  • 5505阅读
  • 6回复
N1MM K3 and KX3 Macros [复制链接]
离线BA2Bi
只看楼主 倒序阅读 0楼 发表于: 2016-02-14
http://ellmore.net/na1dx/?p=469
Below is three sets of macros for the Elecraft K3 and KX3 that can be used with the N1MM contesting software. It uses a combination of memories of the KDVR and key commands. It can be made to work with just the “KY” key command. Copy and Paste the appropriate section for CW, SSB, and Digital modes. Using the built in Decoder you can get the exchange without any other decoding software. I use NaP3 2.8.8 and open the text box to capture longer strings of text.
Enjoy!
#NEW VERSION, This Function Key File requires N1MM Logger V12.02.00 or newer
#RUN ———-, Run Messages begin here —————————–
#Simple CW K3/KX3 EXAMPLE
#The space between the KY and the first character in the actual message
#is required by the K3/KX3 command syntax, as is the semicolon at the end
#of the message.
#RUN____,Run CW Message begin here —————————–
F1 CQ,{CATA1ASC SWH21;}
F2 Ex,{CAT1ASC KY {CALL} 5NN {EXCH};}
F3 TU!,{CATA1ASC KY TU CQ {MYCALL} TEST;}
F4 MYCALL,{CATA1ASC KY {MYCALL};}
F5 HIS CALL, {CATA1ASC KY {CALL}?;}
F6 RptCQ,{CATA1ASC SWH21;}{CATA2ASC SWH21;}
F7 EX2,{CAT1ASC KY 5NN {EXCH} {MYCALL};}
F8 AGN?,{CAT1ASC KY AGN?;}
F9 Nr?, {CAT1ASC KY NR?;}
F10 SEC?, {CAT1ASC KY SEC?;}
F11 Wipe,{WIPE}
F12 STOP,{CATA1ASC RX;}{CATA2ASC RX;}
#S&P ———-, Search and Pounce CW Messages begin here —————————–
F2 Ex,{CAT1ASC KY 5NN {EXCH} {MYCALL};}
F3 TU!,{CATA1ASC KY TU {MYCALL};}
F6 -,
F11 Wipe,{WIPE}
#REM ———-, Special instructions begin at end-of-file —————————–
#On K3/KX3 use straight Key to end tranmission at anytime
#RUN ———-, Run SSB Messages begin here —————————–
#F1 pulls mesage from Memories, test to verify assignments in your radio
F1 CQ,{CATA1ASC SWT21;}{CATA2ASC SWT21;}
F2 Exch,{CATA1ASC SWT31;}{CATA2ASC SWT31;}
F3 Thanks!,{CATA1ASC SWT35;}{CATA2ASC SWT35;}
F4 {MYCALL},{CATA1ASC SWT39;}{CATA2ASC SWT39;}
F5 -,
F7 REC,{CATA1ASC SWT37;}{CATA2ASC SWT37;}
F8 -,
F9 -,
F10 -,
F11 -,
#S&P ———-, Search and Pounce SSB Messages begin here —————————–
F2 TU QRZ,{CATA1ASC SWT31;}{CATA2ASC SWT31;}
F3 NA1DX,{CATA1ASC SWT35;}{CATA2ASC SWT35;}
F5 -,
F8 -,
F9 -,
F10 -,
F11 -,
#RUN____,Run DIGITAL Message begin here —————————–
F2 Ex,{CAT1ASC KY {CALL} 599 {EXCH};}
F11 Wipe,{WIPE}
#S&P ———-, Search and Pounce DIGITAL Messages begin here —————————–
F2 Ex,{CAT1ASC KY 599 {EXCH} {MYCALL};}
F6 -,
F11 Wipe,{WIPE}
离线bd2fw
只看该作者 1楼 发表于: 2016-02-14
应该发到软件版 或设备版
张东辉
bd2fw@126.com
只看该作者 2楼 发表于: 2016-02-14
KX3用这个宏感觉是很牛B,可是发了就停不下来,只能等所有发完,再就是有延迟,所以不是特别方便,所以还是要占用一个接口用拍发线比较方便;K3完全不要用这个,直接好几种拍发方法,玩得手软。
离线BA2Bi
只看该作者 3楼 发表于: 2016-02-15
回 BD8SZ 的帖子
BD8SZ:KX3用这个宏感觉是很牛B,可是发了就停不下来,只能等所有发完,再就是有延迟,所以不是特别方便,所以还是要占用一个接口用拍发线比较方便;K3完全不要用这个,直接好几种拍发方法,玩得 .. (2016-02-14 14:55)
离线bg8nud
只看该作者 4楼 发表于: 2016-02-17
这个玩不了《《《 《 》》》,没法体会比赛时变速齿轮的快感
联系方式:妖五三妖三000五六五
离线BH4rrg
只看该作者 5楼 发表于: 2016-11-08
变速也可以玩
BH4RRG       CSKC#219
常用DX信息网站:
http://new.dxsummit.fi/
http://www.425dxn.org/
http://dx-world.net/
离线bh4bqi
只看该作者 6楼 发表于: 2016-11-10
月底搞起来
