  • 5211阅读
  • 10回复
发现一个好东西FDM-DUO [复制链接]
离线bh1tfk
只看楼主 倒序阅读 0楼 发表于: 2015-09-18
看着流口水啊
相关参数
FDM-DUO is a SDR tranceiver that offers the possibility to operate STand-alone like traditional radio or attached to a Personal Computer discovering the possibilites offered by the SDR technologies.
Stand-alone Specifications updated 6 June 2014
RX:
Freqency range: 10KHz - 54MHz
Direct sampling receiver operating @ 122.88MHz ADC: LTC2165 16bit
DDC (Digital Down Converter) FPGA Xilinx Spartan.6 family down to 192Ksps
DDC, Filter & Demodulator ARM STM32F429 floating point microcontroller
Demodulation CW, LSB, USB, AM
LSB,USB Filters selectable 1600-3100Hz Bandwitdh with 100Hz step plus 4000-5000-6000 Hz Bandwitch
AM Filter selectable from 2500 to 6000Hz with 500Hz step
CW Filters 2600Hz-1500-1000-500-300-100Hz Bw plus 4 Cw peak filters applied after 100Hz Bw to obtain an overall filter of 20Hz Bw
Noise Reduction  10 levels
Noise Blanker 10 leves
VFO A, VFO B, 199 MEMORIES with Frequency/ Alphanumeric label visualization, programmable by FDM-SW2 memory manager
Programmable BAND selections: selectable up to  20 quick recallable memories from 180 to 199
TX:
DDS AD9957  with 368.64 MHz clock
Microphone input ADC 48KHz @16bit selectable gain -12dB to +12dB
Key and Paddle input for CW operation (Iambic A e Iambic B selectable)
5W min power output from 160m to 6m, 8 W typ output @14MHz
PTT Output connector to drive external amplifiers
GENERAL:
All programmable components (ARM RX, ARM TX, Flash for FPGA, User Interface microcontroller and USB controller) are firmware upgradable
CAT input USB control interface with FTDI controller
Antenna connectors: RTX SO-239, RX SO-239
Monitor output: 0dBm SMA to be used as test equipment allow the use  as a Digital RF Generator
LCD Backlight RGB programmable, depending on function can change the colour (RX, TX , PC remote control)
10MHz Reference input connector: SMA
Power supply: 2.1mm DC Plug 13.8VDC RX consumption 500mA typ (13.8V) TX: tbd
Size: Witdh 180mm (7.00") x Depth 155mm (6.10") including Knob and connectors or 130mm (5.10") only enclosure  x Height 70mm (2.75")
Weight: 1.2Kg (2.4 lb), shipment package 2.2Kg (4.85 lb)
PC mode operation with FDM-SW2 software specifications updated 6 June 2014
Up to 9 simultaneous receivers combination ( 1 on center frequency stand alone, 4 FDM-SW2 in fist 192kHz channel and 4 in the second 192kHz channel
Each receiver on FDM-SW2 have a dedicated Audio Channel and a dedicated CAT to be usable from external application with Visrtual serial ports and Virtual Audio Cables
Selectable Band configuration from 192kHz to 6MHz DDC bandwith  (192,384,768,1546,3072,6144Ksps) 2 channel 192Ksps, 2 channels 384Ksps
RX and TX SPLIT mode operation:  VFO A for RX while VFO B used for TX (with FDM-SW2 simple click operation to change TX frequency)
CW skimmer integration management (DX Spot visualization & tuning capability)
Direct digital Modulation using USB soundcard based on CMedia chipset digitally interfaced with ARM floating point microcontroller and DDS
离线bi3nmv
只看该作者 1楼 发表于: 2015-09-18
英语一个字不认识啊
离线bh1tfk
只看该作者 2楼 发表于: 2015-09-18
简单翻译一下
fdm-duo是一台SDR收发器
接收:
频率范围:10KHz - 54MHz
直接采样接收机操作”122.88mhz ltc2165 16bit ADC:
DDC(数字下变频器)的Xilinx的Spartan FPGA。6的家庭到192ksps
DDC,滤波和解调器臂stm32f429浮点控制器
支持模式CW,LSB,USB,AM
LSB,USB过滤器可选1600-3100hz 带宽与100Hz步加4000-5000-6000赫兹带宽
AM滤波器可选2500和500Hz的步进频率
CW滤波器2600hz-1500-1000-500-300-100hz体重加4连续峰值滤波器应用在100Hz BW获得20Hz BW整体过滤器
降噪分为10级
噪声抑制10级
VFO,VFO B,199的回忆与频率/数字标签的可视化,通过fdm-sw2内存管理程序
可编程的波段选择:可选择多达20个快速恢复记忆从180到199
发射:
368.64 MHz的时钟DDS AD9957
麦克风输入ADC 48kHz 16bit可选增益12dB @ + 12dB
支持自动键
最小输出功率5W在160~6m,典型值8 W输出@ 14MHz
PTT输出连接器驱动外部放大器
综述:
所有可编程元件(ARM RX,TX,Flash FPGA,单片机和USB控制器的用户界面)可以进行固件升级
CAT输入USB控制接口由FTDI控制
天线:RTX so-239,RX so-239
监视输出:0dBm SMA作为试验设备允许作为数字射频发生器的使用
LCD背光RGB可编程,根据功能可以改变颜色(RX,TX,PC远程控制)
10MHz参考输入连接器:SMA
电源:DC插头13.8vdc 2.1mm RX消费500mA的典型(13.8V)TX:待定
尺寸:180mm X155mm包括旋钮和连接器或130mmx70mm(不含突出物)
重量:1.2kg(2.4磅),出货包装2.2kg(4.85磅)
多达9个同步接收机组合(1个在中心频率独立,在第二192kHz的拳头192kHz的通道和4通道4 fdm-sw2
在fdm-sw2每个接收器有一个专用的音频通道和一个专用的猫可以从visrtual串行端口和虚拟音频电缆的外部应用程序
从6MHz带宽可选带192kHz DDC配置(192384768154630726144ksps)2通道2通道192ksps,384ksps
RX和TX拆分模式操作:VFO一RX而VFO B用于TX(与fdm-sw2简单的点击操作来改变发射频率)
连续式集成管理(DX现场可视化与调整能力)
采用基于cmedia芯片的数字接口与ARM微控制器和USB声卡的浮点DDS直接数字调制
离线bg5bdt
只看该作者 3楼 发表于: 2015-09-18
只看该作者 4楼 发表于: 2015-09-18
离线BD7IWW
只看该作者 5楼 发表于: 2015-09-18
最关键的接收性能不说,估计指标不高吧。
离线BI7JSE
只看该作者 6楼 发表于: 2015-09-18
己有几台在国内用了, 9xe 在出
BI7JSE
深圳市福港路200号
离线bg9xe
只看该作者 7楼 发表于: 2015-09-18
我这有一台,要的说话,有惊喜
离线BD6RJ
只看该作者 8楼 发表于: 2015-09-19
离线conjuring
只看该作者 9楼 发表于: 2015-09-19
万把块的东西,乐啥乐。
QQ:2795 022三6
离线BG6JJI
只看该作者 10楼 发表于: 2015-10-02
这机器可玩性极强
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
