  • 21846阅读
  • 27回复
发现一个各种线性天线的图样网站 [复制链接]
离线BG6JJI
只看楼主 倒序阅读 0楼 发表于: 2014-09-05
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线BG6JJI
只看该作者 1楼 发表于: 2014-09-05
01 - 三通天线
02 - 半的Lamda三通天线
03 - 双带领的马可尼天线
04 - 燕子,尾巴天线
05 - 随机长度散热器线天线
06 - 温德姆天线
07 - 温德姆天线 - 与同轴电缆饲料
08 - 四分之一波长垂直天线
09 - 折叠T恤马可尼天线
10 - 齐柏林天线
11 - 母羊天线
12 - 偶极子天线 - 巴伦
13 - 多频段偶极天线
14 - 倒V型天线
15 - 坡偶极子天线
16 - 垂直偶极
17 - 三角洲美联储偶极子天线
18 - 蝶形偶极子天线
19 - 蝶形折叠偶极子天线的接收
20 - 多波段调谐双峰天线
21 - G5RV天线
22 - 宽带偶极子天线
23 - 宽带偶极子的接收
24 - 倾斜折叠偶极子天线
25 - 直角马可尼天线
26 - 线性负载三通天线
27 - 缩小尺寸偶极子天线
28 - 双峰偶极子天线
29 - 德尔塔环形天线
30 - 半三角洲环形天线
31 - 富兰克林共线天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/31-Colinear%20Franklin%20Antenna.jpg[/img]
32 - 四元宽边天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/32-Four%20Element%20Broadside%20Array%20Antenna.jpg[/img]
33 - 懒惰-H天线阵
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/33-The%20Lazy-H%20Array%20Antenna.jpg[/img]
34 - Sterba窗帘阵列天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/34-Sterba%20Curtain%20Array%20Antenna.jpg[/img]
35 - TL的DX天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/35-T-L%20DX%20Antenna.jpg[/img]
36 - 1.9 MHz全波环形天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/36-1.9MHz%20Full-wave%20Loop%20Antenna.jpg[/img]
37 - 多波段便携式天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/37-Multiband%20Portable%20Antenna.jpg[/img]
38 - 关中心馈全波双峰天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/38-Off-center-fed%20full-wave%20doublet.jpg[/img]
39 - 终止斯洛泼天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/39-Terminated%20sloper%20antenna.jpg[/img]
40 - 双扩展策普天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/40-Double%20extended%20Zepp%20antenna.jpg[/img]
41 - TCFTFD偶极子天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/41-TCFTFD%20dipole%20antenna.jpg[/img]
42 - V型天线斯洛泼
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/42-Vee-sloper%20antenna.jpg[/img]
43 - 菱形倒V型天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/43-Rhombic%20inverted-vee%20antenna.jpg[/img]
44 - 地网Longwire
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/44-Counterpoise%20longwire.jpg[/img]
45 - Bisquare环形天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/45-Bisquare%20loop%20antenna.jpg[/img]
46 - 背驮式天线,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/46-Piggyback_antenna_for_10m.jpg[/img]
47 - 立式套筒天线的10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/47-Vertical_Sleeve_Antenna_for_10m.jpg[/img]
48 - 双温德姆天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/48-Double_Windom_Antenna.jpg[/img]
49 - 双温德姆9波段
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/49-Double_Windom_for_9-bands.jpg[/img]
50 - 共线天线陷阱
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/50-Collinear_Trap_Antenna.jpg[/img]
51 - 短偶极子天线的40M - 80米 - 160米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/51-Short_Dipole_Antenna_for_40m-80m-160m.jpg[/img]
52 - 中心美联储策普天线的80米 - 40立方米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/52-Center-Fed_Zepp_Antenna_for_80m-40m.jpg[/img]
53 - 全波段天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/53-All-bands_Antenna.jpg[/img]
54 - 全波段偶极子天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/54-All-bands_Dipole_Antenna.jpg[/img]
55 - 多频段天线Ž
