  • 3488阅读
  • 6回复
Logging Morse Runner with N1MM  这个怎么玩啊? [复制链接]
离线bh1cuo
只看楼主 倒序阅读 0楼 发表于: 2014-06-26
离线BD1GO
只看该作者 1楼 发表于: 2014-06-26
CUO老看着像插件,具体谁插谁就不知道了。
一会下载下来放YOUKU吧。好多人看不了的。
以前:BH1GXH
其它请到WWW.QRZ.CN查询
电话:13366276142
离线BD1GO
只看该作者 2楼 发表于: 2014-06-26
以前:BH1GXH
其它请到WWW.QRZ.CN查询
电话:13366276142
离线bg5jnt
只看该作者 3楼 发表于: 2014-06-26
可能在morse runner上加了插件,只要你输入呼号开头,相应的呼号就会自动匹配出来。
以QRPp CW QSO  为乐。
离线bg4hyk
只看该作者 4楼 发表于: 2014-06-26
加了猜呼号的,更接近实战了。
练习用,没意思,有害。
欢迎加入 快乐无线电GLHAM 224850911QQ群
离线BD8ADT
只看该作者 5楼 发表于: 2014-06-27
用N1MM带著MR,不会有时间去看猜呼号的窗口
QQ:....- 232.....68----.
QQ群号(Elecraft & MR) 113481874
E-Mail:bd8adt@qq.com
RIG:K three,FT-817,
FTM350R,FT-8900,FT1D,DJ-G7
离线BG6MGD
只看该作者 6楼 发表于: 2016-03-23
http://k7og.net/downloads/n1mm-to-morse-runner-connector/N1MM to Morse Runner Connector
I wrote a connector to mix N1MM Contest Logger and Morse Runner together. The program lets you log contacts from Morse Runner in N1MM. Setting up is easy. Install N1MM and Morse Runner. In N1MM, switch to CW mode. N1MM should not be connected to your rig so make sure none of the COM ports are set up for rig control. The N1MM entry window should have the words “CW Manual” at the top:
N1MM Entry Window Title
Start a new CQ WPX contest log. Be sure to enable the “Running” check box on the entry window. I also recommend using ESM mode in N1MM because Morse Runner works that way.
Run either the stand-alone version or the script version of the connector. Once you run the Autohotkey script, there will be a little H icon near the Windows clock.
Autohotkey Icon
开拓视野,开创未来,君子慎独,活在当下。
