  • 16479阅读
  • 24回复
便当来了 ELAD FDM-DUO SDR 5W [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-01-15
厂商资料   FDM-DUO_Leaflet_1_ING_LO.pdf (346 K) 下载次数:39
       ADC Linear LTC2165-16bit 122.88MHZ clock
  DDC FPGA Spartan 6 XC6SLX25 + Serial Flash for stand-alone mode.
  USB IQ path through CY68013 for RX bitstream (192KHz up to 6.144Mhz single channel and 384KHz dual channel in PC mode)
  Stand-alone RX IQ path STM32F4 ARM floating point microcontroller
  LCD Controller Keyboard controller LPC1766 Cortex M3
  TX modulator use a second STM32F4 Floating Point microcontroller + AD9957 DDS clocked at 368,64 MHz
  Clocking source Si5338 drived by 10MHz TCXO or External reference input
  TX modulator use I2S sourcing from MIC input (Cirrus CS5346) or USB input (CODEC CM6510B with customized firmware)
  The third USB is a FTDI controller for CAT interface
  This versatile platform allow transceiving in stand alone mode or in PC mode or in dual mode.
  Frequency range: RX 9Khz to 52MHz direct sampling receiver
  TX 160m to 6m others frequency to be defined
  MDS: -132dBm
  BDR: +115dB (500Hz)
  Power output 5W
  There is available a secondary SMA connector output with 0dBm level for use or as generator
  open from 400Khz to 150Mhz (TBD)
  2m VHF RTX will be an option as a board to fit (TBD)
  The RTX have 2 Antenna inputs and can work as single RTX antenna or separate RX and TX antennas
  (selectable by front panel or by CAT)
  Standalone MOdes: CW CW+ CW- LSB USB AM
  Firmware upgrade:
  Cortex M3 by CAT
  CY68013 by PC
  STM32 RX or TX USB by memory stick through internal dedicated USBs
  FPGA by PC
  St-alone PROM TBD
  When working in ST-Alone mode it is possible to connect an Android tablet (for example a Samsung Galaxy) to see the 192KHz spectrum and send some commands to FDM-DUO. Connection is made done through USB host of the Android and a TTL FTDI cable to EXTio connector of FDM-DUO
  In dual mode PC software can show the 192KHz bandwidth of the FDM-DUO and it possible to demodulate with PC Software and with FDM-DUO with internal demodulator
  In PC mode the RX bandwidth may have up to 6MHZ and internal demodulator is disabled.
  This is a Software Defined Radio and these mode can be changed depending on new software that will be available from ELAD or for from who want to use Extio Dlls.
  For using existing programs like HRD and FLDIGI….It will be very simple to plug the USB for CAT and USB TX like an external sound card.
  FDM-DUO will be available also as Receiver only as FDM-DUOr name
  From aesthetic point of view the box will be available SIlver or Black.
  Price: 1159,00 Euro VAT included
  Availability: 2/2014
[ 此帖被BG4DRL在2014-04-08 01:24重新编辑 ]
只看该作者 1楼 发表于: 2014-01-15
FDM-DUO_Leaflet_1_ING_LO.pdf (346 K) 下载次数:33
离线BH1MNM
只看该作者 2楼 发表于: 2014-01-15
顶,很漂亮!
只看该作者 3楼 发表于: 2014-01-16
我读书少  不要骗我
只看该作者 4楼 发表于: 2014-01-16
cw+/cw-是微调啊
只看该作者 5楼 发表于: 2014-02-16
DUO spec
ELAD FDM-DUO Preliminay Specification
Front-end
MDS: -132dBm
BDR: +115dB (500Hz)
Power output 5W
use or as generator open from 400Khz to 150Mhz (TBD)
separate RX and TX antennas (selectable by front panel or by CAT)
Firmware upgrade:
Cortex M3 by CAT
CY68013 by PC
FPGA by PC
St-alone PROM TBD
Android
Pagina 1
DUO spec
demodulator
is disabled.
use Extio Dlls.
For using existing programs like HRD and FLDIGI…. It will be very simple
离线bg2iur
只看该作者 6楼 发表于: 2014-02-21
真漂亮
走我的路,关你鸟事!
离线husy
只看该作者 7楼 发表于: 2014-02-22
价钱的那个标点符号,是逗号还是点号?
LOC:OL63na
只看该作者 8楼 发表于: 2014-04-06
只看该作者 9楼 发表于: 2014-04-08
这机器 开卖就抢光
从本次S2验证的感受 感觉告诉我,这已经是毫无悬念
远超越Elecraft KX3 的可玩性
可以说是次时代SDR 发射机起步中的极端精品之作
推荐给喜欢KX3 有米的屌丝们
[ 此帖被BG4DRL在2014-04-08 01:20重新编辑 ]
只看该作者 10楼 发表于: 2014-06-28
屌丝撸过
只看该作者 11楼 发表于: 2014-06-28
强势围观,继续等待新品
离线BA7KW
只看该作者 12楼 发表于: 2014-06-29
有货吗?
BA7KW  张建华
BA7KW"at"163.com
离线husy
只看该作者 13楼 发表于: 2014-06-30
有人上钓了。
LOC:OL63na
离线bg9gxm
只看该作者 14楼 发表于: 2014-10-10
咋办。。。中毒了 好喜欢金属的感觉
印刷通联卡片随缘接单。主攻出版物和油标印刷:)
我个人为了支持BY VR2 XX9 BV Ham走出去
离线BH4rrg
只看该作者 15楼 发表于: 2014-10-10
回 bg9gxm 的帖子
bg9gxm:咋办。。。中毒了 好喜欢金属的感觉 (2014-10-10 01:22)
没办法,你只有把它办了吧
BH4RRG       CSKC#219
常用DX信息网站:
http://new.dxsummit.fi/
http://www.425dxn.org/
http://dx-world.net/
离线bg9gxm
只看该作者 16楼 发表于: 2014-10-10
回 BH4rrg 的帖子
BH4rrg:没办法,你只有把它办了吧 (2014-10-10 08:59)
......好机器要配合好天线才行。。。
离线BA5CW
只看该作者 17楼 发表于: 2014-10-10
7月份在ARRL展会上,很想买一个带回来的,想想已经超重了的行李,就没有下手,不过我估计当时也未必有现货
离线wallyzh
只看该作者 18楼 发表于: 2014-10-12
好几,口水
呼号:BI7MBU
QQ:119551081
EMAIL:wallyzh@163.com
只看该作者 19楼 发表于: 2014-10-12
有人耐不住了
