  • 4069阅读
  • 8回复
没看到有中国台参加JASTA比赛 [复制链接]
离线ba2ba
只看楼主 倒序阅读 0楼 发表于: 2013-08-18
昨天(8月17日)上午开始到现在,在14.230MHZ,有一SSTV比赛。呼叫时用的标志是  JASTA CONTEST   ,没有看到有中国台参加,想了解具体规则,网上没有查到,有知道的吗?
姓名:陈铁石/BA2BA
邮编:153021
电话:18804585572
QQ:464826156
离线深圳上尉
只看该作者 1楼 发表于: 2013-08-18
http://homepage3.nifty.com/jasta/english/e_activ/active10.htm
***** The 2010 JASTA SSTV Activity Contest Rules*****
1.Contest periods:
From August 1st 2010 (00:00 UTC) to August 31 (24:00 UTC)
2.Bands:
3.5MHz and all upper bands.Use Only frequencies which are authorized by each individual station license.
3. Categories of Entry:
a) "J" Category (Japanese only): Japanese domestic stations
b) "S" Category(DX station): All stations operating outside of Japan. If a Japanese station operates outside Japan, this will be considered a DX       contact.
4.QSO Point:
Exchange the usual RSV plus a progressive QSO number starting with 001 which should be displayed in the picture exchange. Regardless of  bands used, a station may only be worked  once each UTC day .
If possible, during the exchange,  include one's own face picture or some kind of illustration. QSO points authorized  by bands.
3.5-28MHz ... 1 point
50-430MHz ... 2 points
1200MHz & upper ... 3 points
5. Multipliers:
Work all  Japanese callsign districts(JA1-JA0 total 10) + DXCC Countries worked. Use DXCC List.  Do not count Japan as a DXCC country + Number of  days on the air.  (10 days at the maximum even if a station  operates  more than 10 days)
note:Prefix 7K-7N's are all JA1 area
6. Scoring:
The final score is computed by multiplying the sum of the QSO points by the sum of multipliers as described in Paragraph 5.
7. Contest awards:
1) A shield award will be sent to the 1st, the 2nd and the 3rd Score of each sections. But when the number of stations are less than 10, awards will be sent to the 1st place winner only.
2) A special activity award will be sent to some of the stations who work over 10 days by lot.
(A JASTA T-shirts to 20 stations)
3) New face certificate will be sent to the 1st of new comers. so please annotate your summary sheets “new Comer” " on summary sheets.
4) YL certificate will be sent to the 1st place YL stations.
8. Logs:
Summary sheets and Log sheets should be arranged and mailed to the Contest manager. Email contest Summary sheet and logs to: JASTA Contest Secretary ja3wzt@mue.biglobe.ne.jp  The log should be in a text file format.  Email (text format)  summary.  E-Mail logs are acceptable now. Both Summary and logs should be forwarded to ja3wzt@mue.biglobe.ne.jp  Assure you station callsign is in the e-mail subject line.
DX stations, "CQ WW" contest format is acceptable. Please enclose SASE and 1 IRC for reply. The log in a text file by Email is also acceptable now.
9. Deadline for log entries:
Log entries with a stamp of a local POST office dated not later than September 30, 2010.(UTC) In case of Email, it must be received by the same above deadline.(UTC)
10 Regulations:
1) All Amateur Radio stations who has a license to transmit SSTV signal.
2) Output power: Up to maximum power officially authorized by the operators class license .
3) Both B/W and Color Picture QSO are accepted.
4) A contest QSO should be one station to one station QSO. Round table style QSO’s between multiple stations will not be counted.
5) Cross band QSO will not be counted as a contest QSO.
6) All the QSO; JA to JA station, JA to DX station, DX to DX station will be counted and  accepted as contest QSOs.
11.JASTA Contest Results:
The contest results will be sent to all stations who include a SASE. Aditionally announcement will be made  on JASTA homepage and Japanese "CQ ham radio" magazine .
