  • 3973阅读
  • 3回复
带LNA的ADE-1变频器 [复制链接]
离线BG0APD
只看楼主 倒序阅读 0楼 发表于: 2014-03-01
For Sale New Version 4.2 Precision HF UpConverter for RTL2832U / E4000 SDR Radio Dongle , RTL3832U  FC0013 R820T Funcube with  ADE-1DBM mixer + BGA614 LNA HF preamplifier
• two antenna inputs UHF and HF select switch, LED lights active input
   - middle SMA connector need connect to RTL SDR tuner dongle antenna input
   - at a time two antenna connections
• News: Adjustable Local level, HF preamplifier gain, and Output level optimized settings for SDR tuner
• High sensitivity converter
• The USB A and USB mini B connectors for +5V power supply
• Local frequency: 100.0000 MHz (sine)
• High-precision local oscillator
• Operating frequency is 100KHz to 54MHz
   - 1.8MHz = 101.8MHz
   - 3.5MHz = 103.5 MHz etc.
• 3x good quality SMA connectors
•  PCB size 5cm x 3cm
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 1楼 发表于: 2014-03-01
邮箱:BG0APD@163.com
电话:15309910960
只看该作者 2楼 发表于: 2014-03-01
APD 好
55美刀买一张100Mhz的Ham it up吧 尺寸大一点 效果看似乎还不错
离线BG0APD
只看该作者 3楼 发表于: 2014-03-01
回 BG4DRL 的帖子
BG4DRL:APD 好
55美刀买一张100Mhz的Ham it up吧 尺寸大一点 效果看似乎还不错 (2014-03-01 22:36)
Ham it up V1.2 好像不带LNA,价格比$55便宜
邮箱:BG0APD@163.com
电话:15309910960
