  • 6495阅读
  • 27回复
激励篇之四 你好新胡安岛FT4JA [复制链接]
离线bg5bny
只看楼主 倒序阅读 0楼 发表于: 2016-04-01
早上LOFT上看到昨晚BA4DW博客上新文:
Hello from Juan de Nova ! After our trip by boat the finally anchored nearby the lagoon entrance. It took a complete day to bring all equipment ashore, dealing with low and high tides in the lagoon. We built the radio camp and antennas under extreme conditions. No wind at all during those first days. On night time, the temperature doesn't really decrease and we have thousands of mosquitoes showing up, looking for fresh meat. Hopefully the two tents are well done. The sea is close but very warm, with sharks coming very close to the sea shore. Prior to the expedition, we worked with  satellite pictures. We met on the island a configuration slightly different than expected but we have been able to set-up all antennas as planned. The field around the camp is not a soccer field but rather a place with high bushes (arbustes, broussailles in french) that makes any move a challenge ! in addition, there's spider as big a man hand everywhere. That's Juan de Nova ! Meanwhile, the lagoon and sky colors are just amazing ! We started the operation yesterday around 1230 utc. We worked with as many station as possible around the clock, depending of the operators shifts. The life camp is located a mile away from the shacks. During the first 24h, we did a bit more than 10K qso. The first batch has been send to Clublog and should be visible on the online-log soon. Conditions are not too bad. We are meting a propagation close to our predictions. We always keep an eye on the planning not to miss any opening toward the "difficult regions of the globe". We ran on 160 and 80m without any RX antennas but we should have them tonight to cover all parts of the world. The 6m beacon is active. Do not hesitate to drop a mail to our pilot if you have informations to forward to the team. We are in touch through the BGAN terminal or via radio. The team is now focused on the pile-up. Thanks for your co-operation, see you on the bands ! 73, FT4JA Team.
简单意译如下:
我们的船最终进入了泻湖的入口,在潮水的高潮和低潮之间,我们花了一整天才将所有的设备搬上岸。
我们在极端的条件下架设起了帐篷和天线。岛上没有一丝风,到了晚上,气温也没有降下来。有成千只找“小鲜肉”吃的蚊子出现。两个帐篷终于建好了。大海距离很近很温暖,只是有鲨鱼游到离岸边很近的地方,另外到处还有手掌大小的蜘蛛!这就是新胡安岛岛!不过泻湖和天空的颜色非常美。
来之前,我们按卫星照片设计了天线位置图,不过来之后有一些偏差。岛上的高高的灌木让架设天线寸步难行。
我们睡觉的地方离开电台室有1英里远,操作员们轮番值班操作电台。从昨晚1230Z开始到现在的24个小时,我们大概完成了1万个QSO,我们将把第一批LOG上传到CLUBLOG上。现在远征队专注于PILEUP上,谢谢您的合作,和您在各个波段上见!
