  • 21766阅读
  • 49回复
超级靓!俄罗斯产SDR电台SUNSDR MB1 [复制链接]
离线BG6JJI
只看楼主 倒序阅读 0楼 发表于: 2014-06-09
关键参数**********************************************************************************************************************
Direct conversion in RX/TX mode, in HF/VHF bands
Frequency range 0-80MHz, 80-160MHz
Output power, nominal: 125W(HF), 30W(VHF)
High dynamic range of receiver: up to 119-120dB in the HF, and up to 114dB in the VHF.
Basic version: 2500 EURO (without options).
Full version: 3000 EURO (with WiFi, GPS, ATU)
大致售价2000或3000欧刀,不同配置
链接http://www.sunsdr.com/en/forum/16-international-forum/6207-specs-on-sun-sdr-mb1.html
Besides transceiver features:
In the one box we have: Full PC(Mini ITX, Intel Core i7 CPU, full blown Windows 7 or Linux), 7" display, touch panel, with all the attendant features.
1. Installing digital communications software.
2. Contest loggers, magazines.
3. Internet browsing, internet clusters and other opportunities (e-mail,Skype, ICQ, TV... ) associated with internet.
4. Viewing and listening audio files.
5. Watching TV via USB-TV receivers.
6. And a lot of others, everything just limited by your fantasy.
In the first model of SunSDR-MB1 will be the next features:
Software: ExpertSDR (own software)
Supported OS: Windows All versions, Linux, in future MAC OS.
Frequency range 0-75MHz, 95-155MHz
Wide band spectrum panadapter up to 80MHz
Two independent receivers
Full duplex mode (depends on software, will available in a new versions of software)
High dynamic range of receiver: up to 120dB in the HF, and up to 116dB in the VHF.
Output power: 125W(HF), 60W(VHF)
IMD3 DR of transmitter, -35dB...-30dB (can be improved by software up to -60dB)
Predistortion of TX signal: will available later(depends on software)
ATU: Available as option.
Reference 10 MHz input
Very small CW delay: 10ms
ADC sample rate: 160MHz
ADC resolution: 16 bit
IMD3 DR, in-band: 100 dB
DUC sample rate: 640MHz
DUC resolution: 14 bit
High perfomance 24 bit Codec on board
Power supply: AC 110...220V 50...60Hz, 1A(RX)/2A(TX)
Weight: 9 Kg
Inputs/outputs:
VHF antenna connector(SO239)
Two HF antenna connectors(SO239)
Wide RF input port direct connect to high speed ADC(SMA)(for XVTRX, measurement etc.)
Wide RF output port direct connect to DUC(SMA)(for XVTRX, measurement etc.)
Reference 10MHz input connector(SMA)
ALC input port(RCA)
PTT input port(JACK 6.3mm)
CW Key input port(JACK 6.3mm)
External Control port with 8 power switch and RS-485 interface(D-SUB-15)
External control 2 port for Stealth Antenna 9310.
PTT output ports for external PA control(RCA x4).
Electret Microphone input(line in)(JACK 6.3mm)
Dynamic Microphone input with PTT switch for MH-31(RJ-45)
Headphones output(line)(JACK 6.3mm)
Ethernet connector(RJ-45) for LAN.
USB 3.0 connectors (x4 + x2 on front panel).
Speaker/headphones connector from embedded PC's sound card(3.5 mm Jack).
Microphone connector from embedded PC's sound card(3.5 mm Jack).
Display port connector.
HDMI connector.
Power supply connector.
Ground connector.
这是早上@BG4DRL 推荐的,超级毒贩!
小图 | 大图 图片
  • 哈罗CQ火腿社区 - 设备 - 超级靓!俄罗斯产SDR电台SUNSDR MB1
本帖提到的人: @BG4DRL
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线BG6JJI
只看该作者 1楼 发表于: 2014-06-09
HDMI!!!!  USB3!!!!!!!这是要爽死的节奏啊
这是老款的面板,新的正在设计,上面已经有图了
新面板的视频
http://v.youku.com/v_show/id_XNzIzNzI3MTY0.html
[ 此帖被BG6JJI在2014-06-09 11:33重新编辑 ]
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线BH8BJO
只看该作者 2楼 发表于: 2014-06-09
是不是还在设计阶段?没上市?
离线yushiozzy
只看该作者 3楼 发表于: 2014-06-09
这个价格可以考虑啊 真可以考虑
离线BH8BJO
只看该作者 4楼 发表于: 2014-06-09
俄罗斯人比较能干,实在
离线BG6JJI
只看该作者 5楼 发表于: 2014-06-09
回 BH8BJO 的帖子
BH8BJO:是不是还在设计阶段?没上市? (2014-06-09 10:27)
下面丑一点的已经在卖了
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线BG6JJI
只看该作者 6楼 发表于: 2014-06-09
个人感觉比ICOM 7-00好玩
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线BG6JJI
只看该作者 7楼 发表于: 2014-06-09
里面就是台I7的电脑,可以一鸡搞定日志记录,机器操控等等,完全抛开另外一台电脑了,还能外接显示器,搞大屏幕!
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线BD6QBQ
只看该作者 8楼 发表于: 2014-06-09
整合了电脑的电台,各种应用都可增加啊。
湖北省武汉市  QQ:1311997913
只看该作者 9楼 发表于: 2014-06-09
MiniMini-990s
像软件名字一样ExpertSDR
离线BG6JJI
只看该作者 10楼 发表于: 2014-06-09
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
只看该作者 11楼 发表于: 2014-06-09
离线BG1PLA
只看该作者 12楼 发表于: 2014-06-09
so nb。。。
Old soldiers  never die,they just fade away.
离线see5588
只看该作者 13楼 发表于: 2014-06-09
这个不错!
BG7BVP  王宏
EMAIL:7863857@QQ.COM
QQ:7863857
TEL:18907348623
只看该作者 14楼 发表于: 2014-06-09
太强大了。
只看该作者 15楼 发表于: 2014-06-09
ICOM,KENWOOD.YAESU看来要彻底玩完
离线BG6JJI
只看该作者 16楼 发表于: 2014-06-09
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线ROBOT
只看该作者 17楼 发表于: 2014-06-09
好东西。
离线bd3cb1
只看该作者 18楼 发表于: 2014-06-09
组织团购吧。
呼号:BD3CB
姓名:赵学亮
电话:13388029229
地址:天津市津南区咸水沽镇南洋村
邮编:300350
只看该作者 19楼 发表于: 2014-06-09
终于走到这—步了~比我预想的还快~