12.The Contest Manager and Mailing Address :
JASTA Contest Secretariat ?@Email:ja3wzt@mue.biglobe.ne.jp
c/o YOSHIKAZU TANABE JA3WZT/1
905-8,SHIMOYAGANUKI,IRUMA,SAITAMA,3580041 JAPAN
B D 7 M T J     Ex :BG7MTJ
DXCC Mixed
bd7mtj@qq.com
离线深圳上尉
只看该作者 2楼 发表于: 2013-08-18
***** 2010 JASTA的SSTV活动竞赛规则*****
1.Contest periods: 1.Contest期间:
From August 1st 20 10 (00:00 UTC) to August 31 (24:00 UTC) 20 10(00:00 UTC),从8月1日至8月31日(24:00 UTC)
2.Bands: 2.Bands:
3.5 MHz and all upper bands.Use Only frequencies which are authorized by each individual station license. 3.5 MHz和个别车站许可证授权所有的上bands.Use只有频率。
3. 3。 Categories of Entry: 参赛类别:
a) "J" Category (Japanese only): Japanese domestic stations 一)“J”类别(日本):日本国内站
b) "S" Category(DX station): All stations operating outside of Japan. B)“S”类别(DX站):在日本以外的所有站。 If a Japanese station operates outside Japan, this will be considered a DX 如果日本站日本以外的操作,这将被认为是一个DX        contact. 联系。
4.QSO Point: 4.QSO点:
Exchange the usual RSV plus a progressive QSO number starting with 001 which should be displayed in the picture exchange. 交易所通常的RSV加一个渐进的QSO数001应显示在画面交换开始。 Regardless of 不管   bands used, a station may only be worked 使用的频带,电台只可以工作   once each UTC day . 一旦每个UTC一天。
If possible, during the exchange, 如果可能的话,在交流过程中,   include one's own face picture or some kind of illustration. 包括自己的脸图片或某种说明。 QSO points authorized 通联授权点   by bands. 乐队合奏。
3.5-28MHz ... 3.5-28MHz的... 1 point 1点
50-430MHz ... 50-430MHz的... 2 points 2分
1200MHz & upper ... 1200MHz的上部... 3 points 3分
5. 5。 Multipliers: 乘数:
  Work all 所有工作   Japanese callsign districts(JA1-JA0 total 10) + DXCC Countries worked. 日本呼号区(JA1-JA0共10)+ DXCC国家工作。 Use DXCC List. 使用DXCC列表。   Do not count Japan as a DXCC country + Number of 不要指望日本作为DXCC国家数+   days on the air. 空气天。   (10 days at the maximum even if a station (10天,即使在最大一个台站的   operates 经营   more than 10 days) 超过10天)
note:Prefix 7K-7N's are all JA1 area 注意:前缀7K-7N都是JA1区
6. 6。 Scoring: 评分:
The final score is computed by multiplying the sum of the QSO points by the sum of multipliers as described in Paragraph 5. 最后得分的计算乘以第5段中所描述的乘法器的总和QSO分数的总和。
7. 7。 Contest awards: 大赛奖项:
1) A shield award will be sent to the 1st, the 2nd and the 3rd Score of each sections. 1)屏蔽奖项将被发送到第一,第二和第三每个部分的分数。 But when the number of stations 但是,当站的数量 are less than 10, awards will be sent to the 1 st place winner only. 小于10,奖项将被发送到第一名的赢家只有。
2) A special activity award will be sent to some of the stations who work over 10 days by lot. 2)一个特殊的活动奖励将被发送到超过10天的工作很多站。
(A JASTA T-shirts to 20 stations) (A JASTA的T恤20个电台)
3) New face certificate will be sent to the 1st of new comers. 3)新的脸证书将被发送到第一大学新生。 so please annotate your summary sheets “new Comer” " on summary sheets. 所以请注释摘要表,“新丁”,“汇总表。
4) YL certificate will be sent to the 1st place YL stations. 4)YL证书将被发送到第一名YL站。
8. 8。 Logs: 日志:
