  • 2749阅读
  • 5回复
KX3 firmware rev. 2.23 (with DSP rev. 1.30) [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-09-26
KX3 firmware rev. 2.23 (with DSP rev. 1.30) enables the use of DUAL RX (dual watch)
even with RX SHFT set to 8.0 kHz in the menu. RX SHFT=8.0 can help optimize the KX3's performance in
the presense of large signals or power supply noise. Shifting the RX may also help in CW mode with dual watch enabled,
reducing audible keying artifacts.
NOTE: On any band where dual watch is turned on with RX SHFT set to 8.0,
the normal +/- 15 kHz dual-watch VFO A-to-B separation becomes -7/+23 kHz.
But the KX3 will, in all cases, automatically turn off dual watch if the VFO separation exceeds the limits.
Firmware files and instructions can be found here:
http://www.elecraft.com/KX3/KX3_software.htm
只看该作者 1楼 发表于: 2014-09-26
哇!!!!要是dual rx split能到192k就好了
只看该作者 2楼 发表于: 2014-09-26
有了也没用
又到了天热时
2VMode 肯定机器烫手  OverHeat 等着呢....
离线罗剑
只看该作者 3楼 发表于: 2014-09-27
只看该作者 4楼 发表于: 2014-09-27
环境温度从来没有超过30的撸过,自然降温
只看该作者 5楼 发表于: 2014-09-29
