  • 8181阅读
  • 17回复
WAE 比赛中N1MM软件发射和接收 QTC [复制链接]
离线BH7PFH
只看楼主 倒序阅读 0楼 发表于: 2015-08-08
这个是N1MM帮助文件
96. WAEDC contest CW /SSB
in-edit The WAEDC Contest can be configured for European stations and non-Europeanstations.
  • Window: Select Log typeLog Type:
  • CW: WAECW
  • SSB: WAESSB
Sent Exchange: 001
The callsign in the Station Information dialog ( >Config >ChangeYour Station Data >Call ) determines if you are a European station or anon-European station.
96.1. Introduction to WAE DX CW/SSB - based on an articleoriginally written by Franki, ON5ZO
WAE has something no other contest has, that you'll either love or hate - theexchange of information on past contacts in the contest, or QTC. Except in WAERTTY, a QTC is a piece of traffic that can only be sent from stations outside EUto EU stations. EU stations will beg to get them. Why? Simply because for bothsides each QTC is added to the QSO total. If N1MM makes a QSO with ON5ZO, thenthey both get 1 point for the QSO. If they decide to exchange 10 QTCs duringthis QSO, they each earn 11 points, 1 QSO + 10 QTCs. If, after the contest,ON5ZO made 300 QSOs, during which he got 500 QTCs, his total count will be 800,multiplied by the number of multipliers. Each QTC has three main parts - time, call and received serial number of aQSO from the DX (nonEuropean) station's log. Suppose that N1MM logged ON5ZO at0123UTC, and ON5ZO gave '012' as his serial number. Later in the contest, N1MMcan send the QTC to 9A7P, for example.: He would send 0123 ON5ZO 012.
The rules say that a DX station can only send a total of 10 QTCs to a EUstation, and that previous QSOs with the receiving station cannot be included inthe batch of QTCs sent. Each QSO can only be sent once as a QTC, so a DX stationcan never have more QTCs sent than QSOs logged. A EU station however, can havemany more QTCs than QSOs, as each non-duplicate QSO can yield up to 10 QTCs.
A DX station can choose to send 10 QTCs to a single recipient during a singleQSO, or piecemeal. In addition, QTCs do not have to be exchanged only during anon dupe QSO. Suppose that early in the contest, ON5ZO is running, and N1MMcalls on 20m. They have a regular QSO and exchange serial numbers. ON5ZO asks'QTC?' but N1MM wants to make some QSOs first, so he declines. Towards the endof the contest, N1MM is running on 20m and ON5ZO finds him, ON5ZO sees that N1MMis a dupe because they QSO'd at the beginning of the contest. However, theydidn't pass QTCs, so ON5ZO asks 'QTC? de ON5ZO'. N1MM sees that they have workedbut indeed: there were no QTCs sent then, and N1MM is now eager to send 10 ofhis QSOs as QTCs. They do it, and both go away happy. The second QSO doesn'tcount, of course, but the QTCs do. Each set of QTCs must be numbered. The sending station initiates the seriesof QTCs with a "batch" number like 'QTC 11/10', which means that it is the 11thbatch sent by the DX station, and there will be 10 QTCs in the batch.
All this sounds terribly complicated, doesn't it?. Fortunately, N1MM Loggertakes care of all the clerical work. Let's look at how it works in detail,starting with
96.2. WAEfrom Europe (ON5ZO as an example)
in-edit
XXXSubject to change as code developsXXX
After completing the QSO, where both stations exchange serial numbers, ON5ZOgoes into QTC mode by pressing Ctrl+Z. In CW, the program can be set up so thatthis triggers the program to send 'QTC?' to ask the other station if he wants tosend QTCs. This is controlled by a menu option "Config > WAE > Ctrl+Zsends QTC? automatically (EU stations, Run mode only)". In SSB, he might uncheckthis option and ask the other station "Do you have QTCs for me?" before pressingCtrl+Z. Either way, pressing Ctrl+Z opens a Receive QTC window like the onebelow:
The cursor starts in the QTC header field, and ON5ZO logs the QTC batchnumber sent by the other station, such as '12/10'. If he only types the batchnumber without the forward slash and count, the program will assume the count is10. ON5ZO then hits Space, which sends QRV in CW and moves the cursor to thefirst QTC window. In SSB he would have to tell the other station he is ready byusing the microphone. Each time he copies a part of the QTC, he presses Space tomove into the next box. If he doesn't copy the QTC, in CW he can click on thenumbered "Agn" button for that QTC to ask the other station to send it again.When the QTC is received and logged, he presses Enter or clicks on the "Cfm"button and the program logs the QTC and in CW, sends a confirming 'R' (orwhatever has been configured using the "Config > WAE > WAE Received QTCConfirmation" menu item), so that the other station knows ON5ZO got it OK and hecan start transmitting the next QTC.