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/55-Multiband_Z_Antenna.jpg[/img]
56 - 多频段偶极天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/56-Multiband_Dipole_Antenna.jpg[/img]
57 - 五带无调谐器天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/57-Five-Bands_no_tuner_Antenna.jpg[/img]
58 - 双频全波环形天线的80米-40M
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/58-Dualband_Full-wave_Loop_Antenna_80m-40m.jpg[/img]
59 - 环天线的10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/59-Loop_Antenna_for_10m.jpg[/img]
60 - 懒四天线的10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/60-10m_Lazy_Quad_Antenna.jpg[/img]
61 - 三频三角环形天线的80米 - 40立方米 - 30
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/61-Tri-band_Delta_Loop_Antenna_80m_40m_30m.jpg[/img]
62 - 双频环形天线的30米 - 40立方米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/62-Dual-band_Loop_Antenna_30m-40m.jpg[/img]
63 - 线波束天线的80米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/63-Wire-Beam_Antenna_for_80m.jpg[/img]
64 - 双频天线斯洛泼
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/64-Dual-Band_Sloper_Antenna.jpg[/img]
65 - 倒V天线波束的30米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/65-Inverted-V_Beam_Antenna_for_30m.jpg[/img]
66 - ZL-特殊波束天线的15米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/66-ZL-Special_Beam_Antenna_for_15m.jpg[/img]
67 - 半斯洛泼天线的160米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/67-Half-Sloper_Antenna_for_160m.jpg[/img]
68 - 两带半斯洛泼了80米 - 40立方米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/68-Two-Bands_Half_Sloper_80m-40m.jpg[/img]
69 - 线性负载斯洛泼天线的160米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/69-Linear_Loade_Sloper_for_160m.jpg[/img]
70 - 超斯洛泼天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/70-Super-Sloper_Antenna.jpg[/img]
71 - 塔立杆的垂直天线的80米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/71-Tower-as-a-Vertical_Antenna_for_80m.jpg[/img]
72 - 晒衣服天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/72-Clothesline_Antenna.jpg[/img]
73 - 窗帘策普天线,160米,80,40M
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/73-Curtain_Zepp_160m_80m_40m.jpg[/img]
74 - 共线阵天线,40M,30M,20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/74-Collinear_Array_40m_30m_20m.jpg[/img]
75 - 160米倒三角形循环
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/75-160_Meter_Inverted_Delta_Loop.jpg[/img]
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线BG6JJI
只看该作者 2楼 发表于: 2014-09-05
76 - 半菱形单向垂直20米6米
77 - 电容负载的垂直天线的160米
78 - 风扇偶极子天线的80米6米
79 - 导线接地平面天线
80 - 倒三角形环形天线的160米
81 - 倒L型的160米
82 - 300ohm丝带双频偶极
83 - 三频梁20米,15米,10米
84 - 迷你马八木天线
85 - 半菱形定向天线20米6米
86 - 范 - 偶极子天线,80M,40M,20米
87 - 容量调整折叠环形天线20米
88 - 室内环形天线的80米30米
89 - 室内环形天线的80米
90 - 双三角天线80米40米
91 - 电感式器械缩短的偶极子的160米
92 - V形波束天线的15米
93 - 野餐垂直线天线
94 - 悠闲的四天线的80米
95 - 相控回路天线
96 - 环形天线的发射为160米
97 - Morgain偶极天线的160米,80m
98 - ZL-特20米,15米,10米
99 - 双锥形天线
100 - 指令三角洲鸟笼天线20米10米
101 - 双极化天线,80米40米
102 - 指令300欧姆的丝带折叠偶极子的15米
103 - 小型定向天线的10米
104 - 双二阶天线12dBi增益为2.4GHz的
105 - 双菱形天线,435MHz至870MHz
106 - 双火箭筒天线的80米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/106-Double-Bazooka_Ant_80m.jpg[/img]
107 - 歼式天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/107-J-Style_Ant.jpg[/img]
108 - 垂直/水平/圆极化天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/108-VHC_Antenna.jpg[/img]
