  • 5260阅读
  • 12回复
LNR LD-5 QRP收发信机 [复制链接]
离线邻家ham
只看楼主 倒序阅读 0楼 发表于: 2015-11-10
美国LNR LD-5 是目前市场上最火的QRP收发信机之一,不仅身材小(120mm X 100mm x 50mm),重量也只有一斤多,覆盖波段40m、30m、20m、17m和5m。
只看该作者 1楼 发表于: 2015-11-10
在线m6sig
只看该作者 2楼 发表于: 2015-11-10
打错字了吧?
CS: M6SIG   LOC: OL63
新浪微博已停用
不再更新的旧数据: http://t.cn/RhrIAYe
离线BG6LQZ
只看该作者 3楼 发表于: 2015-11-10
然并卵,mchf还有频谱和瀑布图呢,嘿嘿
离线BG3UBC
只看该作者 4楼 发表于: 2015-11-10
价格呢?
bg3ubc.taobao.com 也许有你需要的
离线BD6RJ
只看该作者 5楼 发表于: 2015-11-11
是啊,这等机器没啥意思!
离线黑衣
只看该作者 6楼 发表于: 2015-11-11
Transmitter
Input Power:    10.5-13.8 VDC
Output Power:    3.5 – 8W
Measurement:     SWR and Power:Numbers or Bar indicators on display
Supply Voltage:Real voltage on display
Two Modes CW:     Select Straight Key or Paddle
Receiver
Receive sensitivity:    0.2uV Preamp
Ant Preamp:    +12 dB
Spurious Response Rejection:    IMD3 -48Db/ 5W
IMD5 -43dB
ATT:    -6db
Specifications:
Frequency Range:        7000 kHz – 22 MHz 40, 30, 20, 17 and 15 meter operation
Modes:        USB, LSB, CW, CW-R, DIGITAL DATA:CAT –USB jack : CW, PSK, RTTY, SSTV – 3.5mm jack
Power:        5W output in CW / SSB
Frequency Stability:        +/- 3 ppm (Si570 defined) typical over 0-50 deg C
Supply Voltage:        10.5V min to 15V max 350mA receive and 1.5 to 2A typical in transmit
LO temp. Stability:        +/- 2.5
Antenna:        50 ohms BNC
Dual VFO
Memory:        100 memory storage per band Memorize frequency, mode, VFO’s
Built-in speaker:        0.2 watts
Dimensions:        4.724”L X 3.937”W x 1.957“H
Weight:        19oz/0.54k/excl. mic.
Iambic key:        Mode A and Mode B
Pitch CW:        Controls CW offset. The sidetone pitch is automatically set to equal the offset
Notch Filter:        Automatic Heterodyne filter for SSB from -6 to -40 db
Noise reduction:        Level of attenuation of the noise from 1 to 50- use minimal necessary
Noise Blanker:        Adjusted in the range from value 4 to 12 readings depending on interference
CW VOX:        Break in delay in CW – adjustable from 0.1 seconds to 5 seconds
CW memory keyer        Choose Iambic Mode A or B
VOICE VOX        VOX Delay adjustable from 0.1 seconds to 5 seconds
SSB VOX Level:        VOX GAIN 10-100 10 IS MOST SENSITIVE
8 Different filters (incl):        4 of 4 for CW/ SSB - 1-3 factory presets – No.4 adjustable for CW/50-1000Hz/ and SSB/250-3.6KHz
Compressor SSB:        0-20dB
SSB TX MUTE        Enable= no monitor Disable= monitor
1 Year Factory Warranty
bg2us谢文  13504197025 17307557465
体谅 Considerate 忠诚 Loyal
进取 Progressive 友爱 Friendly
适度 Balanced 爱国 Patriotic
离线黑衣
只看该作者 7楼 发表于: 2015-11-11
离线黑衣
只看该作者 8楼 发表于: 2015-11-11
网上写着,现货 575刀
离线黑衣
只看该作者 9楼 发表于: 2015-11-11
没事,上网 查了一下,不经销,不广告。
离线bg1vfd
只看该作者 10楼 发表于: 2015-11-12
不错的小东西
离线程俊威
只看该作者 11楼 发表于: 2015-11-22
很不错啊,可惜国内买不到啊!
离线BD1CM
只看该作者 12楼 发表于: 2015-12-05
不经销不广告还有价格这是要做啥?
QQ:63545177
