  • 4179阅读
  • 5回复
the new version 4 of the microADSB-IP [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-02-09
Dear Madam,
We are glad to present you the new version 4 of the microADSB-IP receiver BULLION-4.
You are able to order it at our website www.microADSB.com
The new features are:
  >New metal box with very good seal (IP65) with through holes for mounting.
  >New IP controller, high speed 100MB/s, messages with greater intensity and minimum errors.
  >Special tool to adjust the network part using MAC address.
  >Replacing the switching regulators of supply with parametric regulator in order to reduce noise at the receiver. PoE supply voltage limited 7-9V, DC.
  >Antenna connector is soldered directly to the board.
  >Ability to work in USB connection mode and firmware upgrade.
You can download the User Manual from the following link:
ftp://46.40.125.13/User_Manual_v4.pdf
If you have any further questions, do not hesitate to contact us at support@anteni.net
Best regards,
Miro&Yavor
ANTENI.NET Ltd
office@anteni.net
www.microADSB.com
只看该作者 1楼 发表于: 2014-02-09
这个Madam好贵
只供大家观赏,
这类直下型的非常容易遭受感应雷 以及进水
想法是好的 只拖一根网线,还必须是屏蔽的网线
小小打击下开发者
只看该作者 2楼 发表于: 2014-02-09
没看懂(☆_☆)
离线BD7JAC
只看该作者 3楼 发表于: 2014-02-09
它是想学室外型AP那样,接收和天线做在一起减少馈线的损耗,通过网线的POE供电和连接到网络。
读万卷书心中不留一字,行千里路忘尽途中影子!
EX:BG7JAC、XX9TJC
OL51EG   TEL:棕橙紫黑红灰紫蓝蓝红灰
Email:bd7jac艾特chinaham.org
只看该作者 4楼 发表于: 2014-03-04
这件垃圾,山寨的手工...
我读书少  不要骗我
离线gxlice
只看该作者 5楼 发表于: 2014-09-26
应该还是pic那个板子吧。
