  • 4694阅读
  • 4回复
SDR MK1.5 Andrus [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2013-12-26
只看该作者 1楼 发表于: 2013-12-26
TECHNICAL SPECIFICATION
5kHz to 30MHz frequency range
64MHz maximum internal sampling rate
Compatible with most free SDR software, such as SDR-Radio, Winrad, Linrad, HDSDR, CuteSDR etc.
User Programmable AGC (automatic gain control) with enhanced Power Detector
123dB total dynamic range with AGC (80dB with AGC off)
0.02Hz tuning resolution
10/100Base Ethernet interface for 400kHz sample rate through network (NetSDR protocol mode)
48kHz/16-bit Ch A and Ch B simultaneous USB audio output (looks like a standard USB audio interface to computer)
234kHz single-channel or 2x117kHz dual-channel USB output with libusb driver
Comprehensive daughtercard for up to 2.2GHz downconverter and input bandpass filters available on Q2 2013
On-board RS232TTL compatible serial port and I2C interface for driving external peripheral
Powered from USB port (requires Y cable for drawing power from two USB sockets simultaneously) or external 5VDC adapter (not included). (custom PoE can be fitted)
2x BNC Antenna connectors (Mfg: Rosenberger)
Max current consumption 600mA
Open software and hardware design for DIY development, filter upgrades etc.
只看该作者 2楼 发表于: 2013-12-26
http://www.satrian.com/p/blog-page_29.html
[ 此帖被BG4DRL在2013-12-26 17:09重新编辑 ]
只看该作者 3楼 发表于: 2013-12-26
http://www.youtube.com/watch?feature=player_embedded&v=juvwUuc5Xdo
热衷于无线电收听SWL 推荐此款 信价比非常合适
只看该作者 4楼 发表于: 2014-01-27
