  • 3853阅读
  • 2回复
Bearcon基站APxxxx To Call 发信规则 By WB4APR [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-02-08
只看该作者 1楼 发表于: 2014-02-08
The currently defined q constructs are:
Server Generated:
•qAC - Packet was received from the client directly via a verified connection (FROMCALL=login). The callSSID following the qAC is the server's callsign-SSID.
•qAX - Packet was received from the client directly via a unverified connection (FROMCALL=login). The callSSID following the qAX is the server's callsign-SSID. This construct is in addition to the TCPIP*/TCPXX* construct currently in place. TCPXX and qAX have been depricated.
•qAU - Packet was received from the client directly via a UDP connection. The callSSID following the qAU is the server's callsign-SSID.
•qAo - (letter O) Packet was received via a client-only port, the FROMCALL does not match the login, and the packet contains either a ,I or qAR construct where the indicated IGate matches the login.
•qAO - (letter O) Packet was received via a client-only port and the FROMCALL does not match the login.
•qAS - Packet was received from another server or generated by this server. The latter case would be for a beacon generated by the server. Due to the virtual nature of APRS-IS, use of beacon packets by servers is strongly discouraged. The callSSID following the qAS is the login or IP address of the first identifiable server (see algorithm).
•qAr - Packet was received indirectly (via an intermediate server) from an IGate using the ,I construct. The callSSID following the qAr it the callSSID of the IGate.
•qAR - Packet was received directly (via a verified connection) from an IGate using the ,I construct. The callSSID following the qAR it the callSSID of the IGate.
Client Generated:
•qAR - Packet is placed on APRS-IS by an IGate from RF. The callSSID following the qAR it the callSSID of the IGate.
•qAZ - Packet is generated by the server/client/IGate and should not be propagated. The callSSID following the qAZ is the callSSID of the server/client/IGate. This is normally used for connection messages such as messages to USERLIST.
•qAI - Trace packet. This packet tells each server to add login identification to the packet. This packet starts with the callSSID of the originating station following the qAI. See algorithm for more details.
Client generated q constructs will be verified if a new authorization algorithm is created.
离线BH1IEO
只看该作者 2楼 发表于: 2014-02-08
看不懂,翻译一下呗
燕  巴  虎  开 始 玩 户 外 了
E-mail:1162846706@qq.com
QTH :未来火星人
Echolink Links Node:15668
WiRES-X Node ID:14231
WiRES-X Room:24231
ALLSTAR Links Node:28559
Echolink brought us into the 21st century
APRS:BH1IEO Home IGATE/Yaesu 1DR-5/Kenwood D72E-6/LM3G Mobile-7/GPRS APRS Mobile car-8/Yaesu 400DR Jeep Mobile-9/Mobile phone-12