博主点评:
1、  FT4JA远征队和VK0EK远征队所面对的是完全不一样的气候条件。VK0EK那里气温低而且风大,而FT4JA那里气温高,远征队员不少光着膀子,而且岛上没有一丝风。远征是不容易的,我深有感受。2002年去辽宁长兴岛AS151(见《长兴岛远征日记》)是11月,北方严寒,架天线时风非常大。20116月去山东芙蓉岛(见《无人岛的远征故事》20118月《专业无线通讯》杂志),岛上酷热,印象最深的有3点,第一是芙蓉岛上没有一棵树可以庇荫,尤其到了中午时分酷热难耐。第二岛上苍蝇特别多,傍晚时分,苍蝇乱飞,非常扰人,甚至还有蜈蚣出没。第三天气变化多,刮风下雨的话,帐篷也要经受考验。
2、  搬运设备上岛很累。以前几年我给上海很多HAM上大课的时候,每年都放VP8THU远征队登陆南桑德韦奇群岛时的录像,搬运设备登岛真的不容易。昨天写的激励篇二里面也提到了K5K金曼礁远征队数个人一起肩扛发电机登陆沙洲,那是相当的不易。
3FT4JA远征队睡觉的地方离开电台室1英里,也就是1.6公里,这个有利于休息。因为无人岛上要用柴油发电机发电,我自己扛了一个柴油发电机上的芙蓉岛,体会过柴油发电机所发出巨大的噪音。前几天在海南岛,我的住处和电台架设的地方也不在一个地方,相距有2公里,不过那是因为住处没法架设天线,上不了屋顶,而设电台的地方位置更好。我每天早上步行两公里,在北美传播出现前抵达电台室,白天干完活,再去电台室,等晚上欧洲传播结束后会回住处。
4、  IOTA从某种程度上比DXCC更有挑战性。因为IOTA海岛可能环境恶劣,在岛上不能久呆,DXCC中不是海岛的那些,比如像1A等可以呆在城市里的DXCC就要好一些。
我自己的海岛远征一般在海岛上每次都住上46个晚上。去了中国大陆海岸线上15IOTA海岛(BY字头下一共16IOTA,我只没有去过西沙AS-143,我说去过了中
国大陆海岸线上所有的海岛IOTA,是因为西沙远离大陆海岸线),15IOTA中,在芙蓉岛上只在帐篷里住了两个晚上,就让租的木船来接回了大陆,因为无人岛上吃住不
便。而前两天第二次在海南操作,住了十多个晚上,那里吃住方便啊。所以,对于捕捉海岛IOTA的爱好者,因为IOTA出现时间短,捕捉起来更有难度。
今天白天没有时间听,晚上8点多,在17波段上听到了FT4JA清晰的CW信号。从地理位置上说,FT4JA在东南非洲,位于马达加斯加和莫桑比克之间的海峡里。马达加斯加和莫桑比克都是比较好通的,我通过一大把这两个国家的IOTA,尤其以莫桑比克海岸线上的IOTA为多。所以,FT4JA的距离不算太远,对于我国南方7区的电台来说更近。最主要的是,FT4JAVK0EK一样,电波只要过赤道往南就可,不用通过南北极信号衰弱区。刚才呢看了一下CLUBLOGFT4JALOGBH4SYG又有4个波段上的4QSO了,再点进传播的指引看,国内已有不少人通到,可以截一张图做通讯时间上的参考。看起来,这个比VK0EK要容易不少。
FT4JA虽然没有VK0EK那么稀有,但也是好多年没有出现了。上一次远征应该是TO4E,欧罗巴岛,我通过几个波段。FT4J这个DXCC由欧罗巴和新胡安岛两个海岛组成,这次FT4JA出现在新胡安岛岛,是和欧罗巴不一样的IOTA海岛。虽然天线设备状况目前欠佳,我至少是要通一次,这样又增加一个IOTA
FT4JAVK0EK远征队们都这么不容易,一个酷暑一个严寒,而且是多年才出现一次。尽力去通吧。
[ 此帖被bg5bny在2016-04-01 08:41重新编辑 ]
离线BA7IO
只看该作者 1楼 发表于: 2016-04-01
Re:激励篇之四 你好新胡安岛FT4JA到他细li
这篇文章的点评也很优秀,而且没有什么火药点!
其实我对4DW的文章没什么,反而觉得应看到他文章中很多内容对DX新手确实有引导作用!
所以,这个就不锁了!
联系方式: 站内短信
离线bh9btm
只看该作者 2楼 发表于: 2016-04-01
非常敬佩!榜样典范!点赞!
