  • 6361阅读
  • 19回复
今年夏天中国要发射多枚业余卫星 [复制链接]
离线BD4NU
只看楼主 倒序阅读 0楼 发表于: 2015-05-27
China Set to Launch Several Amateur Radio Satellites this Summer
05/26/2015
CAMSAT has announced that the CAS-3 amateur satellite system is nearing completion, and six Chinese amateur satellites will be launched in mid-July.
“All six satellites are equipped with substantially the same Amateur Radio payloads, a U/V mode linear transponder, a CW telemetry beacon and an AX.25 19.2k/9.6k baud GMSK telemetry downlink,” the CAMSAT announcement said. CAMSAT said that each Amateur Radio complement has the same technical characteristics, but will operate on different 70 centimeter uplink and 2 meter downlink frequencies.
CAMSAT said it has worked closely with DFH Satellite Co Ltd, a Chinese government aerospace contractor, to complete the project. “All the satellites are currently conducting final testing and inspection,” CAMSAT added. Four of the satellites are described as “microsatellites,” while three are listed as CubeSats.
CAMSAT said a Long March-6 rocket will carry the satellites into orbit. The launch will take place at Taiyuan Satellite Launch Center. CAS-3A will have sun-synchronous orbits of about 450 km, while the other satellites have sun-synchronous orbits of about 530 km.
“The launch will carry total of 20 satellites,” CAMSAT said. “Three other satellites named as CAS-3G, CAS-3H, and CAS-3I involved in Amateur Radio from other agencies of China will share the same launch.”
CAMSAT said it was assisting the Chinese government with frequency allocation and coordination and would announce additional details.
CAS-3A (microsatellite architecture)
Dimensions: 400×400×400 mm (20 kg)
Stabilization: Three-axis stabilization system with its +Y surface facing Earth
Antenna: Deployable antenna, one 0.25 λ monopole VHF antenna on +Z side and one 0.25 λ monopole UHF antenna on the –Z side, close to the each edge of satellite body
Call Sign: BJ1SB
CW Telemetry Beacon: 50mW, 22 WPM
U/V Mode Linear Transponder: 100 mW, 20 kHz bandwidth, inverting
AX.25 telemetry: 100 mW, 19.2k/9.6k baud GMSK
CAS-3B, CAS-3C and CAS-3D (microsatellite architecture)
Dimensions: 250×250×250 mm (9 kg)
Stabilization: Tree-axis stabilization system with its +Y surface facing Earth
Antenna: Deployable antenna, one 0.25 λ monopole VHF antenna on the +Z side and one 0.25 λ monopole UHF antenna on the –Z side, close to the each edge of satellite body
Call Signs: BJ1SC (CAS-3B), BJ1SD (CAS-3C), BJ1SE (CAS-3D)
CW Telemetry Beacon: 50 mW, 22 WPM
CAS-3E and CAS-3F (CubeSat architecture)
Dimensions: 110×110×110 mm (1.5 kg)
Stabilization: Spinning stabilization using permanent magnet torquer
Call Signs: BJ1SF (CAS-3E), BJ1SG (CAS-3F)
AX.25 telemetry: 100 mW, 9.6k baud GMSK
Meanwhile, AMSAT News Service has reported via Mineo Wakita, JE9PEL, that Beijing will be launching other satellites carrying Amateur Radio payloads in July. According to AMSAT-UK, the CAS-2A1 and CAS-2A2 satellites will be combined into a binary star system for Amateur Radio communication and education. “There will be a radio link between the two satellites when the satellites are in suitable positions in their orbits, so that Amateur Radio communication coverage can be extended,” AMSAT-UK reported on its website.
