TS-990S firmware has been updated from Version 1.03 to Vers ..
TS-990S firmware has been updated from Version 1.03 to Version 1.04
BG4DRL
UID:360404
8155小时
发表于: 2013-08-24
Updated items : (Version 1.03
1.04)
[August 23, 2013]
Revises the following symptoms.
1.
When sending certain character sequences using the built-in RTTY function, garbled text might be encoded.
2.
When Advanced Menu No.22 "Standby State Low Power Consumption" is set to "On" and the TS-990S is turned off by the front panel power switch, the ARCP-990 may not detect the power off status correctly.
Updated items : (Version 1.02
1.03)
[July 12, 2013]
Updates the following features.
1.
Enables use of the TF-SET function while the CW/Voice Message screen is displayed.
2.
Enables toggling Sub Band reception between ON and OFF while the CW/Voice Message screen is displayed.
3.
When PF keys are pressed to play a CW/Voice Message while CW/Voice Message screen is not displayed, the CW/Voice Message screen is opened.It closes again after playing the message is completed.
If playing a message is stopped by F4[STOP] key, the CW/Voice Message screen remains.
4.
Enables TF-SET function in Simplex mode while "XIT is ON and RIT is OFF".
While [TF-SET] key is pressed, XIT offset frequency can be set by [Tuning] (Main) control as well as [RIT/XIT] control.
The function does not work when RIT is ON.
Please also update the Radio Control Program
ARCP-990
which includes above revisions.
5.
Increases TX monitor maximum level by approximately 6dB.
6.
Reduces CW full break-in RX noise.
7.
Extends default AGC time constant values in "FAST", "MIDDLE", "SLOW"
美版,欧版机更新地址
http://www.kenwood.com/i/products/info/amateur/ts_990/ts990_update_e.html\
日规机 更新地址
http://www2.jvckenwood.com/products/amateur/hf_allmode/ts_990/ts990_update_j.html
[ 此帖被BG4DRL在2013-08-24 22:54重新编辑 ]
BG4DRL
UID:360404
8155小时
发表于: 2013-08-28
顶贴
