  • 7356阅读
  • 6回复
初音 RTL-SDR/HackRF Live DVD [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-12-07
喜欢玩电视棒的福音
Direct Download:
http://files.persona.cc/linux/ubuntu/ubuntu-12.04.2-custom-sdr-amd64.iso
- Built from Ubuntu Precise Server Edition (12.04)
- Generic kernel (not server)
- Gnome Classic (not Unity)
- Software up to date as of 2013/06/22
- udev rules set up for HackRF and RTLSDR
- Ready for VM or bare metal install
- Included Software:
    * SDR
        OsmoSDR Library
        RTL-SDR Library & Tools
        HackRF Library & Tools
        Linrad (not HackRF compatible)
        DReaM
        Various other SDR utilities that aren't RTLSDR/HackRF/OsmoSDR compatible
        GNU Radio v3.6.5
        gqrx
        openLTE
        GNSS-SDR
        gr-rds
        gr-pipe
        gpredict (Satellite Tracker, not really SDR itself)
        gsm-receiver
    * Forensics
        aircrack-ng v1.2 beta 1
        Reaver
        Wireshark
    * Utilities and Libraries
        Remastersys
        VMWare Tools (HackRF does not work on VMWare Workstation 9.0)
        VirtualBox Additions
        LAME, sox, mplayer, and various other media tools
        build-essentials, linux headers, git, subversion, cvs
        jackd
    * Development
        HackRF Firmware Development (ARM Toolchain & libopencm3)
        Monodevelop and libraries are provided so you can compile SDRSharp
            (be warned Mono has abysmal performance)
        Marcus D. Leech's excellent build-gnuradio script
            (/usr/local/bin/build-gnuradio .. launch via terminal in a subfolder, such as ~/dev)
    * Other
        Firefox + Adobe Flash
        XChat (IRC)
        irssi (IRC)
- Known Issues
    Choosing "Install" from boot menu may load live session anyway.
        Simply double click the installer shortcut on the desktop.
    You may see failed services. You can safely ignore this...
        It is likely either VMWare Tools, VirtualBox Additions, or both, depending on the platform used.
- Virtualization Issues
    VMWare Workstation 9 has an error when trying to communicate with the HackRF Jawbreaker
    VirtualBox USB performance is abysmal, and will not allow more than roughly 2 MSPS
        Sometimes it will not sample at all through VirtualBox, stop and start the receiver until it does.
- Post Installation
    If you'd like to remove VM tools, you can do the following:
        To remove VMWare Tools:
            Open Terminal, and type:
                sudo vmware-uninstall-tools.pl
        To remove VirtualBox Additions:
            Open Terminal and type:
                sudo /opt/VBoxGuestAdditions-4.2.14/uninstall.sh
        To build GNURadio from scratch (this is not advised unless you really need to):
        To build HackRF Firmware:
            Simply follow the directions provided by the firmware repo.
            There are a few forks available, but everything should be pre-installed to just compile it with little effort.
        To build SDRSharp with Mono:
            Obtain SDRSharp Source Code
            If you have trouble building SDRSharp from a source base that has been modified with MSVC 11 (VS 2012), edit the .sln file
            in a text editor to change the following lines:
            Change:
            Microsoft Visual Studio Solution File, Format Version 12.00
            # Visual Studio 2012
            To:
            Microsoft Visual Studio Solution File, Format Version 11.00
            # Visual Studio 2010
            Mono should now be able to process the solution and build it.
离线bg2jet
只看该作者 1楼 发表于: 2014-12-07
汉语是啥意思呀
离线m6sig
只看该作者 2楼 发表于: 2014-12-08
有点意思,pentoo用户路过
CS: M6SIG   LOC: OL63
新浪微博已停用
不再更新的旧数据: http://t.cn/RhrIAYe
只看该作者 3楼 发表于: 2014-12-09
支持UHD,
这样的好固件居然没人玩
电视棒环境哈 兄弟们 看过来 用过去 会高潮哒
离线WZK97126
只看该作者 4楼 发表于: 2016-02-03
请介绍一下怎么操作?谢谢!
离线osagem
只看该作者 5楼 发表于: 2016-02-14
省心啊
呼号…………BH7JAG DMRID4607039 NXDN6646
QRZ.com
离线BI7JTA
只看该作者 6楼 发表于: 2016-02-23
淘宝了一个做好的套件,看看如何玩
