  • 2587阅读
  • 1回复
【KX3】MCU 2.27 / DSP 1.30  11-10-2014 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-11-13
MCU 2.27 / DSP 1.30, 11-10-2014
• RX I/Q PORT TURNED ON AUTOMATICALLY WITH PX3 ATTACHED: The KX3 now turns on the RX I/Q output whenever it detects an attached PX3. This eliminates the problem of image signals in the PX3 display due to RX I/Q being accidentally turned off.
• IMPROVED FIRMWARE LOADING: The KX3 now cleanly handles the case where new MCU firmware is incompatible with old DSP firmware in the middle of a full firmware load sequence. An error message may still appear in this case, but load timing will not be affected, allowing the new DSP firmware to be loaded correctly.
只看该作者 1楼 发表于: 2014-11-13
好吧。。