Summary sheets and Log sheets should be arranged and mailed to the Contest manager. 摘要应安排表和日志表,并邮寄至竞赛经理。 Email contest Summary sheet and logs to: JASTA Contest Secretary ja3wzt@mue.biglobe.ne.jp 电子邮件竞赛汇总表和日志:JASTA大赛秘书ja3wzt@mue.biglobe.ne.jp的   The log should be in a text file format. 日志应该是在一个文本文件格式。   Email (text format) 电子邮件(文本格式)   summary. 总结。   E-Mail logs are acceptable now. E-MAIL日志现在是可以接受的。 Both Summary and logs should be forwarded to ja3wzt@mue.biglobe.ne.jp 总结和日志都应该被转发到ja3wzt@mue.biglobe.ne.jp   Assure you station callsign is in the e-mail subject line. 保证你站的呼号在电子邮件的主题行。
DX stations, "CQ WW" contest format is acceptable. DX站“,CQ WW”比赛是可以接受的格式。 Please enclose SASE and 1 IRC for reply. 请附上SASE和IRC答复。 The log in a text file by Email is also acceptable now. 记录在一个文本文件通过电子邮件也是可以接受的。
9. 9。 Deadline for log entries: 日志条目的截止日期为:
Log entries with a stamp of a local POST office dated not later than September 30, 20 10 .(UTC) In case of Email, it must be received by the same above deadline.(UTC) 日志条目与邮票当地邮局日期不得超过9月30日,20 10(UTC)在电子邮件的情况下,它必须在收到由同一上述期限(UTC)。
10 Regulations: 10规定:
1) All Amateur Radio stations who has a license to transmit SSTV signal. 1)所有业余无线电台 ​​许可证SSTV信号传输。
2) Output power: Up to maximum power officially authorized by the operators class license . 2)输出功率:最大功率正式授权的运营商类牌照。
3) Both B/W and Color Picture QSO are accepted. 3)B / W和彩色图片QSO被接受。
4) A contest QSO should be one station to one station QSO. 4)竞赛通联应该是一个站一个站通联。 Round table style QSO's between multiple stations will not be counted. 圆桌式类星体之间的多个站点将不会被计算在内。
5) Cross band QSO will not be counted as a contest QSO. 5)交叉频段QSO将不能算作一个竞赛通联。
6) All the QSO; JA to JA station, JA to DX station, DX to DX station will be counted and 6)所有通联JA JA站的,JA DX电台,DX,DX电台将清点并   accepted as contest QSOs. 接受竞赛类星体。
11.JASTA Contest Results: 11.JASTA比赛结果:
The contest results will be sent to all stations who include a SASE. 较量的结果将被发送到所有站包括一个SASE。 Aditionally announcement will be made Aditionally将另行作出公布   on JASTA homepage and Japanese "CQ ham radio" magazine . JASTA主页 和日本的“CQ火腿无线电”杂志上。
12.The Contest Manager and Mailing Address : 12,竞赛经理和邮寄地址:
JASTA Contest Secretariat ?@Email: ja3wzt@mue.biglobe.ne.jp JASTA大赛秘书处@电子邮件: ja3wzt@mue.biglobe.ne.jp
c/o YOSHIKAZU TANABE JA3WZT/1 C / O YOSHIKAZU田边JA3WZT / 1
905-8,SHIMO YAGANUKI ,IRUMA,SAITAMA,358 0041 JAPAN 入间市,905-8,下落YAGANUKI,埼玉县,358 0041 日本
DXCC Mixed
bd7mtj@qq.com
离线深圳上尉
只看该作者 3楼 发表于: 2013-08-18
DXCC Mixed
bd7mtj@qq.com
离线ba2ba
只看该作者 4楼 发表于: 2013-08-18
回 深圳上尉 的帖子
深圳上尉:就是一日本搞的SSTV比赛
http://homepage3.nifty.com/jasta/english/e_activ/active10.htm (2013-08-18 15:38)
用"有道翻译"看了个大概。虽然是2010年的规则,还是谢谢你给的链接。
这个比赛在《现代通信》或世界比赛网站没有介绍,看来影响力不大。
姓名:陈铁石/BA2BA
邮编:153021
电话:18804585572
QQ:464826156
离线bh4jvk
只看该作者 5楼 发表于: 2013-08-19
昨天 我也去凑热闹了
山东省德州市 微信BH4JVK
只看该作者 6楼 发表于: 2013-08-19
看到别人在比赛,没掺和
900兆:要奇奇陆吧三铃摇摇就散
离线BG5TOX
只看该作者 7楼 发表于: 2013-08-29
打扰别人比赛了~~~~
后来才发现是在比赛
PS:好长好长的呼号………………
Callsign:BG5TOX (微信同号)
QQ:327586364
离线ba2ba
只看该作者 8楼 发表于: 2013-08-29
回 BG5TOX 的帖子
BG5TOX:[图片]
打扰别人比赛了~~~~[表情]
后来才发现是在比赛
....... (2013-08-29 14:06)
今天中午我看到8N6MMTTY/6这个呼号电台与日本台通联,我没有联系上。
姓名:陈铁石/BA2BA
邮编:153021
电话:18804585572
QQ:464826156