109 - 同轴倒L形天线的80米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/109-Coax_Inverted-L_Ant_80m.jpg[/img]
110 - 室内小型环形天线的80米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/110-Indoor_Compact_Loop_Ant_80m.jpg[/img]
111 - 螺旋天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/111-Helix_Antenna.jpg[/img]
112 - 新手垂直天线的80M,40M,15M,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/112-Novice_Vertical_Ant_80m-40m-15m-10m.jpg[/img]
113 - 存根加载缩短的偶极子的80米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/113-Stub-Loaded_Shortened_Dipole_80m.jpg[/img]
114 - 六带线存根陷波天线的40米-10M
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/114-Six-Band_Wire-Stub-Trap_Ant_40m-10m.jpg[/img]
115 - 多波段半波三角环形天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/115-Multiband_Half-Wave_Delta_Loop_.jpg[/img]
116 - 混合型V型20米,17米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/116-Hybrid_Vee_20m-17m.jpg[/img]
117 - 六射击阵天线,增益=7.5分贝
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/117-Six-Shooter_Array_Ant_G-7.5dB.jpg[/img]
118 - 多频段地面平面天线,10M,15M,20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/118-Multiband_Ground_Plane_Ant_10-15-20m.jpg[/img]
119 - 线的Superbeam天线,10M,15M,20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/119-Wire_Superbeam_Ant_10-15-20m.jpg[/img]
120 - 两个元素三角洲环形天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/120-Two_Elements_Delta_Loop_Ant.jpg[/img]
121 - Sterba窗帘天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/121-Sterba_Curtain_Ant.jpg[/img]
122 - 半波垂直天线策普
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/122-Half-Wave_Vertical_Zepp_Ant.jpg[/img]
123 - 懒环形天线的40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/123-Lazy-Loop_Ant_40m.jpg[/img]
124 - 已结束折叠偶极子为80M,40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/124-Terminated_Folded_Dipole_80m-40m.jpg[/img]
125 - 短发天线的15米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/125-Short-Fat_Ant_15m.jpg[/img]
126 - 眼镜蛇天线的80米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/126-Cobra_Ant_80m.jpg[/img]
127 - 对数周期天线线20米,15米,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/127-Log-Periodic_Wire_Ant_20m-15m-10m.jpg[/img]
128 - 5元数周期天线垂直为80M,40M,20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/128-5-element_Log-Periodic_Vertical_Ant.jpg[/img]
129 - 2米垂直线天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/129-2m_Wire_Vertical_Antennas.jpg[/img]
130 - 地球发倒V天线,40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/130-Earth-Mover_Inverted-V_Ant_40m.jpg[/img]
131 - 同轴电缆,电缆共线天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/131-Coax-Cable_Collinear_Ant.jpg[/img]
132 - 双短尾天线20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/132-Double_Bobtail_Ant_20m.jpg[/img]
133 - 策普共线天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/133-Collinear_Zepp_Ant.jpg[/img]
134 - 泰勒V形天线20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/134-Taylor_Vee_Ant_20m.jpg[/img]
135 - 共线垂直天线6分贝增益为2M,1.3米,73厘米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/135-Collinear_Vertical_6dB-Gain_2m,1.3m,73cm.jpg[/img]
136 - 双环形天线20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/136-Bi-Loop_Antenna_20m.jpg[/img]
137 - 丝束6dBd增益为10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/137-Wire_Beam_6dBd-Gain_10m.jpg[/img]
