176 Final   countries
      86 Claimed zones
      85 Final   zones
     263 Claimed mults
     261 Final   mults
  728510 Claimed score
  681471 Final   score
    6.5% Score reduction
    1.8% Error Rate based on claimed and final qso counts
      15 (1.1%) calls copied incorrectly
       4 (0.3%) exchanges copied incorrectly
       5 (0.4%) not in log
      20 (1.5%) duplicates (Removed without penalty)
       2 (0.1%) calls unique to this log only (not removed)
21004 CW 2015-11-28 0620 BD5FFK          24 UA3R            16
7014 CW 2015-11-28 1330 BD5FFK          24 BY7KTO          24
14016 CW 2015-11-29 0245 BD5FFK          24 JA7ZP           25
14016 CW 2015-11-29 0309 BD5FFK          24 JH1EAQ          25
28020 CW 2015-11-29 0700 BD5FFK          24 RK9A            17
离线BH4AYG
只看该作者 11楼 发表于: 2016-04-10
我只想说,打酱油,俺是认真的,哈哈。。。。
柔若无骨二八子,
顺天应时游太虚;
如何觅取何首乌,
水远山高仙家有。
呼号:BH4AYG
QTH:上海徐家汇
QQ:34601046
离线BD5FFK
只看该作者 12楼 发表于: 2016-04-10
回 BH4AYG 的帖子
BH4AYG:[图片]
我只想说,打酱油,俺是认真的,哈哈。。。。 (2016-04-10 11:31)
零错误,牛逼!!!
奢侈品酱油不在多,关键在于精。
离线BA5CW
只看该作者 13楼 发表于: 2016-04-10
其实不要太纠结,这种事情一直在发生,这也是比赛的一部分,这里大致有几种情况:
一个是你在主叫,别人回答你,其实他听你不是很清楚,你倒是很确认能听到他,所以你录入log,他不放心,就没有录入,尤其那些个通过两次以上重复的,但最后还是not in log,通常是这种情况。我曾经回顾过所有not in log的通联录音,大概有五分之二是这种情况,我们是冤枉的。
主叫时还有一种情况,有人跟你在很近的地方呼叫,你录入的呼号其实是在回答另一个台的,这种情况通常在几个QSO以后你就能发现,但是前面录入的就已经错了,比赛的时候你没时间去细想并处理前面的log。
剩下的情况是我们的问题,和第一种情况相反,是我们在比较勉强的时候去追“稀有”台,发生我们平时常说的“诈胡”问题,那些台操作速度很快,容不得你在比赛的时候反复确认,或者是你不好意思干扰人家的节奏,发生这样的错误是我们自己在“赌博”,这种赌博是看自己判断成功概率的,靠经验来判断,首先,你不做这个台,这个系数肯定不是你的,所以之后扣掉的系数分并没有损失,你付出的代价是这个3分的QSO的两倍罚分,也就是你用6分去赌一个系数,对于BY5CD这种通联数量大的台来讲,赌博通常是值得的,当然也跟当时OP自己的判断是紧密相关的。
离线我是伍亿
只看该作者 14楼 发表于: 2016-04-10
611 Claimed QSO before checking (does not include duplicates)
600 Final   QSO after  checking reductions
       1 (0.2%) calls copied incorrectly
       0 (0.0%) exchanges copied incorrectly
      10 (1.6%) not in log
      11 (1.8%) duplicates (Removed without penalty)
       1 (0.2%) calls unique to this log only (not removed)
第一次人耳解码的比赛 错误率感人
肇庆市端州区飘到了深圳市光明区
BG2CTX QSL卡管理人:BH2RO  来卡不回
肇庆市端州区远程电台(ICOM7300+WFVIEW+GP4天线实现远程FT8和CW)
深圳市光明区移动电台(FT-450D+FC40长线天调)
对讲机只用国产100块钱的宝峰和泉盛
离线BD7pzl
只看该作者 15楼 发表于: 2016-04-12
回 BD5FFK 的帖子
BD5FFK:************************** Summary ***************************
....... (2016-04-10 11:29)
我是来认错的。翻总。我只是一个认错的民工(临时)。那些真主可能一边开心着呢。
[ 此帖被BD7pzl在2016-04-12 12:51重新编辑 ]
