  • 3643阅读
  • 12回复
2014年一月第一个比赛 WW PMC 比赛简介 [复制链接]
离线我是伍亿
只看楼主 倒序阅读 0楼 发表于: 2014-12-30
— 本帖被 BA7IO 执行加亮操作(2014-12-30) —
1. GENERAL
The idea of the contest is to promote contacts between stations - operators who are residents of the town or suburb of the Peace Messenger Cities and the rest of the world. If you are not a resident of some PMC, you can also operate as portable station from
some PMC (for example, you can work /p from Berlin and give a multiplier BER).
PMC :Peace Messenger Cities
翻译过来是和平使者城市 是由联合国颁发的
中国目前只有北京被列为和平使者城市
2. DATE AND TIME
24 hours of operating time from 1200UTC Saturday to 1200 UTC Sunday, every first full weekend of January.
北京时间是 三号晚上八点到四号晚上八点
3. BANDS AND MODES
3.5, 7, 14, 21 and 28MHz, CW and SSB. IARU band plans should be observed. Suggested frequencies are: 3520-3560kHz and 3650-3750kHz, 7010-7030 and 7060-7160kHz, 14020-14060 and 14160-14260kHz, 21020-21060 and 21160-21260kHz, 28020-28060 and 28360-28460kHz.
4. CATEGORIES
We have a total of 24 categories in our contest as follows:
4.1 Single Operator Categories ( All Band)
(a) PMC Single Operator High Power - CW, SSB or MIX
(b) PMC Single Operator Low Power - CW, SSB or MIX
(c) PMC Single Operator QRP - CW, SSB or MIX
(a1) NONPMC Single Operator High Power - CW, SSB or MIX
(b1) NONPMC Single Operator Low Power - CW, SSB or MIX
(c1) NONPMC Single Operator QRP - CW, SSB or MIX
4.2 Multi-Operator Categories (All Band, High Power only, )
a) PMC Multi-Operator - CW, SSB or MIX
a1) NONPMC Multi-Operator - CW, SSB or MIX
5. EXCHANGE
For NONPMC entrants: Send RS(T) plus CQ zone number
For PMC entrants: Send RS(T) plus PMC reference (PMC stations MUST include PMC reference as part of their exchange)
5.1 LIST OF PMC
(ABI, ANT, ARN…….WOL, WRO, YOK)
There are 114 PMC on the world.
Complete PMC reference list is available here:
6. SCORING
6.1 QSO Points
NONPMC – NONPMC (QSO between NONPMC station and NONPMC station)
Each station receive 5 points for QSO
PMC – NONPMC (QSO between PMC station and NONPMC station)
PMC station receive 5 points for QSO, while NONPMC station receive 25 points for QSO.
PMC X – PMC Y (QSO between stations from direrent PMC reference)
Each station receives 10 points for QSO.
PMC X – PMC X (QSO between stations within the same PMC reference)
Each station receives 5 points.
6.2 Multipliers
The multiplier is the total of different PMC references contacted on each band on CW, plus the total of different PMC references contacted on each band on SSB. Each PMC reference counts only once for each band and each mode worked.
6.3 Total score:
The score is the total of QSO points on all bands added together, multiplied by the total of multipliers.
7. LOGS
Should be sent in Cabrillo file, 7 days after contest is finished and delivered by provided  upload link on www.s59dcd.si. Exceptionally, we will accept the log via special E-mail address   pmc@s59dcd.si, but that means your log be provided at last.
WW PMC contest is supported by following contest software:  N1MM logger by N1MM,TR4W by UA4WLI, EI5DI by EI5DI, DXLOG by 9A5K and UCX LOG by DL7UCX.
8. AWARDS
Certificates will be awarded to every station in each category, irrespective of the result achieved.
Certificates can be easy downloaded from our website.
