  • 2485阅读
  • 1回复
UA-55 QUAD-CAPTURE Driver Ver.1.5.2 Win8.1 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2013-12-10
Update history
[ Ver.1.5.2 ]
•Now available for Microsoft(R) Windows(R) 8.1.
•Changed the item name "Reduce CPU load" in the Settings dialog box to "Low Latency mode."
This reduces the load on the CPU when the ASIO buffer size is small, and then it lowers the latency of the ASIO driver.
* If you cannot play back or record or if the sound is interrupted, clear this check box.
* If you're using in WDM/KS mode, clear this check box.
[ Ver.1.5.1 ]
http://www.roland.com/support/article/?q=downloads&p=UA%2D55&id=62264894
只看该作者 1楼 发表于: 2013-12-21
haoyong
