  • 5011阅读
  • 7回复
关于解决N1MM实时上传到CLUBLOG出现错误的解决方案 [复制链接]
离线BG8FT
只看楼主 倒序阅读 0楼 发表于: 2014-04-29
http://www.hellocq.net/forum/read.php?tid=330064
该贴中ALC介绍的软件有很多朋友安装以后,软件不能上传(包括我)。试了很多办法,也没能解决问题。
最终EMAIL软件作者。
答案是:安装KB973685更新包。
感谢BA4ALC和BG6JJI在解决问题中的帮助。
VY  73
[ 此帖被BG8FFE在2014-04-29 08:52重新编辑 ]
QQ:1914358
18908210888
离线BA5CW
只看该作者 1楼 发表于: 2014-04-29
楼主认真执着,
离线BG6JJI
只看该作者 2楼 发表于: 2014-04-29
真执着~~!
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线bg3upa
只看该作者 3楼 发表于: 2014-04-29
佩服
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
离线BG6JJI
只看该作者 4楼 发表于: 2014-04-29
已下载  KB973685更新包,但是安装时出现错误,看来我需要打的补丁还有很多啊
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线BG6JJI
只看该作者 5楼 发表于: 2014-04-30
(A). The issue occurs when msxml4.dll doesn't get updated properly.
1. Remove the security update Kb954430 from Programs and features in Control Panel by clicking on View Installed Updates.
2. Delete the Msxml4.dll and Msxml4r.dll file from the location %SystemRoot%\System32 folder.
3. Download and Install the patch kb954430 manually from safe mode the link below:.
http://www.microsoft.com/downloads/details.aspx?FamilyId=96a4413c-5261-4f69-83d0-932c430abd14&displaylang=en
(B). Boot in safe mode.
I would suggest you to boot the computer in safe mode and check if the you face similar issue
Steps to boot to safe mode:
1. Restart the computer.
2. Immediately after the screen goes blank for the first time, or after the BIOS post ends.
3. Start taping the F8 key repeatedly. The Windows Advanced Options menu appears.
(If the menu does not appear, restart the computer and try again. If the Keyboard has a F-Lock key, it may be necessary to press it first - QUICKLY before pressing the F8 Key. This will have to be done quickly before tapping the F8 key repeatedly.)
4. Select safe mode and press enter
5. Try booting to the desktop
Start your computer in safe mode
http://windowshelp.microsoft.com/Windows/en-US/Help/323ef48f-7b93-4079-a48a-5c58eec904a11033.mspx
Then Install the updates in safe mode and check if it works.
Hope it helps
Thanks and regards
Dinesh-Microsoft Support
Visit our Microsoft Answers Feedback Forum and let us know what you think
http://social.answers.microsoft.com/Forums/en-US/answersfeedback/threads/
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线BG6JJI
只看该作者 6楼 发表于: 2014-04-30
由于 MSXML 4.0 是在并列模式下安装的,因此 MSXML 4.0、MSXML 4.0 SP1 和 MSXML 4.0 SP2 的安全更新 927978 不支持完全删除此版本的 MSXML。要变通解决此问题,请按照下列步骤操作:
1. 使用“控制面板”中的“添加或删除程序”项删除安全更新 927978。
2. 从 %SystemRoot%\System32 文件夹中删除 MSXML4.dll 文件。
3. 使用“控制面板”中的“添加或删除程序”项修复 MSXML 4.0 的早期版本。
早期版本的 Msxml4.dll 和 Msxml4r.dll 文件将还原到 %SystemRoot%\System32 文件夹及其并列文件夹中。
• 当从 Windows Update 安装此安全更新时,可能会收到以下错误消息:
无法注册文件 c:\Windows\system32\msxml4.dll 的类型库。请与您的技术支持人员联系。
发生此错误时,您还可以在日志文件中看到类似于以下内容的信息:
错误 1911。无法注册文件 c:\Windows\system32\msxml4.dll 的类型库。请与您的技术支持人员联系。
MSI (s) (20:18) [17:52:31:612]: 产品: MSXML 4.0 SP2 (KB927978) -- 错误 1911。无法注册文件 c:\Windows\system32\msxml4.dll 的类型库。请与您的技术支持人员联系。
=== 日志记录停止时间: 11/10/2006 17:53:07 ===
MSI © (34:20) [17:53:07:252]: 注释: 1: 1708
MSI © (34:20) [17:53:07:260]: 产品: MSXML 4.0 SP2 (KB927978) -- 安装失败。
MSI © (34:20) [17:53:07:267]: Windows Installer 已安装该产品。产品名: MSXML 4.0 SP2 (KB927978)。产品版本: 4.20.9839.0。产品语言: 1033。安装成功或错误状态: 1603。
MSI © (34:20) [17:53:07:313]: 捕获到执行互斥关系。
MSI © (34:20) [17:53:07:319]: 如果存在任何已卸载的安装程序包,请进行清理
MSI © (34:20) [17:53:07:331]: MainEngineThread 将返回 1603
=== 详细日志记录停止时间: 11/10/2006 17:53:07 ===
要变通解决此问题,请从 Microsoft 下载中心手动安装该安全更新,并在显示错误消息时单击“忽略”。要确认安装是否成功,请验证 %systemroot%\System32 中的 Msxml4.dll 文件的版本是否为 4.20.9841.0。
• 安全更新程序包 927978 可能会创建一个日志文件。该程序包将该日志文件命名为 KB927978.log,并将其保存在某个文件夹中。该文件夹具有系统生成的名称,并位于系统驱动器的根目录下,其路径类似于以下内容:
C:\system generated name\KB927978.log。
注意:在本示例中,C 为系统驱动器。
虽然是可选的,但您可以删除该日志文件和文件夹。
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
离线bg3upa
只看该作者 7楼 发表于: 2014-04-30
在楼主的帮助下顺利完成安装。
QQ:1124652397
山西省太原市万柏林区
设备: TS-590S
天线:80米倒V+18E。