When the series of QTCs is copied, ON5ZO presses the Exit button, the programsends a TU message and closes the QTC window, returning to normal QSO mode.
Sometimes when conditions are poor or deteriorating or QRM is gettingheavier, it is not possible to complete a batch of QTCs. If you want to startthe batch over again, you can use the Clear button to clear the window and startfresh. Or, if you click on the Cancel button or press the Esc key, the QTCprocess is aborted. Note that both Clear and Cancel leave any QTCs that havealready been logged still in the log. Depending on the circumstances, you caneither leave those QTCs in the log, or if necessary (for example, if you startover and find you have duplicated some QTCs in the log) you can deleteindividual QTCs in the Log window.
You can use Alt+W to wipe the current line, or Ctrl+Q to place the Entrywindow into Quick Edit mode to edit a QSO or QTC. Normally the program willprevent you from logging an invalid QTC (non-number in the time or serial numberfields, or an invalid call sign). Whenever the Agn button is highlighted, youcan override this validity checking and force-log the QTC using Alt+Enter,Alt+Space or Alt+Tab.
Sometimes the number of QTCs in the header was miscopied, and the number ofQTCs actually received is smaller or larger than the number originally expected.You can use Ctrl+A to remove the last blank line from the QTC window and reducethe count in the QTC header (and in logged QTCs in that batch) by 1. Or, you canuse Alt+A to add a new blank line and increase the count in the header and thelog (up to a maximum of 10).
Note: Sometimes DX stations don't repeat the two digits representing the hourin the time part of the QTC. They just send the minutes, because the hour is thesame for a bunch of QSOs. For example, the DX station might send '1134' for thetime of the first QTC, but then send 35 and 36 for the next two.
When copying QTCs at 36 wpm or faster, you don't have the time to do anythingbut type what you copy. If you copy two numbers, and the next character is aletter, you usually know you need to press Space and begin typing the callsign.N1MM Logger will automatically add the two hour digits to your log. This doesn'twork so well with number prefixes like 5B or 4Z unless the sending station iscareful with his spacing, and we'd welcome suggestions on a better approach.
The QTC process works in either Run or S&P mode. The same keystroke,Ctrl+Z, turns it on and off (in case you need to abort QTC mode).
96.3. WAE from theDX (non-Europe) side
The process is even easier from the non-European (DX) side. If you wantto send QTCs, you simply press Ctrl+Z. If you've forgotten to log the QSO first,Ctrl+Z will do it for you. A pop-up window opens, asking you how many QTCs youwant to send to the EU station:
The pop-up defaults to the maximum number you can send that station, but ifyou want to send fewer, you can just type in the new number over the old one.When you exit from the pop-up by hitting Enter or pressing OK, the QTC header issent to the other station, and a QTC window opens up, populated with all theinformation you need to send:
Once the other station indicates he's ready, usually with 'QRV' in CW, youcan press Enter to send each QTC in turn, waiting for the other station toacknowledge after each QTC. The following screen shot shows the window after the5th QTC has been sent - note that the highlight is on the "Snd 6" button,because that is the one that will be sent if you press Enter at this point:
If he asks for a repeat, you can press the = key, or you can click on the"Snd" button for the previous QTC, i.e. the one that was not yet received andacknowledged. If he asks for a repeat of only part of the QTC, you canright-click on one of the three parts to re-send it, or you can press the 1, 2or 3 keys to re-send just the time, call sign or serial number respectively.Once all of the QTCs have been sent and the European station acknowledges theQTC batch, you click on the Exit button to end the batch and log the sent QTCs.The Clear and Cancel buttons work the same way as for a station in EU.
96.4. Both sides
After you enter the callsign of the other station in the entry window, a newline in red type will appear below the buttons in the Entry Window to tell youthe QTC status.
This line will appear regardless of whether you have worked the station yetor not. The left-most number tells you how many QTCs you have already exchangedwith that station. The next number tells you how many QTCs you still haveavailable to send to that station (up to the maximum of 10), and the last numbertells you the total number of unsent QTCs in your log.
