  • 7123阅读
  • 2回复
这个价位如何? [复制链接]
离线神秘色彩
只看楼主 倒序阅读 0楼 发表于: 2014-04-03
朋友正在美国,刚给穿的资料。
BD4ITM
我的微博: https://weibo.com/u/2243489255
拥有一颗平常心·健康快乐每一天
离线神秘色彩
只看该作者 1楼 发表于: 2014-04-03
You are looking at the 392m HF mobile/portable antenna system. Over the past 3 years of testing many improvements have been made,
the best being our CNC machined parts! This antenna can take a beating! I along with others use this antenna on the top of the vehicle, open to all kinds of abuse from trees to drive-through's! Also, the tap wire connections have been put through the test as well. You will not
need to worry about replacing this antenna for a very long time.
    The idea for this antenna was conceived during the replacement of a gear motor for a "screwdriver" style mobile antenna. This was the third time replacing the motor. I also had replaced the beryllium contacts several times along with the drive. We thought "Wouldn't it be nice
to have a mobile antenna that can cover 80m through 10m CONTINUOUSLY without gaps with no internal moving parts to wear out? It would need to cover the entire range so that it will be friendly to CAP or MARS operators as well as marine frequencies. It needed to be easy
to mount without special brackets or guy wires such as the ones used with many screwdriver antennas. Also, it needed to use the standard 3/8 x 24 thread mounts that are so common and diverse. How about water proof? Yes, it needed to be unaffected by the elements
of everyday driving and extreme weather conditions and easy to keep in working order.
    Well, here it is, now sold all over the world and even reviewed by Gordon West himself in Popular Communications magazine! This is a "no nonsense" HF mobile/portable antenna system that is all of the above! There are other "band tap" style antennas on the market such as
the Outbacker and Opek, but this antenna is different, not only does it cover the entire frequency range (not just certain bands), but it does it with more efficiency and it looks better while doing it! It will also cover 6 meters when you shorten the adjustable whip provided. How
about power handling? This will handle 600 watts of power, more than most mobile installations. This comes at a cost far less than the complicated "screwdrivers". This is a RESONANT antenna system! In other
words, this is not one of those "no tune" antennas. If you see an antenna that claims to work on all frequencies without tuning, don't be fooled! Those antennas do work and you can make contacts with them, but they do not come close to the efficiency of a similar sized resonant antenna.
They have a transformer at the base of the antenna that is more like a dummy load with a whip on it.
    Here are some reviews from our customers, I have many more and will be posting them in due time.
     Just wanted to say hello, and to let you know your antenna coil is performing beautifully on my setup and is now proudly displayed on QRZ dot com. Thanks again for such a quality and well performing product! - 73 from KF4GOQ
     "I recently bought one of your 392M antennas through EBay.  I have it installed on my Chevy Trailblazer using a Comet RS-480 "lip" mount on the top of the rear driver side door.  I found the antenna very easy to get matched and working on 40-10 meters, which were the only bands that I was really interested in.  I realize that the Comet is not an ideal mount but it is what I was using with Hamsticks.  I found that I could tune the antenna without a matching coil, which I am sure confirms that my mount is not the best, but the antenna is working great without it.
I have worked in to Europe on 20 and 17 meters from here is Wisconsin and gotten 59 signals reports.  I have also worked from coast to coast here in the USA on 20 and 17 meters.  I also worked Europe on 40 meters.  In comparing the 392M to Hamsticks it seems it "hears" about the same but it seems that I am getting better signal reports and it is very convenient to have one antenna instead of carrying a bunch of hamsticks!
I will try to get some comparison reports using your antenna and Hamsticks but I am sold on this antenna.  I will be looking forward to your web site and as I operate mobile I will try to point other hams to your web site.
Thanks for a good product.  Before I bought your antenna I bought a similar multi-tap antenna that MFJ just introduced.  I found that their advertising was very misleading the antenna was several feet shorter than advertised and every time you changed bands not only did you have to change the taps but you also had to readjust the whip.  I have set this antenna up for 6 meters and that is all I will be using it for.
If there was any thing that I would have liked to have seen with your antenna was the ability to tune it for 6 meters."
Thanks again,
Don Solberg
K9AQ.
Also check out Jason Gant W^AUX's web page for a review of the antenna with him and Gordon West.
Here are some specs....
All stainless steel hardware
All coil connections are wrapped then soldered for strength
Tap connections are solid brass
Uses standard mobile mounts with 3/8 x 24 thread
Coil is 12.0" x 1.5" Power handling 600 watts PEP SSB
Adjustable from 6' to 9' total height, then just use the taps for frequency adjustment.
One final note....    I have been building antennas for a long time. I have been a ham since I was 15 years old and have never lost interest in the hobby. Ham radio is a "people" hobby where they help one another and learn from others. I consider myself very lucky to be able to earn a living through my passion. If you have a question or problem PLEASE contact me and I will work with you to get the most out of your HF set up. Rarely, someone needs help to get things working properly, HF mobile can be very tricky and your installation much more critical than that of VHF and UHF.    My point is... I will do everything in my power to make this a good experience for you! So keep in touch! Go down the list in my feedback, there are many people who love the antenna and are amazed at it's performance! Yes, on 40 and 75 meters as well, not just the "easy" bands. Thank you for considering this design for your mobile or portable use. (and at home for those HOA's!!!) 73!
BD4ITM
拥有一颗平常心·健康快乐每一天
离线BD6MM
只看该作者 2楼 发表于: 2014-04-03
