  • 4078阅读
  • 11回复
SAC是什么比赛? [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2013-09-12
请前辈来个规则吧,谢谢
只看该作者 1楼 发表于: 2013-09-12
新手转发:
Scandinavian Activity CW Contest
Start: Saturday of 3rd September full weekend in 12:00 UTC (21 September, 2013 in 12:00)
Finish: Sunday in 11:59 UTC (22 September, 2013 in 11:59)
Modes: CW
Bands:
80m    40m    20m    15m    10m
Categories (classes):
- SINGLE-OP ALL HIGH
- SINGLE-OP-ASSISTED ALL HIGH
- SINGLE-OP ALL LOW
- SINGLE-OP ALL LOW ROOKIE
- SINGLE-OP ALL LOW TB-WIRES
- SINGLE-OP ALL QRP
- SINGLE-OP 80M
- SINGLE-OP 40M
- SINGLE-OP 20M
- SINGLE-OP 15M
- SINGLE-OP 10M
- MULTI-ONE
- MULTI-MULTI
LOW Power - output 100 W or less;
QRP - output 5 W or less.
Scandinavian stations, other European stations, and non-European stations are placed in separate categories.
Scandinavian stations are defined by prefixes as follows:
Svalbard and Bear Island JW
Jan Mayen JX
Norway LA – LB – LG – LJ – LN
Finland OF – OG – OH – OI
Aland Islands OF0 – OG0 – OH0
Market Reef OJ0
Greenland OX – XP
Faroe Islands OW – OY
Denmark 5P – 5Q – OU – OV – OZ
Sweden 7S – 8S – SA – SB – SC – SD – SE – SF – SG – SH – SI – SJ – SK – SL – SM
Iceland TF
SINGLE-OP ALL LOW ROOKIE, SINGLE-OP ALL LOW TB-WIRES, SINGLE-OP 80M ... SINGLE-OP 10M, MULTI-MULTI - Only for Scandinavian
stations.
SINGLE-OP-ASSISTED ALL HIGH - Only for non-Scandinavian stations.
SINGLE-OP - Single operator means that one person performs all operating, logging and spotting functions without any external
assistance. The use of DX-Cluster, Skimmer or Skimmer-like technology (such as Reverse Beacon Network, RBN) is not allowed. The
station must be located in one site, with the location determined by the physical location of the transmitters, receivers, and
antennas. Asking and begging stations to announce ones own call on the DX-Cluster is NOT allowed.
Scandinavian ALL band entrants may participate in one of the "Tribander/Single Element" or "Rookie" categories by adding the line
CATEGORY-OVERLAY: TB-WIRES or CATEGORY-OVERLAY: ROOKIE in their Cabrillo log file.
SINGLE-OP ALL LOW ROOKIE - Participants in the Rookie category must be licensed less than 3 years before the CW contest starts.
SINGLE-OP ALL LOW TB-WIRES - Participants in this category shall use only one triband antenna for 10, 15, and 20 meters, and
single-element antennas for 40 and 80 meters.
SINGLE-OP-ASSISTED ALL HIGH category allows the use of DX-Cluster, Skimmer, and Skimmer-like technology (such as RBN). The
antennas.
MULTI-ONE - Only one signal may be transmitted on any band at any time (running station). When operation has started on one band,
the station must remain on that band for at least 10 minutes. The 10-minute period starts with the first QSO worked on that band.
Exception: It is allowed to work a QSO on another band if it is a new multiplier (multiplier station). The multiplier station
is allowed to be on the air at the same time as the running station. The multiplier station must also stay on the "multiplier
band" at least 10 minutes. The use of DX-Cluster, Skimmer, and Skimmer-like technology (such as RBN) is allowed. The station must
be located in one site, with the location determined by the physical location of the transmitters, receivers, and antennas.
MULTI-MULTI - There are no restrictions on the number of transmitters. Only one signal per band is allowed at any time. All
equipment, including receivers, transmitters, and antennas must be located within a circle with a maximum diameter of 500 meters.
Separate serial numbers are used for each band. The use of DX-Cluster, Skimmer, and Skimmer-like technology (such as RBN) is
allowed. Asking and begging stations to announce ones own call on the DX-Cluster is NOT allowed.
The same station may be worked once on each band. Cross-mode and/or cross-band QSO’s are not allowed.
Exchanges:
RST + serial number starting with 001 (e.g. 599001). (QSO’s after 999 are numbered 1000, 1001 etc).
Points for QSO:
For Scandinavian stations:
2 points per QSO with Europe;
3 points per QSO with DX.
For non-Scandinavian stations:
EUROPEAN stations:
1 point per QSO.
