  • 4542阅读
  • 1回复
DXLab 的系列软件 [复制链接]
离线罗剑
只看楼主 倒序阅读 0楼 发表于: 2014-11-18
http://www.dxlabsuite.com/dxlabwiki/InstallLauncher
功能齐全啊,几乎全能
Getting Started with DXLab
Welcome to DXLab! The DXLab Suite is a free set of applications that support DXing activities. You can use them individually, but when multiple DXLab applications are running they detect each other's presence and interoperate automatically. One benefit of this approach is that you can learn applications individually. It doesn't matter where you begin, or what sequence you choose: start with one application that satifies an interest or need, and get comfortable with it. Then choose the next application that suits your fancy, and repeat the process. What's important is taking your time and having fun.
Reference Documentation
Each DXLab application has reference documentation that describes its capabilities and options. To get comfortable with a DXLab application, start by scanning this documentation to create an inventory of the application's features that you plan to use first. It's important that you ignore all details and secondary features during this scan!;you can always return for the details when needed, and you can always return to scan for secondary features once you've mastered the most important ones. Reference documentation is available in an online (HTML) format that you can view with your web browser, and in a downloadable PDF format that is easy to search or print:
Application
Functions
HTML Reference Documentation
PDF Reference Documentation
Commander
Transceiver Control, Bandspread
Commander
Commander
DXKeeper
Logging, QSLing, Award Tracking
DXKeeper
DXKeeper
DXView
DX Information, World Map
DXView
DXView
Launcher
Suite Control
Launcher
Launcher
Pathfinder
QSL Route Discovery
Pathfinder
Pathfinder
PropView
Propagation Prediction and Monitoring
PropView
PropView
SpotCollector
DX Spot Management
SpotCollector
SpotCollector
WinWarbler
CW, Phone, PSK, and RTTY operation
WinWarbler
WinWarbler
To search for specific information, use the appropriate application's PDF file, as it provides all information within a single file. When you install a DXLab application, a local copy of its HTML reference documentation is created in the application's Help folder; Help buttons in the application provide immediate access to this local copy without internet access delays.
After scanning an application's reference documentation, start that application, choose an interesting function, and refer to the documentation to help you configure the application to support that function. For example, if the application is Commander and the function is transceiver control, then the minimum configuration would be choosing a radio model, choosing a serial port, and setting that serial port's parameters. Then choose the next interesting function and get it going; repeat this process until the application is doing everything you need.
[ 此帖被罗剑在2014-11-18 13:22重新编辑 ]
BG8PD,ex BG8OKU
贵州省贵阳市解放路51号盛世华庭二层(快递仅工作日收货)
择善而行,潇洒自在
BG8OKU#chinaham.org
离线罗剑
只看该作者 1楼 发表于: 2014-11-18
免费的好软件,准备花点时间研究一下。
BG8PD,ex BG8OKU
择善而行,潇洒自在
BG8OKU#chinaham.org
