  • 10644阅读
  • 15回复
NaP3 SDR v2.6.6 元旦版 支持KX3 神卡192K [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2014-01-01
v2.6.6 NaP3 v2.6.6 setup
Greater resilience to high input levels from audio drivers.
Input ‘Calibrate’ control now changes displayed level only, not gain.
Intermittent display problem on some bandchanges cured.
Bandstack Modes and Filters Option checked as default.
Bandstack obstinacy debugged.
Minor cosmetic changes.
v2.6.0 NaP3 v2.6 setup
Overdrive condition trapped
K3, K2 auto IQ reverse debugged
Waterfall frequency labels bug removed
Extraneous ‘DSB’ entry in Filter configure form removed.
Various cosmetic changes.
Help file rewritten
v2.5 NaP3 v2.5 setup
Image correction values that are too high are ignored, and
in WBIR Calibration they generate a message about excess drive.
To Do:
Help file will be rewritten.
v2.4.0 NaP3 v2.4 Setup
No longer defaults to LSB and Filter 3 before running.
WBIR calibration and setting interface is simpler.
Three deep bandstack on all bands except 60m and GEN which are five deep.
Option to recall bandstacked modes and/or filters.
Option for combined control of spectrum and waterfall display levels on Avg button.
All Recording go to ‘NaP3 Recordings’ folder in My Documents.
Multiple RX Audio recordings timed and dated like IQ recordings.
IQ and RX Audio recordings separately identified.
Many display colours now have alpha (saturation) controls.
‘Button Selected’ colour now changes on the fly.
Span resize now works in Spanascope mode.
Squelch state in non-FM modes now saved and restored.
Setup tab changed to begin support for input devices other than sound cards.
VAC tab moved.
Orion ‘Peak Reset’ bug eradicated.
Full length click to tune line in SpanaFall mode.
Click to tune filter now disappears when cursor is off the display.
FFT Windowing function selectable again (there you go, Jeff).
’6m jump’ caused by K3 CAT corruption written around.
Frequency increments > the displayed span (e.g. rig memories) in Fixed mode now Centre.
+-1 sound sample offset for some cheap cards.
Input ‘Calibrate’ control now changes NaP3 gain.
v2.2.4.2 NaP3 v2.2.4.2 setup
For reference
下载地址
http://www.panadapter.com/wp-content/uploads/2013/12/NaP3-v2.6.6-setup.zip
[ 此帖被BG4DRL在2014-01-02 14:40重新编辑 ]
只看该作者 1楼 发表于: 2014-01-02
cmd
Dism /online /enable-feature /featurename:NetFx3 /All /Source:X:\sources\sxs /LimitAccess
或用
Microsoft .NET Compact Framework 3.5 安装dot framerwork 3.5 runtime
都可
只看该作者 2楼 发表于: 2014-01-02
拥有192k声卡的兄弟们 又可以折腾来
只看该作者 3楼 发表于: 2014-01-02
支持Pete出新版
只看该作者 4楼 发表于: 2014-01-02
没有192声卡
我读书少  不要骗我
只看该作者 5楼 发表于: 2014-01-02
回 爱不交租 的帖子
爱不交租:没有192声卡[表情] [表情]  (2014-01-02 16:26)
听说你的声卡是384K的?
只看该作者 6楼 发表于: 2014-01-02
96声卡低头默默路过~~~
900兆:要奇奇陆吧三铃摇摇就散
离线wd3010
只看该作者 7楼 发表于: 2014-01-03
48k内置声卡飘过
DE BA3OT
离线BG8STW
只看该作者 8楼 发表于: 2014-01-03
内置声卡怎么破!。。。默默路过吧~
呼号:BG8STW
只看该作者 9楼 发表于: 2014-01-04
回 BG8STW 的帖子
BG8STW:
内置声卡怎么破!。。。默默路过吧~
[attachment=630570]
只看该作者 10楼 发表于: 2014-01-04
只看该作者 11楼 发表于: 2014-01-04
Intel NUC 4k + 32bit DAC
只看该作者 12楼 发表于: 2014-01-04
围观各种高技术
只看该作者 13楼 发表于: 2014-01-04
回 BD8SZ 的帖子
BD8SZ:围观各种高技术 (2014-01-04 18:16)
digital-life
只看该作者 14楼 发表于: 2014-01-04
只看该作者 15楼 发表于: 2014-01-04
回 BG4DRL 的帖子
BG4DRL:digital-life[表情] (2014-01-04 18:43)
Huge Trap
