  • 3949阅读
  • 8回复
KX3固件升级 MCU 1.79 / DSP 1.27, 11-26-2013 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2013-12-12
See KX3 Firmware Release Notes for a complete revision history.
This release can be automatically downloaded by KX3 Utility.
KXPA100 PER-BAND POWER CALIBRATION IMPROVED
KXPA100 DRIVE CALIBRATION DATA SHOWN BY TX GAIN MENU ENTRY: If the PA MODE menu entry is set to ON or Pout CAL, and PWR is set above 10 W, the TX GAIN menu entry will show drive power in watts needed to hit 75 W at the KXPA100 amp . A letter 'A' or 'T' prefixes the drive power value shown, depending on whether the source of the calibrated drive value is the Amp or the Transceiver.
MCU 1.76 / DSP 1.27, 11-20-2013
Initial KX3 f/w release with KXPA100 support
MENU:PA MODE NOW HAS POWER-OUT CAL (P out CAL) SETTING: This enables 75-W power calibration in TUNE mode. When PWR is adjusted, and “P out CAL” mode is in effect, setting power to 75 watts shows “CAL 75W” on VFO B.
KXPA100 DRIVE POWER CAL DATA UTILIZED: If the KXPA100’s per-band 75-W drive power has been saved at the factory, the KX3 will use it. If not, the KX3's own per-band amplifier drive data is used (if available). This data is created by setting PA MODE to Pout CAL (see above), then doing a TUNE on each band at 75 W.
IMPROVED POWER CONTROL. As the KX3’s PWR control is adjusted, the KXPA100’s output now more closely approximates the requested value.
KX3-2M SUPPORT (instructions TBD).
DTMF TONE SUPPORT ADDED IN FM MODE: To generate DTMF tones: (1) Hold PTT; (2) tap FREQ ENT switch to enable DTMF keypad; (3) tap desired switches [0-9, * (ATU TUNE), # (MSG), A (MODE), B (A/B), C (DATA), D (A>B)]. Release PTT or tap FREQ ENT to disable DTMF keypad. Switches can be held indefinitely to generate longer-duration tones.
FM RX & TX IMPROVED: Reduced FM distortion on receive. TX deviation max now 6.0; default 5.0 (U.S. standard).
只看该作者 1楼 发表于: 2013-12-12
离线BD7MYM
只看该作者 2楼 发表于: 2013-12-12
刚看没有更新啊。
在线BD8CS
只看该作者 3楼 发表于: 2013-12-12
回  2楼(东莞刘伟)的帖子
第2楼东莞刘伟于2013-12-12 21:54发表的:
刚看没有更新啊。
估计是beta
只看该作者 4楼 发表于: 2013-12-13
国内有不少台吧
离线BG6JJI
只看该作者 5楼 发表于: 2013-12-13
我早升过了,是beta
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
只看该作者 6楼 发表于: 2013-12-13
MCU 1.76是beta 总体也许还是beta
KXPA100的兄弟们可以享受联动的快乐
在线BD8CS
只看该作者 7楼 发表于: 2013-12-13
kxpa100支持qsk吗?
离线bh1boq
只看该作者 8楼 发表于: 2014-03-04
回贴收藏一个
GSM:13520155353
E-mail:bh1boq@126.com
QTH :北京广安门
QQ:108617263(加好友时请注明呼号,谢谢!)
邮政信箱:邮编(100808) A座16层杜键收
____________________________________
设备情况:
IN DOOR:KENWOOD TS-590S OUT DOOR:ELECRAFT KX3 OR YAESU897D
ANT:750V; 80米:自动天调+60长线天线+X510 非常喜欢手键!
