  • 3938阅读
  • 6回复
Elecraft KX3 next KX4?? [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2015-01-31
Modern digital modes require high stability oscillators,
especially at higher frequencies or when using the KX3 to control a UHF transverter.
I wonder if the following could be explored in a "KX4":
1) Complementary designs for Elecraft compatible UHF and microwave transverters (either made by Elecraft or made for Elecraft by a microwave group.
2) Change to a Si5351a oscillator with external crystal and TXCO or OXCO.
3) Autocalibration to a known stable source (such as GPS).  Hans Summers has this implemented in his QRSS transmitters (I do not know how the time frame for correction compares to the higher stability of a TXCO or OXCO , anyone work in this area)?
4) Introduce a small device, PX3 size, that could handle Keplerian calculations to run a Alt-Az antenna for satellites or EME.
-Just some wild thoughts of where to take the best receiver on the market.
[ 此帖被BG4DRL在2015-01-31 09:52重新编辑 ]
离线7月7小雪
只看该作者 1楼 发表于: 2015-01-31
离线BG6JJI
只看该作者 2楼 发表于: 2015-01-31
还没卖够本呢!急啥!
离线BG6JJI
只看该作者 3楼 发表于: 2015-01-31
其实,把彩屏USB口挪过去就行了
离线罗剑
只看该作者 4楼 发表于: 2015-01-31
确温补是一个小问题
离线bd2bh
只看该作者 5楼 发表于: 2015-01-31
稳定度更高的“温补晶体”或与GOS同步的校准的发射机将会出现,但不要一定是KX4,也不一定由Elecaft生产,愿望良好。
离线BA2Bi
只看该作者 6楼 发表于: 2015-02-01
joke
