  • 3919阅读
  • 1回复
wsjt-suite WSJTX_v1.5..SVN r4831 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2015-01-17
只看该作者 1楼 发表于: 2015-01-20
BUILD INFORMAITON
.Build Date: 17-DEC-2014, v1.0.10
.Builder: Greg, Beam, KI7MT <ki7mt@yahoo.com>
APPLICATION INFORMTION
.WSJT-v10.0..SVN r4826
.WSPR_v4.0...SVN r4825
.WSJTX_v1.5..SVN r4831
.WSJTX_RC3...SVN r4783
.WSPRX_0.9...SVN r4721
.MAP65_v2.5..SVN r4729
.Hamlib3.....BUILD Date: 17-DEC-2014
If you have PROBLEMS with the WSJT-Suite, please REPORT them
to the WSJT-Devel List: < wsjt-devel@lists.sourceforge.net >
WSJT Development Team
CHANGE-LOG
17-DEC-2014 WSJT-Suite-1.0.10.Win32.exe
* Built with JTSDK-2.0.0-B2
* Updated hamlib3 build to 17-DEC-2014
* WSJT-X 1.5 was updated by Bill (G4WJS)
* Makefiles updated for WSJT & WSPR by Greg (KI7MT)
* MAP65 Minor GUI Widget updates from Joe (K1JT)
* No updates to WSPR-X
09-DEC-2014 WSJT-Suite-1.0.9.Win32-exe
* Updated WSJT-X 1.5-devel to r4784
* Updated WSJT-X 1.4 RC3 to r4783
* Bill (G4WJS) updated the NSIS installer MD5 check functions
* Updated Hamlib3 package to 05-DEC-2014version
06-DEC-2014 WSJT-Suite-1.0.8.Win32-exe
* Rebuilt all 6 Applications
* WSJT-X was updated by Bill ( G4WJS ), mostly for Mac OSX
* Changed Python Pillow version to v2.3.0 ( affects WSJT & WSPR )
* Added missing Util Batch file for WSJTX
05-DEC-2014 WSJT-Suite-1.0.7.Win32-exe
* MAP65 Add correct resource files to install bin dir
05-DEC-2014 WSJT-Suite-1.0.6.Win32-exe
* Added WSJT-X Release Candidate 1.4 RC3
* Rebuilt all 5 applications due to build script changes
* MAP65 Added missing .dat and runtime dlls
* WSPRX Added missing .dat files
* WSJT build updated due to Makefile.jtsdk2 changes
* WSPR build updated due to Makefile.jtsdk2 changes
* No JTSDK Base Packages Changes were made
04-DEC-2014 - WSJT-Suite-1.0.5.Win32-exe
* Changed Installer Name to add version numbers
* Old name WSJT-Suite-<date> - New name WSJT-Suite-x.x.x-Win32.exe
* Added kvasd.exe.md5 v1.12 to WSJTX Folder
* Fixed MAP65 Shortcut Link
* Added libgcc_s_dw2-1.dll to MAP65 and WSPRX folders
* Remove WSPR-X default .INI file
* No Changes To Application Versions