The Entry Window and the Bandmap window contain visual cues about the QTCstatus of stations spotted in the bandmap. A special color scheme for spottedcall signs has been implemented, as follows (colors are configurable - these arethe defaults):
RED: the station is a newmultiplier on this band (single multiplier color, the same as in other contests)
GREEN: this is a new station on this band,and you can also exchange QTCs with him (you have not yet exchanged 10 QTCs withthis station) (in other contests, this is the double multiplier color, but thereare no double mults in WAE)
BLUE: this is anew station on this band, but you have no more QTC's available that can beexchanged with this station (you have already exchanged 10 QTCs, or else you areboth EU stations or both DX stations, so you cannot exchange QTCs) (normal QSOcolor in other contests)
BLACK: this station is a dupe on this band, but youstill could exchange QTCs with him for QTC points (this color is the "Color of aQTC callsign in the WAE contest" color in the Manage Skins, Colors and Fontswindow)
GREY: dupe, and there are no QTCthat can be exchanged - this station is non-workable for any kind of credit, sojust pass him by (the same as in other contests)
[ 此帖被BH7PFH在2015-08-08 07:36重新编辑 ]
BH7PFH
离线bd3mv
只看该作者 1楼 发表于: 2015-08-08
真的看不懂
离线bg3upa
只看该作者 2楼 发表于: 2015-08-08
蝌蚪
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
离线BA7QT
只看该作者 3楼 发表于: 2015-08-08
无须设定,按ctrl+z进入qtc模式,n1mm logger会自动处理,只须待对方确认后,即可按enter发出下一个qtc,否则可以用alt+enter将上一组重发,直至对方确认为止。
上述为cw赛,若是ssb,则请开尊口。ssb的穿透能力比cw小得太多了
BEST 73!   DE BA7QT/LIAO
QSL MGR:W3HNK
离线我是伍亿
只看该作者 4楼 发表于: 2015-08-08
看得我头疼
旧版N1MM也头疼
离线BD5XX
只看该作者 5楼 发表于: 2015-08-08
无聊的发呆
EX:BD5SO、BG5RSO
Email:bd5xx@foxmail.com
离线我是伍亿
只看该作者 6楼 发表于: 2015-08-09
EU台问你QTC?问你卖不卖QTC的时候
你说卖 于是发QTC (顾客序号)/(货的数量) QRV?就是问对方你准备接货了么
对方说OK或者QRV
于是你一条一条的把货物送出去
没听清楚你再发一次
发完为止
肇庆市端州区飘到了深圳市光明区
BG2CTX QSL卡管理人:BH2RO  来卡不回
对讲机只用国产100块钱的宝峰和泉盛.
离线BG9OF
只看该作者 7楼 发表于: 2015-08-09
太及时了,之前怎么也没找出来QTC的功能,谢谢武哥!
离线bg9mfy
只看该作者 8楼 发表于: 2015-08-19
我的姥姥,太复杂了。
离线BA7QT
只看该作者 9楼 发表于: 2015-08-20
不复杂的,很简单的,我是只管卖,不买。
QSL MGR:W3HNK
离线bg4hyk
只看该作者 10楼 发表于: 2015-08-20
试用过一次,用NIMM,对方问TQC, 回答N,只是极强的信号,回答Y,记得只是按回车,卖出去就完了。
欢迎加入 快乐无线电GLHAM 224850911QQ群
离线我是伍亿
只看该作者 11楼 发表于: 2015-09-10
准备SSB卖QTC 不知道效果如何
肇庆市端州区飘到了深圳市光明区
对讲机只用国产100块钱的宝峰和泉盛.
离线BH4AYG
只看该作者 12楼 发表于: 2015-09-12
传播一泡污啊。。。肿么玩
柔若无骨二八子,
顺天应时游太虚;
如何觅取何首乌,
水远山高仙家有。
呼号:BH4AYG
QTH:上海徐家汇
QQ:34601046
离线我是伍亿
只看该作者 13楼 发表于: 2015-09-12
今天搞了24个台
卖了23个
挺有意思的
离线BH1EBF
只看该作者 14楼 发表于: 2016-08-09
离线BA7QT
只看该作者 15楼 发表于: 2017-08-08
一年一度,顶顶。
QSL MGR:W3HNK
离线BA7QT
只看该作者 16楼 发表于: 2018-08-11
2018年,继续顶!
QSL MGR:W3HNK
只看该作者 17楼 发表于: 2018-08-12
刚刚听了一下,应该又开始啦,在交换QTC了