138 - 坡钻石天线4分贝增益为40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/138-Sloping_Diamond_Ant_4dB-Gain_40m.jpg[/img]
139 - 扭曲环形天线的160米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/139-Twisted_Loop_Ant_160m.jpg[/img]
140 - DX RX环形天线的160米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/140-DX_RX_Loop_Ant_160m.jpg[/img]
141 - Hentenna3分贝增益为10M,6M,2米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/141-Hentenna_3dB-Gain_10m-6m-2m.jpg[/img]
142 - VK2AAR线天线20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/142-VK2AAR_Wire_Antenna_20m.jpg[/img]
143 - 2元四天线的6米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/143-2-Elem_Quad_Ant_6m.jpg[/img]
144 - 呼啦圈双向6分贝增益天线的17米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/144-Hula-Loop_Bidirectional_6dB-Gain_Ant_17m.jpg[/img]
145 - 莫克森矩形梁15米-10M
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/145-Moxon_Rectangle_Beam_15m-10m.jpg[/img]
146 - 双D光束4分贝增益
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/146-Double-D_Beam_4dB-Gain.jpg[/img]
147 - KE4PT持续进修基金办事处全波段偶极
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/147-KE4PT_OCEF_All-Band_Dipole.jpg[/img]
148 - 四线天线,40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/148-Wire_Quad_Antenna_for_40m.jpg[/img]
149 - 斜偶极子天线,80M,40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/149-Inclined_Dipole_80m-40m.jpg[/img]
150 - 锥体线天线的80米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/150-Pyramidal_Wire_Antenna_80m.jpg[/img]
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线BG6JJI
只看该作者 3楼 发表于: 2014-09-05
151 - 乱丝天线全波段
152 - 多频段偶极天线,80M,40M,15M,10米
153 - 斯利姆吉姆线天线的4米
154 - 三角洲回路6米
155 - 重新配置天线的160米,80m
156 - 甚低频倒L形天线
157 - 尺寸减小一半斯洛泼天线的160米
158 - 树式短波天线
159 - 多频段垂直天线的80M,40M,20米
160 - 马可尼天线为136千赫
161 - 简单的杀手天线,40米
162 - 存根,定向V天线的80米
163 - KT0NY过和,在DX天线20米
164 - 水平环形天线
165 - 丝带歼极,实现2M
166 - 双频丝带歼极点为2M,70厘米
167 - 方形垂直环形天线的40米
168 - 三频四天线20米,15米,10米
169 - 3D四天线,80M,40M,20M,15M,10米
170 - 坡线天线,30M,20M,17米,15米,12M,10M
171 - 宽带偶极子天线,同轴谐振腔的80米
172 - 馈线共振偶极子天线的80米
173 - 双带负载线天线为80M,30米
174 - 存根匹配天线
175 - 歼式垂直线天线的10米
176 - 双频带垂直馈线策普为40M,20米
177 - RCA双二的40米至12m
178 - RCA蜘蛛网天线,40米6米
179 - 折叠偶极子与短路链
180 - 双导马可尼天线,160米,80
181 - 宽带天线四分之一波长巴伦80米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/181-Broadband_Ant_L-4_Balun_80m.jpg[/img]
182 - 三季度波折叠双峰双频
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/182-3L-4_Folded_Doublet_Dual-Band.jpg[/img]
183 - 三季度波折叠双峰无开关的双频
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/183-3L-4_Folded_Doublet_No-Switch_Dual_Band.jpg[/img]
184 - 宽带全向锥天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/184-Wideband_Omnidirectional_Discone_Antenna.jpg[/img]
185 - 宽带菱形天线的40米10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/185-Wideband_Rhombic_Ant_40m-to-10m.jpg[/img]
186 - 预切线性阵列天线3分贝增益为40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/186-Pre-Cut_Linear_Array_Ant_3dB-Gain_40m.jpg[/img]
187 - X阵天线6分贝增益20米,15米,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/187-X-Array_Ant_6dB-Gain_20m-15m-10m.jpg[/img]
188 - 双布鲁斯阵天线5分贝增益20米,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/188-Double-Bruce_Array_Ant_5dB-Gain_20m-10m.jpg[/img]
