  • 4360阅读
  • 11回复
逛到的三工器和bpf组合,一般用途差不多了。 [复制链接]
离线罗剑
只看楼主 倒序阅读 0楼 发表于: 2015-01-15
这个三工器和bpf的组合成品算是外面比较便宜的啦。
http://www.dunestar.com/store/HF-Triplexer-Filter-pid-6.html
BG8PD,ex BG8OKU
贵州省贵阳市解放路51号盛世华庭二层(快递仅工作日收货)
择善而行,潇洒自在
BG8OKU#chinaham.org
离线罗剑
只看该作者 1楼 发表于: 2015-01-15
The 333 Triplexer is based on the work of K6KV as presented in the June 2010 QST Magazine article "HF Yagi Triplexer Especially for ARRL Field Day".
Applications range from Field Day, to Emergencies, to Contesting, to DXpeditions. The Triplexer effectively makes one tower and a triband yagi into 3-towers and 3-yagis, while adding only a 3X5X7 inch aluminum box, weighing less than 2 pounds to your equipment list. Works well with Trap Dipoles and Verticals too.
No adjustments required. Just place in-line between transceivers, Bandpass Filters, and antenna and you are ready to go.
SPECS:
Inputs & Output: 50-ohms nominal.
Connectors: UHF type.
Insertion Loss: 0.3-0.4dbTypical.
Attenuation to adjacent band: typically 12 dB in addition to that of the
bandpass filters.
Power: 200W PEP intermittent.
M333: 10M 28.0-28.7, 15M 21.0-21.45, 20M 14.0-14.35
M333v2: 160M 1.8-1.9, 80M 3.5-3.85, 40M 7.0-7.3
VSWR CONSIDERATIONS: The better the VSWR, the less likely you will be to experience difficulties. Every effort should be made to maintain minimum VSWR.
CONSTRUCTION:  Aluminum Enclosure. Dimensions: HWD 3.0 X 5.0 (+ 1-In flange) X 7 Inches.
Ship Weight: 1-lb, 5 OZ.
MORE INFORMATION: See the Dunestar Bandpass Filters Frequently Asked Questions.
PRICING:
M333, Triplexer Only, is US $195.00. (For use with your existing 10, 15 & 20m BPFs)
M333-P, Triplexer PLUS Package, is US $399.00.  The M333-P Includes a 333 Triplexer, plus One-ea.10m,15m & 20m Dunestar 300- series Bandpass filters and 3 interconnect adapters.  See Triplexer PLUS Package page to order
HF Triplexer
M333 (10,15&20M)
M333v2 (160M, 80M, 40M
BG8PD,ex BG8OKU
择善而行,潇洒自在
BG8OKU#chinaham.org
离线罗剑
只看该作者 2楼 发表于: 2015-01-15
一套399刀,只要三工器195刀。
bpf七十多刀一个。
BG8PD,ex BG8OKU
择善而行,潇洒自在
BG8OKU#chinaham.org
离线bg9gxm
只看该作者 3楼 发表于: 2015-01-25
这玩意一刷卡完事 但是万一被查到 退运的风险特别特别大 你给海关的XX说不清楚……
通联卡片最近接不了了,年底忙的起得比鸡早,睡的比狗晚……主攻出版物和油标印刷:)
我个人为了支持BY VR2 XX9 BV Ham走出去
离线罗剑
只看该作者 4楼 发表于: 2015-01-26
非收发信机,不属于限制进口设备。即便是收发信机也不是禁止进口,这个多虑了。
只看该作者 5楼 发表于: 2015-01-26
回 bg9gxm 的帖子
bg9gxm:这玩意一刷卡完事 但是万一被查到 退运的风险特别特别大 你给海关的XX说不清楚…… (2015-01-25 23:46)
高价出给你 我暂时不用
只看该作者 6楼 发表于: 2015-01-26
4CB有在做~
900兆:要奇奇陆吧三铃摇摇就散
离线BD4CB
只看该作者 7楼 发表于: 2015-01-26
回 BH4TXN 的帖子
BH4TXN:4CB有在做~[表情]  (2015-01-26 11:17)
没人买得起!不做了!
离线BD4CB
只看该作者 8楼 发表于: 2015-01-26
这套东西我研究过,我有一种想骂娘的感慨!
离线bg9gxm
只看该作者 9楼 发表于: 2015-01-27
回 罗剑 的帖子
罗剑:非收发信机,不属于限制进口设备。即便是收发信机也不是禁止进口,这个多虑了。 (2015-01-26 08:20)
http://blog.sina.com.cn/s/blog_610b8b270100uqaq.html
看看这个 挺麻烦的
离线bg9gxm
只看该作者 10楼 发表于: 2015-01-27
回 BG4DRL 的帖子
BG4DRL:高价出给你 我暂时不用 (2015-01-26 09:29)
统统站住不许动 坐等顺丰快递
离线罗剑
只看该作者 11楼 发表于: 2015-01-28
回 bg9gxm 的帖子
bg9gxm:http://blog.sina.com.cn/s/blog_610b8b270100uqaq.html
看看这个 挺麻烦的 (2015-01-27 14:33)
我还没碰到过退运的,估计海关的同志也在不断进步中吧。
BG8PD,ex BG8OKU
择善而行,潇洒自在
BG8OKU#chinaham.org
