  • 12080阅读
  • 12回复
LNA for all - Low Noise Amplifier for many applications from 28 MHz to 2500 MHz [复制链接]
离线BG0APD
只看楼主 倒序阅读 0楼 发表于: 2014-02-25
Are you looking for the cheap multipurpose preamplifier? HAM radio, DVB-T, ATV, SETI, ADB-S, Air traffic and many more applications all in one PCB, "turn the key" solution.
Low noise and low price amplifier that can find his place in many applications is ready. When I said low noise I mean the noise figure that is lower or equal to 1dB over all range. The LNA is covering all bands starting from HF up to the SHF. Wide band gain coverage starting from 28 MHz and extending up to 2500 MHz. One LNA for all frequencies and more. This small gadget can lower and improve you DVB-T SDR stick noise figure and improve the sensitivity. Adding the LNA in front the front end of your receiver can open another dimension in your reception. Receiving HAM radio satellites should not be a problem even with the small setup and portable antennas.
The amplifier is built around Mini-Circuits PSA4-5043+ E-PHEMT Ultra Low noise MMIC amplifier operating from 50 MHz to 4 GHz. Small SOT-343 package combine low noise and high IP3 performance with internal match to 50 ohms. Manufacturer declare a 0.75dB NF @ 1 GHz and 0.98dB NF @ 2 GHz with IP3 value reaching 33.5dBm. Beside the LNA purpose the same component can be used as a small driver amplifier capable of delivering +21dBm of output signal thanks to high P1dB value. The last but very handy feature is Class 1B ESD protection incorporated on die making this device easy for handling.
Even the price is very popular the performance of the LNA4ALL can be compared with the really expensive LNA in range on the market. We made a several independent lab measurements just to prove the quality of the product and thanks to all this guys we do have some relevant figures. One of the measurements is the TOI (Third-order intercept point) or widely known IP3 done by Thomas, DG1TRF. The TOI/IP3 graph was derived from the automatic measurements sweeping the range from 10 MHz to 3.5 GHz in 10 Mhz steps. The average TOI/IP3 is 34.75 dB over the range.
The above graph was derived from the single measurements like the one bellow on the 1296 Mhz. Following the markers it is easy to calculate the TOI/IP3 but even easier if you have the machine showing all the results for you.
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 1楼 发表于: 2014-02-25
Thanks to Joost from the Netherlands we do have the latest batch S parameters measurement. As can be noticed, the S1,1 is not good at the lower frequencies but for that we do have the LNA4HF designed for the lower bands.
The LNA is made on professionally made printed circuit board measuring 25x25 mm that can be used also for the other active components using the same SOT-343 package and pin out. There is enough place to combine the input and output matching components on the same board, as well as the bias resistors and various bias configuration. The 500mA 5V voltage regulator is integrated on the board where any voltage from 6 V to 12 V DC can be used for the supply. The consumption is between 50 mA and 60 mA.
Turn the key solution is delivered with the standard female SMA connectors insuring stable operation over all range of frequencies. Experience users and builders may prefer the version without SMA connectors in order to house the LNA into the proper aluminum milled box or other metal housing. We predict also this scenario ensuring the 3 mm dia. holes for tight connection. The ground loops and not a proper grounding is a common mistake among the home brewers all leading to unstable LNA operation and self-oscillations. If you plan to use the LNA this way we prepare also the holes close to the SMA connectors as well to overcome possible problems.
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 2楼 发表于: 2014-02-25
If you already experience the quality of our ideas upconverter up-100 then you know what we are talking about. Enjoy your radio !
The basic setup, what you get when you buy the LNA4ALL is presented on the next slide. The LNA4ALL tested and checked, ready for 6-12 V DC supply. The latest PCBs are "gold" color and the 5V voltage regulator is AMS1117-5V0 instead of the very first version where the 78M05 was used. C10 capacitor is also fitted despite the fact that this is the part required for the optional through the coax power supply.
The most asked modification is a 5 V DC supply possibility. It is very easy to do that just by adding the 0 ohm 0805 SMD size bridge or just a peace of wire on the place marked J3 on the PCB (green colored SMD component on the next slide). Using the same power leads you can power the LNA4ALL now with the 5V DC. We do not supply extra parts for modifications any more.
