  • 4468阅读
  • 1回复
IC-7800 固件升级 Ver. 3.01 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-03-28
Ver. 3.01
2014/03/28
下载地址:JP版
http://www.icom.co.jp/support/download/firmware_driver/data/7800_301.exe
请到USA地址下载最新固件
http://www.icom.co.jp/world/support/download/firm/IC-7800/3_01/
Improvement
Improved remote control of the IC-7800, without needing a Base (server) PC. (RS-BA1 version 1.60 or later required.)
- Improved to prevent voice skip when a network delay and/or high packet loss occurs.
- Improved to prevent voice delay.
•Thoroughly read Section 16 (UPDATING THE FIRMWARE) of the instruction manual (here) for details of what the update requires.
•Backup your transceiver's data onto a CF card as it is possible that your data could get lost or corrupted during the update.
•Never turn OFF the transceiver power during the update.
•The firmware update utility is necessary when updating the firmware through a LAN. Download the utility here.
Control software (Ver.1.60)
Improvements
1.Compatible with the IC-7700 version 2.00 or later firmware.
2.Improved to prevent voice skip when a network delay and/or high packet loss occurs.
3.Improved to prevent voice delay.
Note
• When you use the RS-BA1 with a USB 3.0 device, you must use a USB 3.0 driver. Download the driver here.
• RC-28 firmware version 1.01 or later is required for the RC-28. Download the firmware here.
• When you update the control software: 1.Download and expand the Rsba1_up_ver160.zip.
2.Double-click Update.exe to start the software update.
3.Follow the instructions displayed on the screen.
• You must have a previous version of the RS-BA1 software installed BEFORE you can update to version 1.60.
CAUTION
• The Recover_Setup_Rsba1.reg file is included in the Rsba1_up_ver160.zip. Execute the Recover_Setup_Rsba1.reg file ONLY if you need to reinitialize the RS-BA1's settings.
http://www.icom.co.jp/world/support/download/firm/RS-BA1/1_60/Rsba1_up_ver160.zip
[ 此帖被BG4DRL在2014-03-28 13:39重新编辑 ]
离线bh7ni
只看该作者 1楼 发表于: 2014-03-28
bh7ni,在深圳的安徽人
孔雀-电台ECU交流群(QQ群):463833393
深圳科技园模拟中继438.025,-5,88.5
