  • 3272阅读
  • 0回复
gp88 改gp300 方法英文版 [复制链接]
离线shark
只看楼主 倒序阅读 0楼 发表于: 2003-04-19
gp88 to gp300
open the gp88 file with hex workshop or other software change number 23 with number 14 at offset 0000000c
3133 3354 5545 3439 3230 0403 2304 0102 <-- recognized as gp88 (original)
3133 3354 5545 3439 3230 0403 1404 0102 <-- recognized as gp300
write to the disk, finish. run the program, and your gp88 recognized/detected as gp300 with features.
gp88宽频接收方法
the basic process is just open lowest and highest limit of frequency.
offset 20351      94 change to 00
offset 20352      11 change to 00
offset 20358      5c change to 06
offset 20359      12 change to 27
offset 20365      94 change to 00
offset 20366      11 change to 00
offset 20372      5c change to 06
offset 20373      12 change to 27
offset 20379      94 change to 00
offset 20380      11 change to 00
offset 20386      5c change to 06
offset 20387      12 change to 27
offset 199688      5c change to 06
offset 199689      12 change to 27
now, how is it works ? can you see 94 paired with 11 --> 1194, 5c paired with 12 -->1254 and so on ?.
if you put the numbers with these series 1194, 125c, 0000, 2706
1194 hex is 4500 in decimal
125c hex is 4700 in decimal
0000 hex is of course 0 in decimal
2706 in hex is 9990 in decimal
now you can see 4500 (450.0 in frequency) is the lowest frequency permitted for motorola (f3 ?) and 4700 (470.0 in frequency) is the highest frequency permitted for motorola (f3 ?).
if you change 4500 to 0000 and 4700 with 9990 it means that the limit is extended (erased ?). with this method you can change the limitation of your motorolla rss as your wish.
