  • 2888阅读
  • 2回复
IC-7700 没触摸用鼠标新固件 v2.0正式对外公布 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-03-26
Major points of the Ver.1.20 update.
1.Additional functions for CI-V commands (ex. CW message) are provided to support the RS-BA1.
2.A new additional feature, the Time-Out Timer (TOT) function.
•Please read IC-7700 Firmware update information-Ver. 1.20, if you want to know more detail information of additional functions.
•Please save the transceiver's data contents to an USB memory before starting the firmware update.
•Never turn the transceiver power OFF while updating the firmware.
•Please read through Section 16 (UPDATING THE FIRMWARE) in the IC-7700 instruction manual, before downloading the new firmware.
•Please also download Firmware update utility; 7700FirmUtl_v100.zip (225KB) when updating the firmware using a LAN.
下载地址
http://www.icom.co.jp/world/support/download/firm/IC-7700/2_00/
[ 此帖被BG4DRL在2014-03-26 21:25重新编辑 ]
只看该作者 1楼 发表于: 2014-03-26
只看该作者 2楼 发表于: 2014-03-26
