  • 4659阅读
  • 3回复
HRD6新版- v6.2.72.293 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-09-05
6.2.72 updated feature set
*     Fault on connection with IP logging enabled fixed.
*      Norton 360 fix
*       LOTW upload and download fix
*     ODBC fix for install.
*    Winkey 3 fix
1.       FT-1200 Support
2.       OMNI VI support
3.       HRD Voice
4.       updated Label-maker
5.       ADX support
6.       FT-767 GX II support
7.       Support for IC-9100 in Satellite mode to use VFO B.
8.       Added WA9PIE-2 cluster support
9.       Unicode support
10.   Moved code to Visual Studio 2013, which decreased load time of programs
11.   Improved K3 and KX3 support
12.   Support for the Flex 6700 with SmartSDR
13.   Better Windows 8.1 support
14. Yaesu SCU-17 support
15. Orion KY keyer support
16. ClubLog support
17. New Dstar Icom radio support ID-3 and ID-5
18. FSK fixes (updated)
19. PSK Reporter fixes
20. Logbook and Cluster fixes
21. Radio Control fixes, Kenwood, Yaesu, and more
22. IC-9100  Dual VFO Satellite Support
23.  Fixes for LOTW
24. Logbook fixes
25. Icom A/B and QSX fixes
26. Line colors based on WSI in the logbook
27. ID-5100 support
28. updated license manager
29. RC fix for VCP ports...
30. Multiple QSO's on a single label.
31. Make your own QSL
32. Alinco supportm DX SR8/9, DX77
32. HRD WSI Filters
33. Support for rotors controled by CAT in the FTDX Series of radios.
只看该作者 1楼 发表于: 2014-09-05
非常不能理解的是
DM780的 Rptr 版本 从v1.8降到了V0.6 .....
只看该作者 2楼 发表于: 2014-09-09
v6.2.72.294 又不知道有哪些fix
离线shtsunwu
只看该作者 3楼 发表于: 2014-10-21
付费的么?还是免费的
呼号BG2CRP
黑龙江省五常市
