  • 2543阅读
  • 10回复
KX3 CW decorder Display on 订正贴 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2013-08-27
有同学来问
以前的固件长按DATA,选择TRH3左右的level,液晶屏幕右下角显示“T” 即可DEC CW 接受和发送,
现状固件取消了这个功能 不知为什么 等Elecraft上班了问问
/***---- 针对以上更正   固件升级和降级都验证过了 没有任何关系 现在MCU:01.57 DSP:01.22 Beta版本验证---**/
CW模式下的DECODER TEXT操作步骤如下
(mode)切换到CW模式下
长按(DATA)
然后
(OFS)旋钮 选择到需要的level 一般为RX THR3 解码比较准确 能达到60-70%左右
特此更正
[ 此帖被BG4DRL在2013-08-27 18:07重新编辑 ]
只看该作者 1楼 发表于: 2013-08-27
KX3 Beta Firmware Revision
MCU 1.57 / DSP 1.22, Aug 17, 2013
Please read KX3 Beta Firmware Instructions for   installing beta firmware.
Only the current production firmware releases can be downloaded by KX3 Utility automatically.
12-kHz AUDIO SPUR ELIMINATED:  Some operators reported hearing a very weak 12-kHz tone at the headphone jack, even with the volume turned all the way down. This tone has now been suppressed by an additional 20 dB (approx.).
“WEAVER MODE” SSB RECEIVE IMPROVED:  When the high end of the KX3’s SSB receive passband is set below about 2.4 kHz using the PBT control, the DSP switches to “Weaver” demodulation mode. This allows roofing filter FL2 to be used. In previous releases, Weaver demodulation had poor opposite-sideband image rejection; this has been corrected. Note: It is not necessary to re-do RXSBNUL calibration.
ATU IMPROVEMENTS:  Tapping ATU TUNE now recalls stored LC settings for the current VFO frequency prior to tuning, avoiding auto-tuning from scratch in most cases. Also, ATU settings are now reloaded (if necessary) when the A/B, A>B, REV, FREQ ENT, or  SPLIT  switches are used. This increases the likelihood that the ATU will be kept tuned during receive, improving sensitivity, without having to transmit first. Previously, only XMIT, TUNE and band changes would force an ATU settings reload.
Note: If you switch to a different antenna, such as when taking the KX3 into the field, you may want to clear old ATU LC settings for one or more bands prior to doing new auto-tunes. To do this, locate the ATU MD menu entry, then hold CLR (hold function of the OFS/B knob). You can change bands from within this menu entry using BAND +/-.
KXPA100/KXAT100 SUPPORT:  Support for the KXPA100/KXAT100 is incomplete and is presently intended for engineering use only. The PA MODE menu entry should be set to OFF for now.
CW-IN-SSB TRANSMIT ADDED:  This feature allows you to send CW while in SSB mode, which can be useful when your SSB signal cannot be copied due to poor conditions. The other station will hear a tone at your CW pitch. To enable CW-in-SSB: Locate the CW WGHT menu entry, then tap ‘1’ (PRE) to alternate between “SSW +CW” (enabled) and “SSB –CW” (disabled). The default is disabled. Important Notes: (1) CW-in-SSB does not yet apply in SPLIT mode. (2) When CW-in-SSB is enabled, tapping the KEYER/MIC knob toggles between keyer speed and mic gain rather than between the two transmit metering scales (CMP/ALC and SWR/RF). The CMP/ALC scale is still shown temporarily whenever CMP or mic gain are adjusted.
1-HZ TUNING PRESERVED AFTER APF-OFF:  If you were using 1-Hz tuning prior to turning on APF (CW audio peaking filter), 1-Hz tuning will be restored when APF is turned off. Prior to this change, exiting APF would set the tuning rate to 10 Hz.
