  • 6451阅读
  • 9回复
APRS.FI 被谷歌墙了  哈哈==》已恢复大部分功能 [复制链接]
离线BG6LQZ
只看楼主 倒序阅读 0楼 发表于: 2015-04-03
你没看错,被谷歌禁止使用API,哎还有其他家不?
[ 此帖被BG6LQZ在2015-04-04 15:28重新编辑 ]
呼号:BG6LQZ
QTH:河南省南阳市
Phone:155叁久久888伍六
离线bh4rxp
只看该作者 1楼 发表于: 2015-04-03
一样!
离线BG2RKH
只看该作者 2楼 发表于: 2015-04-03
离线我是伍亿
只看该作者 3楼 发表于: 2015-04-03
楼主火星回来了?
离线BG2CQO
只看该作者 4楼 发表于: 2015-04-03
离线BH1IEO
只看该作者 5楼 发表于: 2015-04-03
APRS.FI本来就是辅助,主要的还是靠设备玩。看不看无所谓了。
燕  巴  虎  开 始 玩 户 外 了
E-mail:1162846706@qq.com
QTH :未来火星人
Echolink Links Node:15668
WiRES-X Node ID:14231
WiRES-X Room:24231
ALLSTAR Links Node:28559
Echolink brought us into the 21st century
APRS:BH1IEO Home IGATE/Yaesu 1DR-5/Kenwood D72E-6/LM3G Mobile-7/GPRS APRS Mobile car-8/Yaesu 400DR Jeep Mobile-9/Mobile phone-12
只看该作者 6楼 发表于: 2015-04-03
aprs.hellocq.net
离线bi4rmd
只看该作者 7楼 发表于: 2015-04-04
切换到osm可以吗
离线BG6LQZ
只看该作者 8楼 发表于: 2015-04-04
回  3楼(我是伍亿)的帖子
第3楼我是伍亿于2015-04-03 19:47发表的:
楼主火星回来了?
火星好热,还是地球舒服,还有妹纸微博喊吃饭
离线BG6LQZ
只看该作者 9楼 发表于: 2015-04-04
回 bi4rmd 的帖子
bi4rmd:切换到osm可以吗 (2015-04-04 00:57)
好像不行了
具体看APRS.FI管理员关于这个问题的回复
http://forums.qrz.com/showthread.php?474582-APRS-FI-Down-with-Google-Map-Issue
“aprs.fi's Google Maps should be back soonish. I see the speculation for
the reasons is already getting on.
Google had noticed that aprs.fi has integrated support for OSM map tiles
*and* Street View. I hadn't noticed that the combination of Street View on
top of anything else than Google Maps is forbidden according to the Maps
API Terms Of Service document. Or I had just forgotten about it when
implementing OSM or Street View (there was probably a year or two of time
in between..).
They had sent me a few emails to warn about the unapproved configs,
starting on 5th of March. I had moved away from reading emails regularly
in Gmail a long while back, but forgotten to arrange for these emails from
Google APIs to go to my primary email address. Silly me.
Oh well. OSM support is disabled for now, and I notified Google that
aprs.fi is again compliant with the terms. Should be back soonish.
I might put OSM support back later, and remove Street View instead, as OSM
is probably more useful in practice at some areas (although admittedly
less visual and "cool"). Or maybe make some sort of arrangement where
Street View only works if you have Google Maps selected instead of OSM.
Have to check with the Google folks if that's OK.
- Hessu”
呼号:BG6LQZ
QTH:河南省南阳市
Phone:155叁久久888伍六
