  • 12997阅读
  • 35回复
TS-590SG的新特征 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-11-26
TS-590SG Incremental changes help performance and function to evolve (see the new brochure V1- download .pdf link below)
TS-590SG Upgraded features, replaces the original TS-590S model
Enhanced RX performance with superb 3rd-order Dynamic Range
New On-screen CW decoder
Extended Digital IF Filter selections
“ANT Out” function like TS-990S
TX/RX Equalizer DSP now settable per Mode
Now up to 20 steps adjustment for TX Monitor and CW Side-tone
Enhanced VGS-1 “Voice Guide” functions
New Quick Split-frequency Operation function like TS-990S
New Tri-Colour LCD Display (Amber, Green or Yellow)
Extra (3rd) PF function via push-switch in the MULTI/CH knob
De-luxe new VFO knob design
我的蝇文很烂:
1、增强接收机性能,改进三阶动态范围(2KHz)。
2、新增CW解码功能,像K3那样的。。
3、带接收天线输出,好像是利用DRV接口(妈妈再也不用担心SDR的接收天线问题了)
4、分模式调节的收发EQ调节,发射监听音量与CW侧音音量升级为20阶可调;
5、增强VGS-1的语音向导功能;
6、类似990的快捷操作;
7、新的三色LCD屏幕;
8、小波轮可以按压了;
9、双VFO波轮了。
Enhanced RX performance 3rd Order Dynamic Range @ practical 2 kHz separation (revised circuitry around post 1st Mixer & AGC control system & C/N characteristic of 1st Local OSC) – CW signal is decoded and scrolls in the 8-segment of the LCD (like to K3) – MULTI/CH encoder is changed, with push-switch funcition – ANT OUT to use with DRV OUT terminal as ANT OUT (via internal splitter) to connect external RX such as a Pan-adapter (3dB loss in divider) – SPLIT Setting: push and hold Split key, push “5” key example then you can work 5kHz up in Split operation -TX Power spike comparable to TS-990S  etc
Adjacent C/N with conventional PLL/VCO – This is a method in which, for the 1st local oscillator, instead of employing conventional PLL/VCO, the output of a DDS (Direct Digital Synthesizer Analog Devices Inc. AD9951YSVZ) is supplied directly to the Mixer.During down conversion, the oscillation frequency is lower than it is in up conversion, so even better C/N (Carrier to Noise ratio) characteristics can be achieved.
在线weed
只看该作者 1楼 发表于: 2014-11-26
有解码功能?我晕~
只看该作者 2楼 发表于: 2014-11-26
回 weed 的帖子
weed:有解码功能?我晕~ (2014-11-26 16:09)
这个功能可以无视。。
下面那段话等大师来翻译,好像是本振源换了,改成DDS了,不清楚原来的,原来是PLL吗?
离线bg9gxm
只看该作者 3楼 发表于: 2014-11-26
买990就行了
ARRL终身会员 lifetime member
只看该作者 4楼 发表于: 2014-11-27
590与990之间断档太多,没有细分市场,让人蛋疼
只看该作者 5楼 发表于: 2014-11-27
买!买了就知道了
900兆:要奇奇陆吧三铃摇摇就散
只看该作者 6楼 发表于: 2014-11-27
隔壁有人能代购了,不知道是不是蒸的。。
只看该作者 7楼 发表于: 2014-11-27
不出个490
BD4AQR KF5GSV
离线BG4HUL
只看该作者 8楼 发表于: 2014-11-28
新功能值不值500刀?
DE Bg4HUL
PM01QD
Standingby @
434.000,
14.270USB
144.940APRS
"BG4HUL-3" iGate in service
13918248747
eMail  bg4hul@qq.com
QQ 30124304
离线王昊霖
只看该作者 9楼 发表于: 2015-01-14
回 老干部 的帖子
老干部:不出个490 (2014-11-27 03:02)
时常关注老师的每一个回帖,有技术上的电路分析,又有实际操作感受,能学习到很多东西,致谢
想请老师详细对比下TS480和TS590这对同门兄弟,一个便携车载,一个固定台式,这个自然是知道的,是想从电路设计、到实际使用时接收效果、和发射效果对同门兄弟做一比较和点评,越详细越好。
同是K家,虽然上市年代、定位及价格都不相同,但更想知道两机接收效果和发射效果有什么区别,或者说是有多大差距。
非常期待,严重致谢!