CAS-2A1
Dimensions: 270×270×250 mm
2 meter CW telemetry beacon, 100 mW
2 meter AX.25 digital telemetry beacon, 500 mW
2 meter FM voice beacon, 500 mW
U/V mode linear transponder: 50 kHz bandwidth, 500 mW
L/S mode linear transponder: 200 kHz bandwidth, 320 mW
U/V mode APRS repeater
CAS-2A2
70 centimeter CW telemetry beacon, 100 mW
70 centimeter AX.25 digital telemetry beacon, 500 mW
13 centimeter CW telemetry beacon, 200 mW
V/U mode linear transponder, 500 mW
LilacSat-2 (Harbin Institute of Technology)
Dimensions: 20×20×20 cm (11 kg)
Uplink: 145.825, 145.875 MHz
Downlink: 437.200 MHz beacon, 437.225 MHz FM/APRS
Other spacecraft include Tiantuo-3 (TT-3), from the National University of Defense Technology, and ZDPS-2, a nanosatellite mission of the Microsat Research Center, Zhejiang University. — Thanks to CAMSAT, AMSAT News Service, Mineo Wakita, JE9PEL, and AMSAT-UK
信息污染  是指媒介信息中混入了有害性、欺骗性、误导性信息元素,或者媒介信息中含有的有毒、有害的信息元素超过传播标准或道德底线,对传播生态、信息资源以及人类身心健康造成破坏、损害或其他不良影响。
离线BH4IWK
只看该作者 1楼 发表于: 2015-05-27
只看该作者 2楼 发表于: 2015-05-27
离线BD4NU
只看该作者 3楼 发表于: 2015-05-27
离线BD7NL
只看该作者 4楼 发表于: 2015-05-27
离线bg6ljj
只看该作者 5楼 发表于: 2015-05-27
应该是从南美发射的吧?
离线BD6AHP
只看该作者 6楼 发表于: 2015-05-28
写得很清楚,7月,太原,长征6。
离线BA7KW
只看该作者 7楼 发表于: 2015-05-28
兴奋,维护一下天线,打卫星
离线BH1IEO
只看该作者 8楼 发表于: 2015-05-28
苦苦等待 期待中。
离线BH4IWK
只看该作者 9楼 发表于: 2015-05-28
回  4楼(BD7NL)的帖子
第4楼BD7NL于2015-05-27 20:28发表的:
上去能用几天
每个6天,写的清楚
离线BG8DIV
只看该作者 10楼 发表于: 2015-05-28
好家伙
动手动脑 脑动手动
BG8DIV  I3699OI9I58
离线BG9AGZ
只看该作者 11楼 发表于: 2015-05-29
我仔细思索这个消息,是国外的小道消息吧?还有待验证,感觉国内没那个能力和需求弄上去,不然早就CCTV了。
离线bh1tln
只看该作者 12楼 发表于: 2015-05-30
耐心等待,蛤蟆们掩不住的兴奋吧
离线bd7itx
只看该作者 13楼 发表于: 2015-06-11
   7月吗?
只看该作者 14楼 发表于: 2015-06-15
兲朝的事都要外电消息~
离线BG6LQZ
只看该作者 15楼 发表于: 2015-07-29
已经7月末了 还没有消息,我火急火燎从年初忙到年中搞来了旋转器,好吧,等S9发货再发射吧
呼号:BG6LQZ
QTH:河南省南阳市
Phone:155叁久久888伍六
离线bh1sey
只看该作者 16楼 发表于: 2015-07-29
正好hackrf到货了,期待阿。
离线BA7NQ
只看该作者 17楼 发表于: 2015-08-03
一口气六个
离线bg3vp
只看该作者 18楼 发表于: 2015-08-05
发上去怎么才能用6天?,,电池失效?靠太阳能电池可以在有光照的情况下,,用个几年吧
广泛结交无线电爱好者:cool:
火腿入门
www.qsl.net/bg3vp
bg3vp@163.com
54691151@qq.com
QQ:54691151
山西太原
离线BD7OXR
只看该作者 19楼 发表于: 2015-08-07
回 BA7KW 的帖子
BA7KW:兴奋,维护一下天线,打卫星 (2015-05-28 04:43)
我一直期待 到电厂来玩 EME 和卫星通联
呼号:BD7OXR (EX  BH7OXR)
电话:幺山漆幺幺山山吾林吾酒
地址:QRZ.cn qrz.com
Q Q:1885639
WX:BD7OXR
邮箱:bd7oxr@126.com