只看该作者 2楼 发表于: 2013-08-27
塔酿滴 这小东西功能太复杂
等记住了LongKey长按键 又忘记了短按键
记得建武的开发本部长说得对,按键一定要容易操作 尽可能的摊开Space。
嘿塔玛KX3都反正思维 让你记不住 让你来掀裙子 嘿
只看该作者 3楼 发表于: 2013-08-27
特此更正 此贴关闭
另外请各位香肠一定备份好出厂的基本设置,
如有遗失或者调乱情况发生 可写信给Elecraft的Support索取出厂调整值的config  切记备份好!
[ 此帖被BG4DRL在2013-08-27 17:50重新编辑 ]
只看该作者 4楼 发表于: 2013-08-27
SZ大大的手指戳穿的血没有白流,再次验证SZ同学Work的正确性
DTR-key 在KEY口3.5mm插的 KEYER2时 TX时候显示屏不现实TEXT
Elecraft的说明书中明确表述如下
displays only CW characters you send using the internal keyer
也就是前面的Key1
所以要TX和RX都能看到DISP的话,请把DTR线连接到前面版来了。
很矛盾的是对于CW初学者来说,手键发送的正确性这时候就看不了
两者只能选一,要么流血 要么直插
要么就是3P 手键和DTR键 统统插入前面口  这个等待SZ大大再次出血研究
/***---- 针对以上再次更正
KX3的cw-key2前面版和cw-key1侧面3.5口 只针对LFT-Dot和Dash模式进行解码显示,
第三的Hand模式 无法解码,故上述推测无法实现,难道只能用数据线推送KY cmd
实现面板显示cw test
[ 此帖被BG4DRL在2013-08-27 22:08重新编辑 ]
只看该作者 5楼 发表于: 2013-08-27
KX3原装数据线KY cmd直接拍发CW
原址  BG6JJI 方法
http://www.hellocq.net/forum/read.php?tid=313172
还是想起用Hand模式下的DTR输入的解码!!
只看该作者 6楼 发表于: 2013-08-27
哈哈走到死胡同里来
鱼和熊掌不可兼得嘛
很想问问BG6JJI先辈
也是碰到这样情况才走KY-CMD的是吗?
只看该作者 7楼 发表于: 2013-08-27
老鸟看到菜鸟 肯定无语了
来吧楼下请
拜上
只看该作者 8楼 发表于: 2013-08-27
无奈之举
先启用USB to Keyer的K3NG的winkey
2400速率usb 应该更得上
真折腾,两根线计划暂时搁浅,
也不想用KY-CMD的单线方案
继续
只看该作者 9楼 发表于: 2013-08-28
还是使用串口线KY CMD拍发
{EXCH}新版本还是不能发串号
做个记号
#F1 Cq,cq test {MYCALL} {MYCALL} test
F1 Cq,{CATA1ASC KY CQ NA * * CQ;}
#F2 Exch, {SENTRSTCUT} {EXCH}
F2 Snt,{CATA1ASC KY 5nn # #;}
#F3 Tu,tu {MYCALL} test
F3 Tu,{CATA1ASC KY tu;}
#F4 {MYCALL},{MYCALL}
F4 {MYCALL},{CATA1ASC KY *;}
#F5 His Call,!
F5 His Call,{CATA1ASC KY {call} ;}
#F6 Repeat, {SENTRSTCUT} {EXCH} {EXCH}
F6 Repeat, {CATA1ASC KY # #;}
#F7 Empty,
#F7 Exch, {CATA1ASC KY {SENTRSTCUT} {EXCH} de *;}
F7 Exch, {CATA1ASC KY #;}
#F8 Agn?,agn?
F8 Agn?,{CATA1ASC KY agn? ;}
#F9 Nr?,nr?
F9 Nr?,{CATA1ASC KY nr? ;}
#F10 Call?,cl?
F10 Call?,{CATA1ASC KY cl? ;}
#F11 Empty,
F11 Break,{CATA1ASC RX;}
#F12 Wipe,{WIPE}
F12 Wipe,{WIPE}
只看该作者 10楼 发表于: 2013-08-28
F11 Break,{CATA1ASC RX;}  好用 方便
