  • 2497阅读
  • 1回复
[NaP3] NaP3 V2.7 Working Great! [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-01-12
A new version is available with a rewritten Help file with more graphics and detail, including an Initial Setup section which can be read standalone as How to set up NaP3 in the NaP3 Files section. Following this should provide the basis for trouble-free operation.
v2.7.0 is the usual result of a four-way tug of war: the ‘power users’ who want everything that can be changed to have a control to adjust (which will confuse novice users), the ‘novice users’ who need something which is as close to plug’n'play as possible (which frustrates power users), the ‘display-only’ users (who want as few controls as possible) and the ‘I want a software sub-receiver’ users (who need a range of dsp functions to hand).
As ever, it is handling sound cards, specifically the E-MU 0202/4 family, that has taken up most development time. These are capable of wide divergence from useful settings. In addition to the trapping and warning messages of unacceptable absolute levels in previous releases, v2.7.0 will enable these cards to set their inconveniently high output more accurately with a control that overrides the Windows mixer. There is also a channel balance meter for setting those tiny plastic knobs.
只看该作者 1楼 发表于: 2014-01-12
度娘翻译摘要
一个新的版本可改写的帮助文件和更多的图形细节,包括初始安装部分可以独立阅读如何在NAP3文件部分设置NAP3。本应无故障操作提供依据。
v2.7.0是一个战争四拖轮通常的结果:谁想要的一切都可以改变有一个控制调整电力用户(这会让新手用户),谁需要什么,尽量接近尽可能的即插即用“新手”(这使电力用户),“显示只有用户(谁想要尽可能少的控制)和“我想要一个软件子接收机的用户(谁需要一系列的DSP功能方面)。
以往,它是处理的音效卡,特别是0202 / 4 E-Mu家庭,这占据了大部分时间。这些都是能够从有用的设置范围的发散。除了捕获和警告,在以前的版本中不能接受的绝对水平的消息,v2.7.0将使这些卡设置不便高输出更准确控制覆盖Windows混合器。也有一个用于设置这些微小的塑料旋钮通道平衡表