189 - 双广场宽边阵列天线4分贝增益20米,15米,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/189-Bi-Square_Broadside_Array_Ant_4dB-Gain_20m-15m-10m.jpg[/img]
190 - 六射手宽边阵列天线7.5分贝增益20米,15米,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/190-Six-Shooter_Broadside_Array_Ant_7.5dB-Gain_20m-15m-10m.jpg[/img]
191 - 三层平顶光束4.5分贝增益20米,15米,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/191-Triplex_Flat-Top_Beam_4.5dB-Gain_20m-15m-10m.jpg[/img]
192 - 双频天线倾斜20米,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/192-Dual-Band_Tilt_Ant_20m-10m.jpg[/img]
193 - 超级空间多频段偶极子天线的80米10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/193-Super_Space_Multiband_Dipole_80m-to-10m.jpg[/img]
194 - 双方木天线增益=5.5分贝的10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/194-Bi-Square_Beam_Ant_Gain-5.5dB_10m.jpg[/img]
195 - 表哥G5RV多频段天线的40米10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/195-Cousin-of-G5RV_Multiband_Ant_40m-to-10m.jpg[/img]
196 - 开曼四天线20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/196-Cayman_Quad_Ant_20m.jpg[/img]
197 - Hentenna增益=3分贝用火箭筒匹配的6米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/197-Hentenna_G-3dB_with_Bazooka_Match_6m.jpg[/img]
198 - X波束天线增益=3分贝20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/198-X-Beam_G-3dB_20m.jpg[/img]
199 - 双三角环形天线增益=6分贝的160米,80,40M
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/199-Twin-Delta_Loop_G-6dB_160m-80m-40m.jpg[/img]
200 - 倒V天线波束的30米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/200-Inverted-V_Beam_Ant_30m.jpg[/img]
201 - FD4温德姆天线,80M,40M,20M,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/201-FD4_Windom_Ant_80m-40m-20m-10m.jpg[/img]
202 - 两种元素相控三角洲回路40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/202-2-elem_Phased_Delta_Loop_40m.jpg[/img]
203 - 三要素线八木的10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/203-3-Elem_Wire_Yagi_10m.jpg[/img]
204 - 低辐射角全波环形天线的80米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/204-Low_Radiation_Angle_Full-Wave_Loop_80m.jpg[/img]
205 - 共线天线增益=3分贝实现2M
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/205-Collinear_Ant_3dB-G_2m.jpg[/img]
206 - X射线Monoband天线增益= 6.5dBd
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/206-X-Ray_Monoband_Ant_6.5dBd-Gain.jpg[/img]
207 - 宽边共线帘阵列20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/207-Broadside_Collinear_Curtain_Array_20m.jpg[/img]
208 - 缩水环形天线的80M,40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/208-Shrunk_Loop_Ant_80m-40m.jpg[/img]
209 - λ/ 3多频段偶极为40M,20M,17米,15米,13M,10M
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/209-1-3_Wavelength_Multiband_Dipole_40m-20m-17m-15m-13m-10m.jpg[/img]
210 - K3LR斯洛泼天线增益=3分贝的160米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/210-K3LR_Sloper_G-3dB_160m.jpg[/img]
211 - 迷你折叠的垂直单极天线,160米,80,40M
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/211-Mini_Folded_Vert_Monopole_160m-80m-40m.jpg[/img]
212 - 三带偶极为80M,40M,20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/212-Three_Band_Dipole_80m-40m-20m.jpg[/img]
213 - 存根匹配偶极子天线
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/213-Stub_Matched_Dipole.jpg[/img]
214 - 倒V型天线,火箭筒比赛
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/214-Inverted-Vee_with_Bazooka_Match.jpg[/img]
215 - 多频段长线天线,40M,20M,15M,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/215-Multiband_LongWire_Ant_40m-20m-15m-10m.jpg[/img]
