  • 2385阅读
  • 0回复
KX3 MCU 1.68 / DSP 1.23, 9-24-2013 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2013-11-05
•LOW POWER (UNDER 1 W) NOW WORKS IN SSB MODE: Previously,
with power settings under 1 W, SSB power output could drop to about 0.1 W and stay there.
•ESSB DISALLOWS USE OF CMP: If attempted, shows "N/A".
•DATA-A/AFSK-A/etc. BUG FIX: MIC GAIN control now works as expected.
In the previous release, adjustment of keyer speed while using the CW-in-SSB
feature would leave the MIC GAIN control set to keyer speed when the user switched to
an audio data mode.
