  • 6544阅读
  • 6回复
Initial KX3  with KXPA100 All in One support [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2013-11-23
MCU 1.76 / DSP 1.27, 11-20-2013
Initial KX3 f/w release with KXPA100 support
• MENU:PA MODE NOW HAS POWER-OUT CAL (P out CAL) SETTING: This enables 75-W power calibration in TUNE mode. When PWR is adjusted, and “P out CAL” mode is in effect, setting power to 75 watts shows “CAL 75W” on VFO B.
• KXPA100 DRIVE POWER CAL DATA UTILIZED: If the KXPA100’s per-band 75-W drive power has been saved at the factory, the KX3 will use it. If not, the KX3's own per-band amplifier drive data is used (if available). This data is created by setting PA MODE to Pout CAL (see above), then doing a TUNE on each band at 75 W.
• IMPROVED POWER CONTROL. As the KX3’s PWR control is adjusted, the KXPA100’s output now more closely approximates the requested value.
• KX3-2M SUPPORT (instructions TBD).
• DTMF TONE SUPPORT ADDED IN FM MODE: To generate DTMF tones: (1) Hold PTT; (2) tap FREQ ENT switch to enable DTMF keypad; (3) tap desired switches [0-9, * (ATU TUNE), # (MSG), A (MODE), B (A/B), C (DATA), D (A>B)]. Release PTT or tap FREQ ENT to disable DTMF keypad. Switches can be held indefinitely to generate longer-duration tones.
• FM RX & TX IMPROVED: Reduced FM distortion on receive. TX deviation max now 6.0; default 5.0 (U.S. standard).
ftp://ftp.elecraft.com/KX3/firmware/beta
离线BG6JJI
只看该作者 1楼 发表于: 2013-11-26
我刷了,但没有KXPA100........
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
只看该作者 2楼 发表于: 2013-11-26
回 BG6JJI 的帖子
BG6JJI:我刷了,但没有KXPA100........ (2013-11-26 09:30)
买。。。
离线浙江HAM
只看该作者 3楼 发表于: 2013-11-26
我也刷。
BG5GAG 13757821288
E_mail:13757821288 a 139.com
QTH:OL98NB
喜欢短波通信
离线BG6JJI
只看该作者 4楼 发表于: 2013-11-27
回 BD8SZ 的帖子
BD8SZ:买。。。 (2013-11-26 12:42)
你给我买...
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
只看该作者 5楼 发表于: 2013-11-27
回 BG6JJI 的帖子
BG6JJI:你给我买... (2013-11-27 12:36)
刷机能刷个出来的
离线BG7YMX
只看该作者 6楼 发表于: 2013-11-28