216 - 转换V形天线,80M,40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/216-Converted-Vee_Ant_80m-40m.jpg[/img]
217 - 瑞士四天线20米,15米,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/217-Swiss_Quad_Ant_20m-15m-10m.jpg[/img]
218 - 日本四天线20米,15米,10米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/218-Japanese_Quad_20m-15m-10m.jpg[/img]
219 - 七元三角波束天线20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/219-7-Elements_Triangle_Beam_20m.jpg[/img]
220 - 对数周期天线线为40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/220-Log_Periodic_Wire_Ant_40m.jpg[/img]
221 - 三要素90度丝束20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/221-3-Elem_90deg_Wire_Beam_20m.jpg[/img]
222 - 两元丝束20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/222-2-Elem_Wire_Beam_20m.jpg[/img]
223 - 旅行箱飞度偶极子天线,80M,40M,20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/223-Suitcase-Fit_Dipole_Ant_80m-40m-20m.jpg[/img]
224 - 多频同轴偶极为80M,40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/224-Multiband_Coaxial_Dipole_80m-40m.jpg[/img]
225 - 垂直对数周期天线,80M,40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/225-Vertical_Log_Periodic_Ant_80m-40m.jpg[/img]
226 - 倒立式数周期天线的40米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/226-Inverted_Vertical_Log_Periodic_Ant_40m.jpg[/img]
227 - 双扩展策普天线增益=7分贝的15米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/227-Double_Extended_Zepp_Ant_Gain-7dB_15m.jpg[/img]
228 - 双懒惰-H天线,G =10分贝的70厘米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/228-Double_Lazy-H_Ant_G-10dB_70cm.jpg[/img]
229 - 线对数周期天线,G =12分贝为15M,20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/229-Wire_Log_Periodic_G-12dB_15m-20m.jpg[/img]
230 - 五元素垂直对数周期为80M,40M,20米
[img]http://www.qsl.net/va3iul/Antenna/Wire%20Antennas%20for%20Ham%20Radio/230-5-Elem_Vert_Log_Periodic_80m-40m-20m.jpg[/img]
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线7月7小雪
只看该作者 4楼 发表于: 2014-09-05
离线BG6AZJ
只看该作者 5楼 发表于: 2014-09-05
眼都花了,模拟了一个,不对劲啊
小概率事件往往是最低级的疏忽和缺陷造成的。
离线BH4rrg
只看该作者 6楼 发表于: 2014-09-05
真多啊,可惜有些看不到。
BH4RRG       CSKC#219
常用DX信息网站:
http://new.dxsummit.fi/
http://www.425dxn.org/
http://dx-world.net/
离线bg1tcs
只看该作者 7楼 发表于: 2014-09-05
这个比较牛啊
离线BG6QCB
只看该作者 8楼 发表于: 2014-09-05
好多哪一种好做。
莱鸟
BG6QCB
E-mail;BG6QCB@126.com
           BG6QCB@tom.com
QQ.   151772849
13707155268
离线bg2wrj
只看该作者 9楼 发表于: 2014-09-05
QQ:1232423       微信:f1232423
QTH:辽宁-大连
离线bg2ano
只看该作者 10楼 发表于: 2014-09-05
很好 以前也收藏过一个
mini SW2013      BA6300
离线bh4cbv
只看该作者 11楼 发表于: 2014-09-05
闲鱼:BH4CBV的小环天线
抖音:BH4CBV
离线bg5oe
只看该作者 12楼 发表于: 2014-09-06
好东西
姓名:李洪庆  呼号:BG5OE
手机:腰587906久久久6        QQ:腰腰617988
离线小朱
只看该作者 13楼 发表于: 2014-09-07
楼主辛苦了,好多天线做个了解。昨天架台,感觉还是倒V好用,特别是14M和21M的,尺寸很小,支撑杆不高,通联效果还可以。
呼号:BG6BPH
QQ邮箱: 464139795@QQ.COM
QTH:安徽省chuzhou
只看该作者 14楼 发表于: 2014-09-07
离线bd4igh
只看该作者 15楼 发表于: 2014-09-08
楼主大好人,谢谢分享!
王安林
山东.日照
曾用呼号BG6AG
安徽境内首个业余台
QQ:317311229
手机:13376330683
Email  :wal 696@163.com.
离线weed
只看该作者 16楼 发表于: 2014-09-08
没看到磁环天线在列!
姓名: 方启旸 (旸:Yang)
联系电话:13798809718
E-mail: fangqy112@sina.com
E-mail: fangqy112@qq.com
离线BD0AAI
只看该作者 17楼 发表于: 2014-09-09
楼主辛苦了, 收藏
de BDØAAI 73
离线电离层
只看该作者 18楼 发表于: 2020-03-23
BG2ALB
离线bd2mc
只看该作者 19楼 发表于: 2020-03-24
星空的闪电
QQ:327755217
E-maill:bd2mc@qq.com
QTH:
邮编:
