  • 5841阅读
  • 3回复
SDRstick HF1  HF2 TX 系列SDR [复制链接]
离线BG0APD
只看楼主 倒序阅读 0楼 发表于: 2014-01-25
BeRadioTM Digital Down Conversion SDR Receiver
100 kHz - 4MHz continuous coverage
LTC2225 12-bit @ 10MSPS ADC
30dB LNA and 2MHz LPF
On-board ferrite MW antenna with wire extension
12-bit @ 48KSPS audio DAC with headphone output
Power requirements: USB powered via BeMicro SDK
Uses BeMicro SDK for FPGA engine
BeRadio is no longer available
BeRadioTM MW Digital Down Conversion Receiver
[ 此帖被BG0APD在2014-01-25 18:29重新编辑 ]
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 1楼 发表于: 2014-01-25
UDPSDR-HF1
100 kHz - 30MHz continuous coverage
LTC2249 14-bit @ 80MSPS ADC
LNA and 30MHz LPF
SMA external antenna jack
Power requirements: USB powered via BeMicro SDK or external 5V@400mA
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 2楼 发表于: 2014-01-25
UDPSDR-HF2 SDRstickTM
100 kHz - 55MHz continuous coverage
LTC2208 16-bit @ 122.88MSPS ADC
LTC6400 20dB LNA
0-31dB step attenuator in 1dB steps
Low-phase noise oscillator: -152dBc/Hz @ 10kHz
External sine-wave input for GPSDO
Audio CODEC with headphone output
Power requirements: 5V@950mA
Customization available to suit specific applications
Price  $399
邮箱:BG0APD@163.com
电话:15309910960
离线BG0APD
只看该作者 3楼 发表于: 2014-01-25
UDPSDR-TX2 SDRstickTM
Digital Up Conversion Transmitter
Companion to UDPSDR-HF2 DDC SDR Receiver
output continuously variable to 500mW below 30MHz, 350mW above 30MHz
14-bit @ 122.88MSPS DAC
On-board T/R switching
Microphone, PTT and keyer paddle interfaces
Supplies microphone bias for electret microphones
Plugs directly into UDPSDR-HF2 receiver
Power requirements: 13.8VDC@500mA (including BeMicro SDK/UDPSDR-HF2)
Price $179
邮箱:BG0APD@163.com
电话:15309910960