NON-EUROPEAN stations:
1 point per QSO on 14, 21 and 28 MHz bands;
3 points per QSO on 3.5 and 7 MHz bands.
Multipliers:
Each worked non-Scandinavian DXCC country is valid for one multiplier for each band.
Each worked prefix-number (0-9) in each Scandinavian country is valid for one multiplier for each band (e.g. SI3, SK3, SL3, SM3,
7S3 and 8S3 are all in ONE district and count for ONE (1) multiplier on each band).
Portable stations without a prefix number count for the 10th area (e.g. LA/G3XYZ counts for LA0).
OH0 (Aland Is.) and OJ0 (Market Reef) are separate call areas. SJ9 and SI9 counts for the 9th district in Sweden.
Score:
To calculate the final score, multiply the sum of QSO points on all bands with the sum of multipliers worked on all bands.
Logs:
Logs must be submitted separately for CW and SSB, and the QSOs must be listed in chronological order.
By submitting a log, you agree that your log and the corresponding log checking report may be made open to the public.
Electronic submission of logs at http://www.sactest.net is required for all entrants. The website provides conversion tools and
allows manual entry for those operators who have used a paper log while operating.
Use the CABRILLO format. Please ensure that you fill out all of the header information.
Please check your log for typing errors and leave all your QSOs in the log, dupes included. The log checking software will find
the dupes and mark them with zero points.
Sending of electronic logs:
Log must be upload via SAC LOG UPLOAD Page.
Deadline:
Cabrillo logs or typed-in paper logs shall be uploaded no later than two weeks after the end of each part of the contest.
Awards:
The top scoring station in each country, in each category, on both CW and SSB, will receive a Contest Award, provided a
reasonable score is made.
Scandinavian winner stations will receive a Contest Plaque in the High-power, Low-power, Low-power Rookie, and Low-power
Tribander/Single-element multi band categories.
The non-Scandinavian continental winners will receive a Contest plaque in the High-power multi band category, provided a
Depending on the number of participants, the Contest Committee may consider additional awards.
Scandinavian Cup
The Scandinavian Cup is a competition between the Scandinavian Regions. All entrants scores for both CW and SSB are accumulated
to a total for each region. All logs except for checklogs are counted towards the total.A circulating trophy is awarded to the
league of the region that wins the Cup.
Rule Violations, Penalties and Declaration:
Violation of Amateur Radio Regulations in the country of the contestant or the rules of this contest, unsportsmanlike conduct and
taking credit for unverifiable QSOs or multipliers may lead to disqualification.
The decisions by the Contest Committee are final and definite. The right to changes in these rules is reserved.
Web-site: http://www.sactest.net/
Link for original rules:
english
Examples lines for Cabrillo format logs:
000000000111111111122222222223333333333444444444455555555556666666666777777777788
123456789012345678901234567890123456789012345678901234567890123456789012345678901
                              -------transmitted------ -------received---------
QSO: 14026 CW 2013-09-21 1200 UA8AAA        599 001    SA0XXX        599 001
QSO:  7023 CW 2013-09-21 1205 UA8AAA        599 002    OH2ZZZ        599 003
Examples head for Cabrillo format logs:
SINGLE-OP ALL HIGH
SINGLE-OP ALL LOW
SINGLE-OP ALL QRP
SINGLE-OP 80M
SINGLE-OP 40M
SINGLE-OP 20M
SINGLE-OP 15M
SINGLE-OP 10M
MULTI-ONE
MULTI-MULTI
SINGLE-OP ALL HIGH (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: UA8AAA
CATEGORY-OPERATOR: SINGLE-OP
CATEGORY-BAND: ALL
CATEGORY-POWER: HIGH
ADDRESS: ul. Lenina 17-1
ADDRESS-CITY: Chelaybinsk
ADDRESS-POSTALCODE: 454111
ADDRESS-COUNTRY: Russia
EMAIL: ua8aaa@yandex.ru
SINGLE-OP ALL HIGH (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: UA8AAA
CATEGORY: SINGLE-OP ALL HIGH
ADDRESS: ul. Lenina 17-1, Chelaybinsk, 454111, Russia
SINGLE-OP-ASSISTED ALL HIGH (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: UA8AAA
CATEGORY-BAND: ALL
CATEGORY-ASSISTED: ASSISTED
SINGLE-OP-ASSISTED ALL HIGH (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: UA8AAA
CATEGORY: SINGLE-OP-ASSISTED ALL HIGH
SINGLE-OP ALL LOW (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: UA8AAA
CATEGORY-BAND: ALL
CATEGORY-POWER: LOW
SINGLE-OP ALL LOW (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: UA8AAA
CATEGORY: SINGLE-OP ALL LOW
SINGLE-OP ALL LOW ROOKIE (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY-BAND: ALL
CATEGORY-POWER: LOW
ADDRESS: Box 999
ADDRESS-CITY: Stockholm
ADDRESS-POSTALCODE: SE127 00
ADDRESS-COUNTRY: Sweden
EMAIL: sm0xxx@ssa.se
SINGLE-OP ALL LOW ROOKIE (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
ADDRESS: Box 999, Stockholm, SE127 00 Sweden
SINGLE-OP ALL LOW TB-WIRES (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY-BAND: ALL
CATEGORY-POWER: LOW
ADDRESS: Box 999
SINGLE-OP ALL LOW TB-WIRES (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
SINGLE-OP ALL QRP (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: UA8AAA
CATEGORY-BAND: ALL
CATEGORY-POWER: QRP
SINGLE-OP ALL QRP (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: UA8AAA
CATEGORY: SINGLE-OP ALL QRP
SINGLE-OP 80M (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY-BAND: 80M
ADDRESS: Box 999
SINGLE-OP 80M (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY: SINGLE-OP 80M
SINGLE-OP 40M (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY-BAND: 40M
ADDRESS: Box 999
SINGLE-OP 40M (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY: SINGLE-OP 40M
SINGLE-OP 20M (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY-BAND: 20M
ADDRESS: Box 999
SINGLE-OP 20M (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY: SINGLE-OP 20M
SINGLE-OP 15M (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY-BAND: 15M
ADDRESS: Box 999
SINGLE-OP 15M (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY: SINGLE-OP 15M
SINGLE-OP 10M (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY-BAND: 10M
ADDRESS: Box 999
SINGLE-OP 10M (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY: SINGLE-OP 10M
MULTI-ONE (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: UA8AAA
CATEGORY-OPERATOR: MULTI-OP
CATEGORY-TRANSMITTER: ONE
OPERATORS: UA8AAA UA8BBB
MULTI-ONE (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: UA8AAA
CATEGORY: MULTI-ONE
MULTI-MULTI (Cabrillo 3.0 format):
START-OF-LOG: 3.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY-TRANSMITTER: UNLIMITED
OPERATORS: SA0XXX SA0YYY
ADDRESS: Box 999
MULTI-MULTI (Cabrillo 2.0 format):
START-OF-LOG: 2.0
CONTEST: SAC-CW
CALLSIGN: SA0XXX
CATEGORY: MULTI-MULTI
900兆:要奇奇陆吧三铃摇摇就散
只看该作者 2楼 发表于: 2013-09-13
发了没人看?
900兆:要奇奇陆吧三铃摇摇就散
在线BD7IS
只看该作者 3楼 发表于: 2013-09-14
参与的中国人不多的
在线深圳上尉
只看该作者 4楼 发表于: 2013-09-14
回 BD7IS 的帖子
BD7IS:参与的中国人不多的 (2013-09-14 09:49)
那证明奖更好拿些
B D 7 M T J     Ex :BG7MTJ
DXCC Mixed
bd7mtj@qq.com
离线BH1EBF
只看该作者 5楼 发表于: 2013-09-15
等看中文版的
离线BH1IIJ
只看该作者 6楼 发表于: 2013-09-15
回 BH1EBF 的帖子
BH1EBF:等看中文版的[表情] [表情]  (2013-09-15 16:44)
此板块,比赛广告帖:)
呼号:BD1IIJ
CSKC:099
地址:山后北清路一路向西
QQ:八1零4零5九8
邮箱:我的呼号@163.com
离线BG4AHF
只看该作者 7楼 发表于: 2013-09-15
SZ现在什么比赛都打
BG9XD
KG5NJU
XU7AMG
只看该作者 8楼 发表于: 2013-09-15
搞不搞?
只看该作者 9楼 发表于: 2013-09-15
For non-Scandinavian stations:*.Multi Band – High Power [SINGLE-OP ALL HIGH]*.Multi Band – High Power Assisted [SINGLE-OP-ASSISTED ALL HIGH]*.Multi Band – Low Power (output 100 W or less) [SINGLE-OP ALL LOW]*.Multi Band – QRP (output 5 W or less) [SINGLE-OP ALL QRP]
这个重要!
离线曾经拥有
只看该作者 10楼 发表于: 2013-09-21
传播白搭,没搞
呼    号: BG4男模特
操作证号: 42-88357
QQ 号码: 19918970
电子邮箱: bg4男模特@126.com
等级代表应该承担的责任和义务
vy 73
离线BG5MVE
只看该作者 11楼 发表于: 2014-09-21
昨天、今天,15米上听到无数,,,
http://bg5mve.taobao.com/  赣南脐橙、宁都莲子、蜂蜜等土特产
