  • 6231阅读
  • 1回复
RS-BA1 Ver1.50到Ver1.60升级 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-03-28
下载地址 JP
http://www.icom.co.jp/support/download/firmware_driver/data/Rsba1_up_ver160.exe
Control software (Ver.1.60)
Improvements
1.Compatible with the IC-7700 version 2.00 or later firmware.
2.Improved to prevent voice skip when a network delay and/or high packet loss occurs.
3.Improved to prevent voice delay.
Note
• When you use the RS-BA1 with a USB 3.0 device, you must use a USB 3.0 driver. Download the driver here.
• RC-28 firmware version 1.01 or later is required for the RC-28. Download the firmware here.
• When you update the control software: 1.Download and expand the Rsba1_up_ver160.zip.
2.Double-click Update.exe to start the software update.
3.Follow the instructions displayed on the screen.
• You must have a previous version of the RS-BA1 software installed BEFORE you can update to version 1.60.
CAUTION
• The Recover_Setup_Rsba1.reg file is included in the Rsba1_up_ver160.zip. Execute the Recover_Setup_Rsba1.reg file ONLY if you need to reinitialize the RS-BA1's settings.
http://www.icom.co.jp/world/support/download/firm/RS-BA1/1_60/Rsba1_up_ver160.zip
[ 此帖被BG4DRL在2014-03-28 13:39重新编辑 ]
只看该作者 1楼 发表于: 2014-03-28
我读书少  不要骗我
