  • 4868阅读
  • 14回复
同志们,团购啦。 [复制链接]
离线ROBOT
只看楼主 倒序阅读 0楼 发表于: 2014-08-19
Section 6 – SPECIFICATIONS AND TECHNICAL DATA
SPECIFICATIONS
GENERAL
Frequency Range RX: 100 kHz – 30 MHz and 48 – 54 MHz. Specifications should
apply within Amateur Radio bands only.
Frequency Range TX: 1.797-2.010, 3.495-4.005, 5.275-5.407, 6.995-7.305, 10.095-
10.155, 13.995-14.352, 18.063-18.170, 20.995-21.452, 24.885-
24.995, 27.995-29.702, 49.995-54.0 MHz.
Tuning Step Sizes: 1, 10, 100, 1k, 5k, 10k, and 100 kHz.
Frequency Stability: Maximum +/- 0.5 PPM over operating temperature. TCXO
standard.
Rated RF Load: 50 ohms nominal.
Antenna Jacks: 2 x SO-239 transceive, 1 x SO-239 receive only.
Modes: USB, LSB, AM, FM, CWUSB, CWLSB, FSK.
I-Fs: 1
st: 70 MHz, 2
nd: 455 kHz, 3
rd: 14 kHz.
NTIA Compliance: Meets requirements for frequency stability, not in compliance for
occupied bandwidth.
Display: STN transmissive color LCD display with CFL backlight, 320 x
240 pixels.
PC control ports: Serial, EIA-232 standard, DB-9F. Integrated 10 mb/s Ethernet,
CAT5 or CAT6, RJ-45.
Supply Voltage: 13.8 Vdc nominal. Reverse-polarity and over-voltage protection
standard.
Operating Temperature Range: 0-50 degrees Celsius.
Dimensions (HxWxD): 5.0” x 12.0” x 14.75”. Depth measurement includes rear panel
heat sink.
Weight: 15.4 lbs. (7 kg).
Construction: Aluminum chassis, steel cabinet, glass-epoxy printed-circuit
boards.
RECEIVER
SSB Sensitivity: <0.18 uV typical for 10 dB SINAD at 2.4 kHz BW, pre-amp on.
<0.5 uV typical for 10 dB SINAD at 2.4 kHz BW, pre-amp off.
AM Sensitivity: <2.5 uV for 10 dB SINAD at 6 kHz BW, 30% modulation, 1 kHz,
pre-amp off.
FM Sensitivity: <2.5 uV for 12 dB SINAD at 20 kHz BW, 3 kHz deviation, 1 kHz,
pre-amp off.
Selectivity, IF1: at 70 MHz, 20 kHz
Selectivity, IF2: at 455 kHz, 20, 6, 2.5 kHz standard, 500 Hz, 300 Hz, optional.
Selectivity, DSP IF: 38 built-in DSP filters from 200-12000 Hz BW.
离线ROBOT
只看该作者 1楼 发表于: 2014-08-19
离线BG5EIB
只看该作者 2楼 发表于: 2014-08-19
骚机真多
离线BD6QBQ
只看该作者 3楼 发表于: 2014-08-19
万能的宝上有:http://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.93.S0M8Fk&id=37101826857 ;该机可以直接插上网线远程遥控的。
[ 此帖被BD6QBQ在2014-08-19 22:36重新编辑 ]
湖北省武汉市  QQ:1311997913
离线BG9TX
只看该作者 4楼 发表于: 2014-08-19
围观!!!!!!
青海 西宁
☎:13909791632
离线BG3UBC
只看该作者 5楼 发表于: 2014-08-19
离线bg3uda
只看该作者 6楼 发表于: 2014-08-20
顶起来
BG3UDA   醋都清徐欢迎你!
设备:ICOM-7300  FT-891  FT-1000mp   FT-8900   N76   TH-F6A  FT3DR
天线:正V750  7段蛛网 2段倒V  清徐中继: 439.300-8 亚音88.5 (p25)
邮箱:121457062@qq.com   电话:18635586388
操作证:C0000000081
地址:www.qrz.cn
只看该作者 7楼 发表于: 2014-08-20
第三中频14k
离线conjuring
只看该作者 8楼 发表于: 2014-08-20
2500美元
QQ:2795 022三6
离线BG2KTQ
只看该作者 9楼 发表于: 2014-08-20
怎么团购。团购多少钱
离线BG2KTQ
只看该作者 10楼 发表于: 2014-08-20
怎么团购。团购多少钱
离线enzosuhoi
只看该作者 11楼 发表于: 2014-08-20
啥时候有手台团购呀
离线bg8gqt
只看该作者 12楼 发表于: 2014-08-29
万能的X宝上已经有啦2019。900软妹币。。。快去啊。
设备: TS-590S, IC-7410, FT-7900R
天线: 端馈, HB9CV 3单元
网上扒的一些资料: https://pan.baidu.com/s/1u2TIfq_HIrfVLw52ygiE8Q?pwd=qb89 提取码: qb89
离线husy
只看该作者 13楼 发表于: 2014-08-29
楼上的是坏淫
LOC:OL63na
离线BH4JQR
只看该作者 14楼 发表于: 2014-08-30
内容感觉不错
BH4JQR
山东.东营
QQ:346198156
16725117@163.com