Next most common modification is possibility to supply the LNA4ALL from the 13.8V DC power supply. The voltage regulator on board should meet this request, but it is much safer to run the LNA through the simple 100 ohms resistor in series with the positive power lead. You should rate the resistor power based on the fact that the LNA consumption is 60 mA. 1/2 watt resistor should do the job as per next slide.
One of the feature requested from the users was the so called "phantom power supply" through the bias-T configuration. To supply the LNA4ALL with the DC power through the coaxial cable from the receiver or bias-T close to the receiver just a simple add-on is required. The 10uH SMD 0805 size inductor should be placed on the place marked L2 close to the OUT  SMA connector. The PCB can accommodate also 0603 and 1006 SMD standard inductor. (Green color on the next slide). The power should be anything from 6-12V DC. We do not supply any more the 10uH inductor nor the bias-T unit.
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 3楼 发表于: 2014-02-25
And what if you have available only 5V DC on the antenna port of your receiver. (I think the FunCube Dongle have this option, or not ??) In that case, the same modification from the previous slide is required (10uH inductor on the place L2) plus the 0 ohm 0805 SMD size resistor or a wire bridge on the place marked J3. Now you can power your LNA4ALL with the 5V through the coaxial cable.
Another very common question is how to protect the LNA from the statics coming from the antenna. We do receive some letters indicating the problem where the MMIC is damaged due to statics or corona discharge effect on the antenna constantly connected to the LNA. So how to protect the LNA? The best way is to disconnect the antenna and before connecting the same back, properly ground and discharge the antenna.
This can not be always possible and handy so the only protection that is used widely is to bridge the input antenna with the BAV99 antiparalel pair of diodes like on the next slide. This may save your LNA but not from the direct thunder hit :-)
The solder mask should be scratched off and the BAV99 diode soldered (green on the next slide) on the antenna input. Using the antiparalel diodes will degrade NF and S11 a bit and there is a treat of the intermodulation products created on the diodes if the strong broadcast signals are present on the antenna. So beware of this facts.
邮箱:BG0APD@163.com
电话:15309910960
离线jxj
只看该作者 4楼 发表于: 2014-02-26
又一个DIY利器!
http://sdr-x.github.io  技术博客 软件无线电 LTE ADS-B GPS HACKRF BLADERF RTL2832 RTL-SDR
离线BG0APD
只看该作者 5楼 发表于: 2014-02-27
回 bm2caj 的帖子
bm2caj:NF 與 混調變怎麼樣 ?
 (2014-02-27 15:19)
邮箱:BG0APD@163.com
电话:15309910960
离线bd4igh
只看该作者 6楼 发表于: 2014-02-28
shigeishuikande?
王安林
山东.日照
曾用呼号BG6AG
安徽境内首个业余台
QQ:317311229
手机:13376330683
Email  :wal 696@163.com.
离线BG0APD
只看该作者 7楼 发表于: 2014-02-28
回 bd4igh 的帖子
bd4igh:shigeishuikande? (2014-02-28 10:47)
shuixuyaoshuikan.
邮箱:BG0APD@163.com
电话:15309910960
只看该作者 8楼 发表于: 2014-02-28
这么宽的带宽,绝对被本地FM,TV和手机基站阻塞
BD4AQR KF5GSV
离线BG0APD
只看该作者 9楼 发表于: 2014-02-28
回 老干部 的帖子
老干部:这么宽的带宽,绝对被本地FM,TV和手机基站阻塞 (2014-02-28 16:39)
老干部,看我这个,没发现阻塞,最少短波30MHz以下没发现。
http://www.hellocq.net/forum/read.php?tid=326561&page=2
邮箱:BG0APD@163.com
电话:15309910960
离线bd4igh
只看该作者 10楼 发表于: 2014-02-28
rangdajiadoukanmingbaiduohao
王安林
山东.日照
曾用呼号BG6AG
安徽境内首个业余台
QQ:317311229
手机:13376330683
离线BG0APD
只看该作者 11楼 发表于: 2014-02-28
邮箱:BG0APD@163.com
电话:15309910960
离线icom71e
只看该作者 12楼 发表于: 2014-03-01
  啥时候上市啊 某宝???
BG2DNS
