  • 5611阅读
  • 8回复
印尼 LAPAN-A2 FM and APRS 卫星 [复制链接]
离线bm2caj
只看楼主 倒序阅读 0楼 发表于: 2015-10-16
中国南部应该可以 QSO
LAPAN-A2 FM and APRS Satellite Launched
The Indonesian amateur radiosociety ORARI report that on Monday, September
28, 2015 04:30 hours UT, theLAPAN-A2/ORARI satellite was launched from the
Sriharikota Range (SHAR) ofthe Satish Dhawan Space Centre in India.
Deployment
took place  23 minuteslater.
LAPAN-A2 is in a 650 km orbit with an inclination of 6 degrees. Ittakes
about
110 minutes to orbit the Earth and should pass over Indonesiaand other near
equatorial locations 14 times a day.
The lowinclination equatorial orbit means it will be receivable from
about30
degrees North to 30 degrees South. About a third of the world’spopulation,
over 2.4 billion people, live within the coverage area of thesatellite.
The ground station at the LAPAN Satellite Technology Centre inRancabungur,
Bogor has made contact with LAPAN-A2. There will now be a periodof
activation
and testing of all the satellite systems and it is expectedto be about
a month
before the amateur radio payload becomes available forgeneral use.
The primary aims of the mission are Earth observation usingan RGB
camera and
maritime traffic monitoring using AIS, both usingfrequencies outside the
Amateur Satellite Service.
The IARU hascoordinated these frequencies for LAPA-A2/ORARI:
• 437.425 MHz telemetrybeacon
• 435.880 MHz FM uplink
• 145.880 MHz FM downlink (5 watts)
•145.825 APRS digipeater (5 watts)
Please send reports to
yd1eee@gmail.com
Listen to a recordingof the 437.425 MHz telemetry signal at
https://chirb.it/MrgLGy
Pre-launchKeps courtesy of Dirgantara Rahadian YE0EEE
YBSAT
1 99999U 00000   15270.20393519  .00010000  00000-0  10000-3 0 00011
2 99999 006.0383 028.81880001450 317.4897 243.6033 14.00000000000018
Keplerian Two Line Elements(TLEs) ‘Keps’ for new satellites launched in
past
30 days
http://celestrak.com/NORAD/elements/tle-new.txt
Addingnew satellites to SatPC32, Gpredict and Nova
http://amsat-uk.org/2013/11/23/adding-new-satellites-to-satpc32/
Satellitetracking information
http://amsat-uk.org/beginners/satellite-tracking/
AMSAT-IDFacebook Group
https://www.facebook.com/groups/831872960241607/
OrganisasiAmatir Radio Indonesia (ORARI) in Google English
http://tinyurl.com/IndonesiaORARI
LAPAN-A2paper
http://www.researchgate.net/publication/259844289_Development_of_
Micro-satellite_Technology_at_the_Indonesian_National_Institute_of_Aeronautics_
and_Space_%28LAPAN%29
TheIARU Region 3 Conference takes place in Bali, Indonesia, October
12-16,2015
http://amsat-uk.org/2015/08/21/iaru-region-3-act-on-band-plan-satellite/
[ANSthanks AMSAT-UK for the aboveinformation]
只看该作者 1楼 发表于: 2015-10-16
只看到四个频率
离线BG6LQZ
只看该作者 2楼 发表于: 2015-10-16
离线BG2TOS
只看该作者 3楼 发表于: 2015-10-16
俺们------中国东北汉子
一直对这颗星 咬牙切齿!!
岁月如刀     我似切糕
BG2TOS@126.com
离线bm2caj
只看该作者 4楼 发表于: 2015-10-17
回 BG7MI 的帖子
BG7MI:只看到四个频率
内容来自[手机版]  (2015-10-16 17:02)
有 FM 转发器
离线BA7KW
只看该作者 5楼 发表于: 2015-10-17
今天试过,好像打不开,不知道是否跟踪的问题还是卫星没打开中继。
离线BG6LQZ
只看该作者 6楼 发表于: 2015-10-22
回  5楼(BA7KW)的帖子
第5楼BA7KW于2015-10-17 01:37发表的:
你看那卫星天线是线性的接收天线好像,仰角低,体位不好,不爽,射也白射,嘿
离线BG4WYJ
只看该作者 7楼 发表于: 2015-11-15
- Uplink 145.880Mhz tone 88,5
- Downlink 435.880 Mhz
姓名:冯斌
呼号: BG5VIM
Q Q:154231051
手机:153久二二0607久
离线胡线电
只看该作者 8楼 发表于: 2015-12-20
这个卫星现在可以用了吗?