离线王昊霖
只看该作者 10楼 发表于: 2015-01-14
回 老干部 的帖子
因为时常用心拜读老师的回帖,所以大致知道老师曾想要一个480的壳+590的芯,谓之490是也。。。
离线王昊霖
只看该作者 11楼 发表于: 2015-01-14
回 老干部 的帖子
印象中记得有HAM说和数台590通联发现590声音过来不是太好,干涩,也请“老干部”师傅做一分析
只看该作者 12楼 发表于: 2015-01-14
惭愧,完全不是老师。
480是570以后的产品,大约是2000年过后2001或2002年推出,和FT897,857类似年代的音频DSP短波机。依然是典型的模拟短波机回路设计。比570微微提高了中频滤波器品质和射频前端的动态。
我是希望490这样的机器,保持590的低中频设计,DSP阶段的中频处理。
BD4AQR KF5GSV
离线bg7day
只看该作者 13楼 发表于: 2015-01-14
顶顶~~~~~
湖南娄底欢迎您!
439.875   434.875   88.5
147.850   144.050   88.5
姓名:付坚强
呼号:BG7DAY  操作证号:B000002606
电台:YAESU FT-1000MP
天线:C19
手机:15573848888  QQ:16743490
邮编:417000
地址:湖南省娄底市娄星区华达汇多超市
支付宝:15573848888
只看该作者 14楼 发表于: 2015-01-15
妈妈再也不用担心SDR的接收天线问题了
离线BA2Bi
只看该作者 15楼 发表于: 2015-01-15
不看广告 看疗效
离线BA5CW
只看该作者 16楼 发表于: 2015-01-15
回 老干部 的帖子
老干部:惭愧,完全不是老师。
480是570以后的产品,大约是2000年过后2001或2002年推出,和FT897,857类似年代的音频DSP短波机。依然是典型的模拟短波机回路设计。比570微微提高了中频滤波器品质和射频前端 .. (2015-01-14 18:00)
一直感觉590的设计挺严谨,在比赛中的表现不会输给K3这类比他贵很多的机器,前年NQ他们新疆比赛回来反应590很差,我还不相信,直到去年的CQWW SSB比赛用过590之后,我不得不同意NQ他们的说法,在PILEUP中,信号黏在一起,和同场用的K3和7600完全不好比。不过在小信号处理上倒还不错,DSP降噪也很有特点,虽然把语音搞得比较难听,但是他愣是让我能听明白原来听不太清的内容。可惜用的时间比较短,没法做更多的测试,回去后认真思考了一下,pileup处理的问题或许不是590的动态比K3这类机器差,而是AGC曲线的调教问题,不知道590能不能自定义agc曲线,自从用了K3的AGC自定义后,有很多以前困惑的问题迎刃而解。
[ 此帖被BA4ALC在2015-01-15 19:26重新编辑 ]
只看该作者 17楼 发表于: 2015-01-15
喜欢590就是因为弱信号的分辨,7600完全是一堆散沙
离线BA5CW
只看该作者 18楼 发表于: 2015-01-15
回 BD8SZ 的帖子
BD8SZ:喜欢590就是因为弱信号的分辨,7600完全是一堆散沙 (2015-01-15 19:28)
590平时DX应该是比较适合的,而且K的遥控软件既好用又免费,但是对SSB比赛真不太适合,CW没试过,我不知道。
小信号处理和大信号处理是矛盾的,所以我后面说了,也许是AGC的调校问题,由于不熟悉机器的使用,我当时不知道怎么关闭AGC完全采用手调来解决问题,否则我就能确认是不是AGC曲线的问题。
K3挺山寨的,但是他最大的有点就是抓住了业余无线电用户的心里,对于众口难调的东西,都用菜单选项让你自己决定,而且用户界面的逻辑也比较符合爱好者的思路。各方面表现也比较均衡,前面提到的7600在SSB的时候的表现我感觉比K3好,但在cw比赛的时候,又显得弱很多。K3则适应性要广很多就,这就是我现在只留下K3的原因,不过今后的发展是SDR,可以少关心点这类机器的比较了。
抱歉,很久没有参与机器的评论了,今天有点破例,赶快收回。
只看该作者 19楼 发表于: 2015-01-15
590在cw比赛堆积的时候,粘在一起的情况好得多,我觉得能分辨,反而感觉FTdx-3000都没有590好,FTdx-3000搅一起让头皮发麻,感觉而已。。
ssb没有比对过。