Slovenj Gradec, October, 2014
President of S59DCD
Tomaz Kasnik, S57PKT
PMC 直接翻译的意思就是 和平使者城市
是由联合国颁发的荣誉
世界上一共有117个PMC城市 每个城市为一个系数
其中包括中国北京(交换信息是BEI)
如果是非PMC城市参加NONPMC 北京有台参加PMC组别
非PMC地区交换信息是599+CQZONE PMC地区交换信息为599+城市缩写(北京为BEI)
更多信息参照http://www.s59dcd.si/en10/index.php?option=com_content&view=article&id=78&Itemid=92
Points for QSO:
PMC:10 points per QSO between stations from direrent PMC reference.5 points per others QSO.Non-PMC:25 points per QSO with PMC reference.5 points per others QSO.
肇庆市端州区飘到了深圳市光明区
BG2CTX QSL卡管理人:BH2RO  来卡不回
对讲机只用国产100块钱的宝峰和泉盛.
离线BA7QT
只看该作者 1楼 发表于: 2014-12-31
看来楼主被毒得不轻啊!
BEST 73!   DE BA7QT/LIAO
QSL MGR:W3HNK
离线我是伍亿
只看该作者 2楼 发表于: 2014-12-31
回 BA7QT 的帖子
BA7QT:看来楼主被毒得不轻啊![表情]  (2014-12-31 01:22)
睡不着觉
就看一下规则复制粘贴一下。。。。。。。
肇庆市端州区飘到了深圳市光明区
对讲机只用国产100块钱的宝峰和泉盛.
离线BH1EBF
只看该作者 3楼 发表于: 2014-12-31
2015....
离线我是伍亿
只看该作者 4楼 发表于: 2014-12-31
回  3楼(BH1EBF)的帖子
第3楼BH1EBF于2014-12-31 05:48发表的:
2015....
半夜三更眼花。。。。。。求管理员帮忙改一下标题
离线BD5XX
只看该作者 5楼 发表于: 2014-12-31
这种比赛可能会睡着................
EX:BD5SO、BG5RSO
Email:bd5xx@foxmail.com
离线我是伍亿
只看该作者 6楼 发表于: 2014-12-31
回 BD5XX 的帖子
BD5XX:这种比赛可能会睡着................[表情]  (2014-12-31 12:38)
通常这种比赛扫地为主。。。。。。
实在找不到台就给DX台扫地
肇庆市端州区飘到了深圳市光明区
对讲机只用国产100块钱的宝峰和泉盛.
在线BD5FFK
只看该作者 7楼 发表于: 2014-12-31
俺们这穷山恶水的地方,和和平无关。让北京HAM玩比较合适。
离线BD7BW
只看该作者 8楼 发表于: 2014-12-31
1区的要代表全国参赛
湖南省郴州市
LOC:OL65MT
离线我是伍亿
只看该作者 9楼 发表于: 2015-01-03
今晚八点开始到明天晚上八点
肇庆市端州区飘到了深圳市光明区
对讲机只用国产100块钱的宝峰和泉盛.
离线我是伍亿
只看该作者 10楼 发表于: 2015-01-03
看了一下上一年的比赛记录。。。。。。排名第一的QSO数目才200不到
看来参与度不算太高啊
肇庆市端州区飘到了深圳市光明区
对讲机只用国产100块钱的宝峰和泉盛.
离线BA7KW
只看该作者 11楼 发表于: 2015-01-05
楼主通了几个台?
BA7KW  张建华
BA7KW"at"163.com
离线我是伍亿
只看该作者 12楼 发表于: 2015-01-05
回 BA7KW 的帖子
BA7KW:楼主通了几个台?
 (2015-01-05 00:05)
CQDX一下午只有一个俄罗斯一个日本
21mhz 28mhz基本废了 7mhz只能勉强做黑龙江本地通讯 14mhz勉强唠了一个日本台
剩下时间在14270上面唠嗑
最后打扫电台室卫生
肇庆市端州区飘到了深圳市光明区
对讲机只用国产100块钱的宝峰和泉盛.
