  • 2580阅读
  • 1回复
SDR-ONE.....A new little bird from RFSPACE [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-02-14
The SDR-ONE is a low cost, high performance transmit / receive module for
experimentation and integration into products.
The module can be used stand alone or plugged into other products.
It offers very high performance with the use of a 14 bit ADC/DACs.
The SDR-ONE RX/TX module offers 48,96 and 192 KHz receive bandwidths over I2S,
optical audio (S/PDIF) and IQ analog out. In addition, up to 40 KHz of BW
can be transmitted at a 48 Khz sample rate. The SDR-ONE sets the RX sample rate
of the sound-card when using the S/PDIF or I2S outputs. In TX,
I/Q signal is received via the IQ analog input or the I2S master port.
The FPGA and flash memory can be reprogrammed over the built in USB port in seconds
without the need of a special programming cable.
The FPGA UCF file and code examples are supplied for those willing to write their own code.
只看该作者 1楼 发表于: 2014-02-14
