  • 3180阅读
  • 1回复
PigTail 和 PigRemote 新品Re-Disign上市 Hamlog73 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2015-10-05
System Overview
PigRemote is an open platform for remote station control. It's a small appliance housing an embedded Linux platform, custom audio codec, and motherboard. It comes in a custom enclosure with connections for: •Serial (RS-232) Rig Control
•Audio In and Out (No third party provider required)
•Ethernet (wired 10/100 mbps)
•Power
•USB Terminal for Linux Shell Access
The internal RF data module (included by default) makes it possible to control the Station Controller product from Sierra Radio Systems using the application PRControl on Windows, Mac, Linux(TBD), iOS, and Android(TBD).
Will PigRemote Work for Me?
Please read this section in the Pigremote User Guide to determine if PigRemote will work for you.
Piglet Redesign
Howdy Folks,
It's been a while since I've posted.  A lot of my time has been going into PackTenna and TeleSense however, I have managed to redesign the Piglet.  I've run into several issues with the Wi-Fi module that Microchip acquired from Roving Networks so I decided to stop using it.  I've switched over to using the Wi-Fi module from ACK.me Networks which is based on Broadcom WICED and very slick.
In addition to the new Wi-Fi module, the new Piglet moves to a coaxial DC power connector and right-angle DIP switches so they can be accessed from the outside of the enclosure.
In the next couple days I'll open the shop up for pre-orders of this new Piglet and they should start shipping in a week or two.
More information on what Piglet is and does:
http://pignology.net/piglet
[ 此帖被BG4DRL在2015-10-05 00:38重新编辑 ]
只看该作者 1楼 发表于: 2015-10-05
和Sierra Radio Systems 的极其相识 就看Decoder性能
[ 此帖被BG4DRL在2015-10-05 00:53重新编辑 ]