离线我是伍亿
只看该作者 3楼 发表于: 2016-04-01
离线BH1EBF
只看该作者 4楼 发表于: 2016-04-01
离线BA7NQ
只看该作者 5楼 发表于: 2016-04-01
FT4JA确实比较好通,尤其是南方地区,操作员的水平很好,并且这次对日本照顾有加,BY电台能够沾点光。昨天傍晚在欧洲墙下搞了好久,因为听不到欧洲台,很难找FT4JA的接收频率。后来OP喊JA和ASIA ONLY之后,很快找到接收频率就轻松通上了。
离线bi4sra
只看该作者 6楼 发表于: 2016-04-01
下午6点能有机会吗?下班搞搞看。
只看该作者 7楼 发表于: 2016-04-01
太容易了,一嗓子就被我吃了。
离线sqxiaofei
只看该作者 8楼 发表于: 2016-04-01
抓紧占楼。
vk0ek听不到啊听不到,呵呵呵呵呵
BG4VRG
E-mail:sqxiaofei@gmail.com
APRS iGate:144.640
离线BA7NQ
只看该作者 9楼 发表于: 2016-04-01
回 bi4sra 的帖子
bi4sra:下午6点能有机会吗?下班搞搞看。
 (2016-04-01 13:40)
参考voacap的预测...到www.dxsummit.fi,点dx spot的呼号,在菜单上选voacap,另外,记得先设置好自己的网格地址
只看该作者 10楼 发表于: 2016-04-01
回 BA7NQ 的帖子
BA7NQ:参考voacap的预测...到www.dxsummit.fi,点dx spot的呼号,在菜单上选voacap,另外,记得先设置好自己的网格地址 (2016-04-01 14:51)
他预测晚点10米成功率99%,可能吗???
只看该作者 11楼 发表于: 2016-04-01
回  10楼(永远的FM)的帖子
第10楼永远的FM于2016-04-01 15:12发表的 回 BA7NQ 的帖子 的帖子
BA7NQ:参考voacap的预测...到www.dxsummit.fi,点dx spot的呼号,在菜单上选voacap,另外, ..
昨天就是19:57@28.490一次吃掉的。
只看该作者 12楼 发表于: 2016-04-01
回  8楼(sqxiaofei)的帖子
第8楼sqxiaofei于2016-04-01 14:49发表的:
抓紧占楼。
vk0ek听不到啊听不到,呵呵呵呵呵
vk0ek的信号一直都很好。
离线BA7NQ
只看该作者 13楼 发表于: 2016-04-01
回 永远的FM 的帖子
永远的FM:他预测晚点10米成功率99%,可能吗??? (2016-04-01 15:12)
可以可以可以可以,够八个字
离线bg6ahu
只看该作者 14楼 发表于: 2016-04-01
光头锁坏了。
BD6AHU
QQ  :  514340527
QTH : 安徽省宁国市竹峰办事处竹峰村下阳组23号
TEL: 18956382464
离线BA2Bi
只看该作者 15楼 发表于: 2016-04-02
回 BA7CK 的帖子
BA7CK:太容易了,一嗓子就被我吃了。 (2016-04-01 14:44)
刀爷说的极好 VK0小手一抖~~80m一枪搞定
[ 此帖被BA2Bi在2016-04-02 08:13重新编辑 ]
离线bd2fw
只看该作者 16楼 发表于: 2016-04-02
回 BA2Bi 的帖子
BA2Bi:刀爷说的极好[表情] 小手一抖~~80m一枪搞定[表情]   (2016-04-02 08:08)
FT4搞定了.....
[ 此帖被bd2fw在2016-04-02 08:13重新编辑 ]
张东辉
bd2fw@126.com
离线bg5bny
只看该作者 17楼 发表于: 2016-04-02
前两天有火力点,没注意到啊?
离线bg5bny
只看该作者 18楼 发表于: 2016-04-02
仔细看了一下,没什么火力点啊。
大概是我多写了一句“比这里的版主能写多了”,抱歉抱歉,言语不当。
感觉HELLOCQ比以前冷清多了,这里有两位版主,可以多写一些,原创的翻译的都可以啊。
离线BA4RF
只看该作者 19楼 发表于: 2016-04-02
回 BA7NQ 的帖子
BA7NQ:FT4JA确实比较好通,尤其是南方地区,操作员的水平很好,并且这次对日本照顾有加,BY电台能够沾点光。昨天傍晚在欧洲墙下搞了好久,因为听不到欧洲台,很难找FT4JA的接收频率。后来OP喊JA和ASI .. (2016-04-01 11:30)
低波段要比vk0ek难,不信你试试
Enjoy DXing!
宠辱不惊,看庭前花开花落;去留无意,望碧空云卷云舒
山阻石拦,大江毕竟东流去;雪辱霜欺,梅花依旧向阳开
