  • 2570阅读
  • 2回复
PX3 支持 USB 蓝牙 键盘&鼠标 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2015-10-17
MCU 1.35 / 10/12/2015
* Added USB keyboard support (see PX3_Keyboard_QuickStart.pdf for usage), most keyboards are supported except Bluetooth, Apple and those with mice.
* Added separate font for Text Decode, which can be different than system font.
* Three lines of RX text, 2 lines of TX text.
* Added 7x11 font which was introduced on the P3
* Added serial commands #USB, #BCN,#BCI, #BCL, #TXM, #TXH to support keyboard.
* Added ability CR and LF in text messages ‘\r’ for CR, ‘\n’ for LF
* Fixes wrong direction spectrum when VFO A is tuned on 2 meters.
* Fixes default values for USB keyboard values when upgrading.
* Fixes ‘smearing’ U-shaped VFO A cursor when fixed tune is enabled.
* Fixes bug with some older units that could have prevented USB from operating.
* Fixes Ctrl-Alt-R keyboard replay, removes garbage characters.
* Fixes missing characters entered with key when no keyboard attached.
* Fixes a problem with RefLvl being too high after upgrading firmware.
* Fixes an issue with display freezing when RIT/XIT was adjusted on KX3
* Fixes displayed frequency not updating when RIT was turned off.
* Limits waterfall size when text display is active, so menus are displayed correctly.
* OSB amplitude and phase serial commands added.
离线bh3nug
只看该作者 1楼 发表于: 2015-10-17
看不懂的硬伤
姓名:马雷
电话:13383366816
QQ  :82337446
廊坊市中继数据:
C4FM/模拟自动模式 438.4625   -8    88.5
欢迎各位HAM 爱好者合法使用、规范通联  。
离线罗剑
只看该作者 2楼 发表于: 2015-10-17
不错,马上准备升级
